Yamaha PASC5 X0S-00 E-bike charger 42V only providing 12 V
  • MrBojangles
    • Jul 2024
    • 44
    • Sweden
    Hey Guys!
    Hoping I can get some help here. I have a e-bike charger with 4 pins on the output. It has a light but the light does not turn on.
    When I check the voltage on the 4 pins on one of the pairs I get 12 V. On the other pairs the voltage keeps changing.
    Nothing looks damaged and there are no shorts on any of the capacitors. I've ordered a ESR meter to measure the capacitance of the capacitors but it will take a while for the package to arrive.
    Any tips?
  • Sam Scarbo
    • Oct 2023
    • 38
    You may check the device TJ30S6M3. It is near the two big capacitors near the output. It could be acting as a fast switching high-current rectifier.
    • MrBojangles
      • Jul 2024
      • 44
      • Sweden
      Thanks for the tip dude. You were close. It was the two output capacitors. I removed them to check the capacitance but my multimeter wasn't able to measure so I soldered them back and then it worked. So it must have been the solder joints.
      Anyway looks like it's a good tip in general to check the output capacitors when the output voltage is low.
      • motormayhem
        Lenovo T460 Only Charges on One Charger
        by motormayhem
        Laptop Question
        I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
        A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
        05-12-2023, 01:46 PM
      • Austin Siebert
        Acer Nitro 5 met my ebike charger...
        by Austin Siebert
        Acer Nitro 5 AN515-5779TD
        Board GH51G LA-L181P Rev: 1B
        Well I was rushing to finish homework and just plugged my 54.6v 3 amp DC ebike charger into it. So thats just miserable. I just spent 2 days troubleshooting a parasitic drain on my A6 that killed my alternator. This literally happened right after I got that all diagnosed and fixed.
        So visually it looks to be localized to the TI BQ24781 charge controller. Pins 2, and 27 look burnt aswell as the top of it got so hot as to melt the plastic it was touching even after I realized what was going on and disconnected...
        01-22-2025, 01:52 AM
        NVDC charger configuration...
        11-05-2024, 03:28 PM
      • flat-earther
        how to prevent a connected charger from draining battery when not charging?
        by flat-earther
        I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
        So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
        but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
        So the battery is backfeeding the charger and being drained.
        How can I prevent...
        08-07-2025, 01:04 PM
      • flat-earther
        ASUS X54H laptop thinks it's always charging even with charger unplugged
        by flat-earther
        The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
        Windows also shows ''Plugged in'' when charger is not connected.
        This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
        Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
        If I let battery run out and say it has 3% Windows will...
        06-24-2025, 09:32 AM
