Cool weller Blog site for reviews
  • teeDee
    • Jul 2006
    • 5
    I have been wondering where I can go to get reviews on weller solder products, and I finally found a place, and it's right from the horses mouth.
    It's at All-Spec's blog site, actually you can get it from there, check it out.
    Weller solder reviews
  • starfury1
    • May 2006
    • 1256
    Re: Cool weller Blog site for reviews
    Thanks teeDee will have a look later.
    Seems like getting decent reviews on test equipment is like pulling hens teeth
    maybe I'm looking in the wrong places but I find it very had to find them.
    cheers all
    You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
    • Toueno
      Dyson Pure Hot+Cool HP00 - Datasheet needed
      by Toueno
      My Dyson Pure Hot+Cool, model HP00, no longer starts.
      After disassembling and accessing the electronic motherboard, I found that the 16A fuse soldered to the motherboard is dead. I decided to do an electronic shunt to see the reaction, and the Dyson turns on for a few seconds and then turns off.
      It is likely that a voltage control chip or a safety chip is dead, but without the electrical schematics, the repair becomes complicated…
      Thank you in advance for your help.
      Best regards
      08-14-2024, 10:38 AM
    • edugimeno
      Wine cooler flickers at startup and doesn't cool enough
      by edugimeno
      Hi there!
      I have an old wine bottle cooler, it's a basic peltier cell system with a power supply built in with the controller board, with a simple display at the front door and 2 push buttons to select the desired temperatura.
      Symptoms are it doesn't barely cool down, and makes a chirping noise at the board.
      Both fans on each side of the peltier are (now, after much cleaning) running smooth and silent
      When you turn it on, the front 7-segment display flickers for a variable time, usually like 1 minute but sometimes nothing or 3 minutes... Then turn on solid (but still some...
      03-01-2025, 04:51 AM
    • clearchris
      Old Weller 100/140 Watt Soldering Gun
      by clearchris
      Someone gave me two of these 100/140w weller soldering guns. Yes, I know it runs current right through the tip, but might be nice to really get some heat into some big wires that need to be soldered.
      So, worth a place on the bench, or chuck it?
      10-04-2023, 01:27 PM
    • Exman
      Weller WD1 with T12 Tips
      by Exman
      Dear BC,
      Today, by luck & chance I found a used Weller WD1 soldering station in my used local market for a very good price and I couldn't say no
      The seller sold it as it's with no warranty and no return, I accepted his t&c since he gave it on my asking price, only the station nothing else with
      My question, is there a way to mod a T12 with this station or someone did like this modification before
      Thank & waiting your replies
      04-10-2023, 02:39 PM
    • honigmann
      Dell 5591 overheating in memtest86+ but cool running Linux Mint - What causes this?
      by honigmann
      This machine comes with the i7-8850H, no internal drive and no battery installed, the bottom cover removed, an original Dell power supply is used. I just installed 8GB RAM, ran memtest86+ and noticed a power draw of about 40-50W. Accordingly within minutes the temperature went up to just below 100 degrees with the fan spinning wildly. Same thing when I enter the BIOS (1.20.0), around 40W power draw.
      Next thing I tried was an install stick with Linux Mint on it. Initially I am also at around 40W but with idle desktop (Xfce) it draws just 6,5W. Is this a BIOS issue? Version 1.34 is...
      09-23-2024, 08:51 AM
