HP 3468A Bench Multimeter Repair
  • retiredcaps
    • Apr 2010
    • 9271
    Modemhead, a member here, has posted a new blog about a HP 3468A Bench Multimeter Repair. See
    http://mrmodemhead.com/blog/hp3468a-...imeter-repair/
    What is interesting is that I can't recall hearing about a shorted electrolytic capacitor on badcaps.net. I found a shorted ceramic capacitor in a 19 inch monitor, but never an electrolytic one.
    PS. The Fluke 8060A he is using to measure the resistance of the 27+ year old Sprague caps was also a victim of obviously bad leaking capacitors (just like my 8060A). It is documented at
    http://mrmodemhead.com/blog/fluke-8060a-repair/
    --- begin sig file ---
    --- end sig file ---
  • smason
    • 1652
    Re: HP 3468A Bench Multimeter Repair
    Damn, nice looking meter.
    I haven't heard of a shorted electrolytic either.
    I would think it would explode or at least pop a top and ooze out.
    Still waiting for my 8040A, it seems to be vacationing in Erlanger, Kentucky.
    • modemhead
      Lurking
      • Jun 2012
      • 52
      I put one of the shorted caps on my power supply and slowly ramped up the current limit. The cap opened up at 620mA. It now measures 338uF, and 0.05 ohms on an ESR tester, and generally acts like a cap again. So whatever the fault was, it was destroyed (at least temporarily) by a little heat.
      • retiredcaps
        • Apr 2010
        • 9271
        Somewhat related video on a shorted capacitor (jump to 11:23 if you don't have time or want to watch the whole thing).
        http://www.youtube.com/watch?v=at7GLypcLro
        One of the 4 main filter caps was a dead short as measured by a bench Fluke. A shorted cap is not something I would have tested for in the above video, but it looks like I will have to add that to my troubleshooting routine now.
        I tried fixing a HK AVR, but gave up after I couldn't get the stupid boards apart.
        Details for those interested.
        https://www.badcaps.net/forum/showthread.php?t=10066
        • Kiriakos GR
          Banned
          • May 2012
          • 940
          • Greece
          One old 8050A which I got from the States (Ebay) it came with a burned resistor which was spliced in half and it was making contact occasionally.
          And it was effecting the power-on of the meter which suddenly it was turn off.
          This was a truly unexpected damage.
          But either way I am not easily surprised any more by anything unexpected those days.
          • Yanleb
            Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
            by Yanleb
            Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
            I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
            D608, good
            D618 RF101L4S, good (See warning 1 below)
            D619 RF101L4S, good (See warning 1 below)
            D865 RF101L4S, shorted (See warning 1 below)
            IC464 Inverter HA MC74HC1G14, shorted...
            03-09-2020, 12:00 AM
          • Geeker007
            Friend messed up my laptop motherboard while working on my bench
            by Geeker007
            Hi All,
            So my friend was visiting and he wanted to use my solder bench to solder on some WLED circuit board. My laptop was open on the side for RAM upgrade. I know my mistake.
            So while soldering he had too much solder on the soldering iron tip and he just shook off the soldering iron on the table itself to remove extra solder on the soldering tip and it landed on the motherboard of laptop. He then out of fear tried to remove it using solder wick and did more damage by removing some components as well. So here I am with weird situation.
            I have not tried putting...
            06-16-2025, 01:40 PM
          • modtool
            HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
            by modtool
            Hi to all,
            the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
            I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
            I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
            04-01-2025, 08:22 AM
          • BalkanBoy
            Dead Razer Blade 14 2022, shorted CPU?
            by BalkanBoy
            today I got Razer Blade 14, Ryzen 9 6900HX and RTX 3070Ti.
            Laptop was completely dead. I found shorted CPU VRM mosfet, shorted 19V mosfet and blown battery fuse.
            I replaced it all, but still on CPU coil where mosfet was shorted I got very low resistance, near 0 ohms. On other CPU coils I got around 3 ohms.
            Laptop now raises voltage on whole board, but still nothing comes on the screen. CPU gets 0.7V on all coils except the shorted one. CPU gets only slightly hot, below 40 C.
            I removed coil and injected 0.7V, it draw around...
            09-27-2024, 12:44 PM
          • guizmo1967
            Dell Latitude 5501 LA-H181P shorted power rail
            by guizmo1967
            This is my problem:
            Laptop: Dell Latitude 5501
            Motherboard: EDC51 LA-H181P
            I have two power rails shorted to ground, +1.0V_PRIM and +3.3V_ALW_PCH. I removed solder on PJP302, +1.05VALWP (pad1) not shorted but +1.0V_PRIM (pad2) shorted.
            I also cleaned PJP38, pad1 not shorted, pad2 (+3.3V_ALW_PCH) shorted to ground.
            I measure the resistance of all the coils on the motherboard and they all were not shorted to ground except coil PL301 before I removed the solder on PJP302.
            I injected +1.05V - 2A...
            07-25-2023, 06:56 PM
