Which used bench multimeter
  • smason
    • 1652
    Re: Which used bench multimeter
    Originally posted by retiredcaps
    Can you be one of my customers?
    What do you sell?
    • smason
      • 1652
      Got it today. So far so good.
      Looks good, seems to work.
      My Fluke 87 agrees with it (up to it's resolution) and my 77 seems a bit low on DC volts.
      Will do some more methodical testing and shoot a few pics later this week.
      • retiredcaps
        • Apr 2010
        • 9271
        Fortunately, the only pot (top left hand corner just underneath the lcd) in the older Fluke 70s series is for DC V. I believe you use a 3.000V DC source for calibration.
        --- begin sig file ---
        --- end sig file ---
          12-31-2023, 06:04 AM
        • Baldbentley
          repairing a Fluke 335 clamp meter
          by Baldbentley
          I am repairing a Fluke 335 clamp meter. After contacting fluke it appears there is no service manual or circuit board/ component list available. I have determined that there us a faulty PNP bipolar junction transistors shown in the pictures. I am having trouble sourcing this transistor. I pulled a good one off of the board and tested it with my component analyzer but I cannot find anything that matches the specifications. Any help locating this part or a replacement would be greatly appreciated.
          Thanks...
          10-18-2023, 02:05 AM
        • chth96
          by chth96
          03-09-2024, 10:03 PM
        • smali
          Fluke 189 multimeter rotary switch contacts
          by smali
          Hi
          My Fluke 189DMM rotary contacts are missing. Can anyone tell me where to find them or any other way to make it?...
          01-03-2022, 06:56 AM
        • Pauldg1
          Fluke 289 multimeter not working
          by Pauldg1
          I have a Fluke 289 multimeter which does not work.
          Have anyone an idea what could be the cause?
          When I turn on the device only the green led is continuously on, and strange stripes are present in lcd screen. I can only turn off the device by removing the batteries.
          Any suggestions will be appreciated...
          04-05-2021, 07:47 AM
