ESR or Capacitance Meter???
  • Andyd1970
    • Feb 2013
    • 374
    • united kingdom
    Hi Guys,
    Really getting into repairing TV's now with thanks to TOM66 who is a real star and has taught me a few things.
    I am looking to get an ESR meter but a friend said why not get a capacitance meter instead, so I was wondering if anyone could clarify between the two types.
    I believe a ESR can be used without removing the caps, and the capacitance meter has to have the caps desoldered first.
    Also any recommendations on a good unit for someone who is going to repair a TV or two.
    Andy
  • 1supertech
    • Apr 2012
    • 384
    Re: ESR or Capacitance Meter???
    Yes you’re correct
    But as far as using a Esr meter if caps are in series you will get false reading I notice this on motherboards but for power supplies Esr meter is a time saver. for caps lower then 0.1UF I us a capacitance meter.
    EDS -88A ESR METER
    M6013 AUTO RANGING CAPACITOR TESTER
    • mariushm
      • May 2011
      • 3799
      Capacitance checker will measure the capacitance
      ESR meter will measure the ESR.
      They are two different things.
      The capacitance is not a very useful value to know when repairing stuff. The capacitors themselves can have +/- 20% variation and the tool itself is only about +/- 1-5% when it comes to measure the capacitance.
      Furthermore, most capacitance meters only use low voltage to determine capacitance, usually up to 2v - this works for low voltage rated capacitors but not so well for 200-400v rated capacitors.
      The capacitors may be bad but the capacitance may still be reported within that 20% tolerance by a meter because the meter only charges the capacitor up to a few volts.
      Of particular importance is the case of ceramic capacitors - the capacitance of ceramic capacitors is hugely dependent on voltage going through them: depending on type, a 10uF 16v ceramic capacitor will have 10uF at 1v, 8uF at 3-4v and can have as low as 1-2uF at 10v. A multimeter won't catch this issue.
      The measurements are also done at low frequency not at frequencies commonly used in power supplies (above hearing level, generally 37Khz-100kHz). On lots of capacitors, the capacitance changes with frequency.
      Capacitors can also go bad/dry up etc yet still show a reasonably good value but when ran at high frequency in switching power supplies they will have a totally different capacitance and they'll heat up due to increase resistance and so on.
      So basically, an ESR meter is much more useful.
      Now, cheap esr meters like Bob Parker's esr meter or ESRMicro or other esr meters you find on eBay for 20-40$ are not really "true" esr meters, but they use some method of determining the ESR that actually gives a close enough approximation of the capacitors' esr, one that's good enough to tell you if a capacitor is bad or not.
      They're much more useful and I highly recommend you to get one.
      If you want really accurate esr reading, you have to invest into a proper LCR meter with ESR function... which cost from about 180$ and up.
      Most of the ones on the cheaper end only measure up to 10kHz but this is still quite a reasonable frequency and if a capacitor has a high esr at 10 khz, it's unlikely it will have better esr at 100kHz.
      • MrBojangles
        Yamaha PASC5 X0S-00 E-bike charger 42V only providing 12 V
        by MrBojangles
        Hey Guys!
        Hoping I can get some help here. I have a e-bike charger with 4 pins on the output. It has a light but the light does not turn on.
        When I check the voltage on the 4 pins on one of the pairs I get 12 V. On the other pairs the voltage keeps changing.
        Nothing looks damaged and there are no shorts on any of the capacitors. I've ordered a ESR meter to measure the capacitance of the capacitors but it will take a while for the package to arrive.
        Any tips?
        03-13-2025, 07:25 AM
        Sacon FZ revival experiment
        by momaka
        So after using capacitor bungs to repair the rubber feet on two laptops, shown here:
        https://www.badcaps.net/forum/showpo...&postcount=548
        … and here:
        https://www.badcaps.net/forum/showpo...&postcount=585
        … I was inevitably left with some paper rolls and cans from the Sacon FZ capacitors I “sacrificed”.
        The paper rolls from these Sacon FZ caps looked absolutely bone-dry. The idea then occurred to me: what if I put a few drops of water on there? How (if at all) would that affect these already-failed capacitors?...
        01-26-2022, 08:43 PM
      • dragon3x
        by dragon3x
        power on.
        Here are some examples :
        switching supply area).
        than 6.3 V.)
        03-21-2025, 02:46 PM
      • nicktasios
        Macintosh Quadra 840AV PSU
        by nicktasios
        I had my Quadra 840AV (which I recapped and had working) plugged in for some time without using it and randomly decided to turn it on today. Unfortunately it did not turn on. After checking the PSU, I found out I was not getting anything from 12V, only from the 5V rail. After a few minutes, I removed the PSU and plugged it back in the electrical outlet and it suddenly started making a weird sound and soon after smoke started coming out. I quickly unplugged it. I opened it up but on first instance I didn't see anything out of the ordinary really. I later turned it back on and one of the MOVs blew...
        12-22-2024, 05:07 AM
      • shagster
        Capacitor Discharge Rate Testing!
        by shagster
        Hi, I have 2 identical capacitors from an old scope I'm trying to get running.
        Both caps measure ok in ESR and Capacitance values imo.
        Data sheet says tolerance spec is -10 +50%. And these are way under that.
        Both of there original values are marked as (430uf 200vdc).
        After ~40 years, they now measure 485uf and 465uf. Well under the +50% tol.
        Anyway I charged them up to 24 volts dc and discharged them slowly down to 10 volts using a Digital Multi Meter. Funny thing was one of them just took over 4 minutes to discharge down to 10 volts. And the...
        08-24-2023, 02:55 PM
