BGA questions and possible equipment purchase
  • Spork Schivago
    • Mar 2012
    • 4734
    • United States of America
    Hi guys, hope this is in the right section. I've been scouring the internet for some answers and I'm getting a little confused so I figured I'd just ask.
    I want to purchase some equipment so I can remove some chips off of some boards and replace them or replace the solder. The boards I want to work on will be laptop / desktop, XBox 360 and Playstation 3 boards. I don't really want to go much higher than 1,500$ on the equipment. Now on to the questions.
    First off, I've seen many video's on youtube on people using rework stations. There seems to be two types of machines, one uses hot air and one uses IR lighting. What's the best one to use?
    Secondly, how exactly does the process work? My understanding is you remove the chip, remove the old solder then use a grid of one sort or another to put solder on the chip, heat up the solder till it melts, remove the grid, lay the chip on the board and heat it up. I was playing with an old 360 that I couldn't fix and used a heat gun to remove the chip and the little ICs on the GPU flew off from the air. Wouldn't I have the same problem if I got a hot air rework station?
    How do you know the chip is lined up on the board correctly before you melt the solder? And also, can anyone suggest a good system for the money I have? If I need anything more than just the rework station, please let me know. Thanks.
    -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
  • Spork Schivago
    • Mar 2012
    • 4734
    Re: BGA questions and possible equipment purchase
    Well, no one has answered yet. Is this the wrong place to ask this question in? Should I try starting a new thread in another section?
    • sasser
      • Dec 2012
      • 364
      • Malaysia
      if u business purpose u need the good rework station, reballing station and some tools for rework. rework station some use ir heater and hot air heater just help u to get accurate tempreture when lift and place back BGA. your ask about lined up bga on board when place bga. just put the bga on pad then see when ball underneth melt slowly go on position .
      • Kiriakos GR
        Banned
        • May 2012
        • 940
        • Greece
        XBox and Playstation chips are huge in size, many older equipment does not have the power to unsolder those chips.
        You should forget the budget limit and find out the latest system that can do the job.
        Recently a local friend find and ordered the proper modern one, but I do not remember brand or model, all that I remember is that is using a team of heat heads, and at the bottom base and also has an head at the top.
        • xboxhaxorz
          • Jan 2011
          • 196
          Working with large mainboards basically xbox ps3 and laptops you need a PROPER bga rework station. There are several options and sometime too many options. The chinese toss out rework machines as if it was candy. The most common are honton and achi.
          You can also go this route http://cgi.ebay.com/ws/eBayISAPI.dll...e=STRK:MESE:IT
          Then immediately upgrade heaters http://cgi.ebay.com/ws/eBayISAPI.dll...e=STRK:MESE:IT
          This will give you a very decent machine. The problem with chinese machines is they put cheap parts in them, they are not terribly bad, if you get the base and change some parts. If you spend over $5000 then the quality is higher but less and you cant expect much as these machines were originally very expensive. I represent XModdz where we specialize in bga repair, since we got into the repair business we got the best machine possible. Take a look http://www.youtube.com/watch?v=kDTrS7wDyNE and this give us extremely high success and best part is we dont feel shitty doing a clients work.
          If i was repairing your laptop with a heatgun and griddle i would be bad personally. I know the repair may work but the problem will return.
          To respond to you in simple terms view this http://xmoddz.com/hot-air-vs-ir
          That will help you choose properly
          • acedogblast
            by acedogblast
            11-02-2024, 05:13 PM
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • viewerau
            Remove excess solder
            by viewerau
            Can someone tell me how (or if) I can remove this excess solder?
            I made a novice boo boo.
            The board is an edge board from an lcd tv, and it connects to the tv panel via a fixed cof strip.
            I had to remove a surface mounted multi diode chip (yes I did a bad job) but got some residue solder on the pins when cleaning it up with a ribbon wick.
            Can I get that excess off, as I believe it is causing interference to the panel, shorting or something, that effects just a small portion of my image.
            Any pointers please?...
            08-16-2023, 03:52 AM
          • corrize
            Best way to solder LVDS connector for beginner (and qfn) ?
            by corrize
            Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
            I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
            I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
            See the test :
            https://youtu.be/bNAzC-EvqHs?t=1767
            With hot air from bellow the board, that's...
            03-09-2023, 02:57 AM
            Multifix 425-01 and 450-01 Rework Flux Datasheet
            REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
            - No Clean Formulations
            - Low residue
            - Range of activity to deal with different component solderability
            - Halide free
            - Suitable for dispensing
            - Compatible with solder coatings and/or No Clean flux cored solder wire product range
            Both products are supplied in syringes or cartridges for application by dispensing....
            10-07-2024, 06:02 AM
