Capacitor?
  • lorins_core
    BlackSmith
    • Dec 2012
    • 552
    • Philippines
    Capacitor?
    Would you Help me About Tis...
    I Have a Capacitor. can you answer this? and explain to me?
    1, 330g24L and 330e76 and 330_68LG , 330_68NG. It is a Same?
    Thank's and more Power.
  • selldoor
    Slow Learner
    • 7870
    Re: Capacitor?
    Not a clue what you mean - post clear picture of what you have
    • lorins_core
      BlackSmith
      • Dec 2012
      • 552
      • Philippines
      Re: Capacitor?
      Sir I Think No Need to Take A Pic. I Asking Only...
      A Value of The Following sample... same Farad and Voltage?
      Last edited by lorins_core; 02-07-2013, 03:59 AM. Reason: Value and Voltage And Fared?
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        Re: Capacitor?
        If I am thinking right, these are the codes on some SMD electrolytic (or polymer) capacitors?
        Muh-soggy-knee
          Re: Capacitor?
          It does sound like SMD LYTIC CAPS, but each companies has its own codes, without seeing the cap, that will be hard to know what kind of cap it is. I.E.
          https://cdn.badcaps-static.com/pdfs/...63aae3b97e.pdf
          What is so hard about posting the pictures?
          • lorins_core
            BlackSmith
            • Dec 2012
            • 552
            • Philippines
            Re: Capacitor?
            Yes Sir You Pin Point. Sorry to My English Grammar... hehehe. But You Can Teach me How To read Those Capacitor what is A Value Of Farad and Voltage You Have a Example? More Thank's
            • lorins_core
              BlackSmith
              • Dec 2012
              • 552
              • Philippines
              Re: Capacitor?
              i'm sorry Sir if I not post a picture here in my thread. Please let you know that later on I shall take a photo using my camera but those cameras I was not much beauty photographs. hehehe
              by the way More Thank You to your Effort to Teach me and sending me a Link to Identify The Value and Voltage and ex. of Manufacturer.
              • MORETTIGIAN
                Capacitor detached from PCB – RTX 2070 Super Founders Edition
                by MORETTIGIAN
                Title:
                Description:
                During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                I did not notice it detaching, so I am unsure of its original location on the PCB.
                Procedure performed:
                - Removed backplate
                - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                - Reapplied thermal compound
                - Reassembled card
                Observed behavior after reassembly:
                - GPU powers on and operates normally under...
                09-18-2025, 12:14 PM
              • Prolog
                RTX 3080 FE Identifying capacitor
                by Prolog
                Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                I hope these photos make it clear which component I am referring to:
                (yes, the soldering is a bit botched from removing the blown one, I know)
                I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                12-01-2024, 08:27 PM
              • chth96
                If I replace with inferior capacitor, Is it No harm to other IC components at all?
                by chth96
                I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                I know that these capacitor will not last as long as nichicon capacitor...
                12-22-2023, 04:34 AM
              • chth96
                How can I test non-polarized capacitor?
                by chth96
                I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
                I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
                And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
                I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
                06-02-2024, 07:31 PM
              • chth96
                Is it no harm to replace with capacitor without ripple current rating?
                by chth96
                When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                Rubycon YK DataSheet (b...
                04-19-2024, 05:19 AM
