Stubborn solder won't leave hole!
  • mockingbird
    • Dec 2008
    • 5484
    Re: Stubborn solder won't leave hole!
    I've reached the conclusion that for really difficult spots, like an IPM off a plasma, the only way to do it is with a vacuum-desoldering gun or a high end desoldering gun... There's simply too much ground plane and the difficulty is compounded by the fact that the solder typically used is a really stubborn RoHS alloy...
    And even with all that high end equipment, you still need to heat the IPM for a while before even attempting.
    I've found that ChipQuick is really _REALLY_ expensive for what it is, and the only kinds of people I could see using it are those who need it for really-high end custom jobs where typical tools won't work.
    • severach
      • Aug 2007
      • 1055
      A paper clip has the right shape but is the wrong metal. Solder will stick to it. A paper clip bends too easily. You also don't get to choose the diameter of the paper clip so it won't work when the board makers match the hole diameter to the lead diameter.
      Using the butt end of a drill bit solves all these problems. Chuck the drill into a pin vice to keep the sharp end from drilling you.
      A vacuum desoldering tool will destroy as many pads as a soldering iron. Hot air is the great equalizer. Heat the board up to 150*C and it matters not how big the plane is. You can heat with air all day long and not damage anything.
      sig files are for morons
      • Ltank
        • Jun 2013
        • 776
        I am build a DIY Preheater. Will cost about 250 but is CPU controlled optoisolated SSR,
        Heat sink, 1300 Watt Milwaukee heat gun element, 23 CFM 110vac fan, digital readout
        Use industry standard 3°C/sec Preheat to 150°C. This should help alot. When finnished I will have on a post I already started
        • howardc64
          by howardc64
          Problem
          08-04-2024, 10:36 PM
        • corrize
          Best way to solder LVDS connector for beginner (and qfn) ?
          by corrize
          Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
          I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
          I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
          See the test :
          https://youtu.be/bNAzC-EvqHs?t=1767
          With hot air from bellow the board, that's...
          03-09-2023, 02:57 AM
        • petemanuk
          BGA solder balls not connecting - help pls
          by petemanuk
          So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
          I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
          I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
          11-16-2022, 05:21 AM
        • myth77
          UV solder mask - high temp resistent, recomendation?
          by myth77
          Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
          Is there any solder mask...
          03-28-2022, 04:04 AM
        • Maniackk
          Yoga 530-14ARR NM-B781 Ryzen 3 2200 – overheating and shutting down under load
          by Maniackk
          I’ve got a stubborn patient here. The laptop powers on and works, all components like the screen, keyboard, touchpad, etc. are functional. The issue is that it heats up very quickly under load (within a few minutes up to 95°C) and then shuts down shortly after. Subsequent attempts to turn it back on right after a “hot shutdown” result in it shutting off within a few seconds. Interestingly, if I enter the BIOS, it can stay there for 2 days without shutting down (most likely due to low CPU load and low temperatures).
          The cooling system has been cleaned, thermal...
          09-03-2025, 09:32 AM
