Somewhat Urgent Ebay auction for Eico model 460
  • ComputerGeek
    • Oct 2011
    • 262
    Hey guys, I have a Somewhat Urgent Ebay auction Quesiton. I am watching 2 Eico model 460 oscilloscopes that I am thinking about buying. I know that these aren't very useful because of their low sample rate, correct? I do like the vintage factor of them though. So here are my questions.
    What would you pay for one of these?
    Is there any thing I should know about these. Any difficult to find replacement parts? I know that I probably am going to need to replace the filter Caps.
    I asked the seller a bunch of Questions. They have some rust around the front bezels, which seems common for these models. The Seller says that he has not plugged them in or tested them, which I prefer because then if something goes Pop, I can start them with the covers off and know where it is.
    Here are the two listings promise not to bid against me, LOL
    http://www.ebay.com/itm/110986134361
    http://www.ebay.com/itm/110986136080
    He also has a 425 but it looks shot. Rust all over it.
    THanks!
    Re: Somewhat Urgent Ebay auction for Eico model 460
    This unit uses lots of tubes, so unless you have some money to spend on replacement tubes. It is also only 4.5MHz bandwidth (analog scope does not deal with sampling rate like digital scope). You can also expect to replace caps (paper type) and electrolytics type also..
    • ComputerGeek
      • Oct 2011
      • 262
      How many tubes are you thinking that I will need to replace? All of them?
      How difficult is it to find replacement tubes for this unit?
        http://www.radiomuseum.org/r/eico_46...scope_kit.html
        • ComputerGeek
          • Oct 2011
          • 262
          Hmm ok there are a total of ten tubes and all the tubes can be found on ebay for under 3 with the exception of 5UP1 or DG13-32 which seems sort of rare. Still there is a listing for the 5up1 for 30 shipped so I should be able to get all the tubes for under $60.
          Do you think that any of the tubes might be good or do I just have to replace them all?
            Do you really want to spend $60 or more on 1956 scope? Unless you have tube tester. You will have to have the unit in your hand to really check out and the service manual so you can calibrate or fix what is needed to be fixed.
            • ComputerGeek
              • Oct 2011
              • 262
              I don't know I sort of like the vintage factor. Don't tube scopes have some different properties from typical analog scopes? Would the heathkit 10-12 be a better choice?
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                I actually have one of these at my parents' place, and it still works. I was actually using it to look at a particular PSU's output waveform. Its bandwith is fairly limited, only hundreds of KHz, but it's well fast enough to see the sawtooth from that switching power supply with tons of bad caps... Its case, unfortunately, has seen better days. Not that it's beat up, but rather it's rusty. The ebay pics look better. But I know mine works
                I don't really think the tube scope is any more desirable other than the fact it's old compared to my analog tube but semiconductor amplifier scope (which has an order of magnitude higher bandwidth and dual trace.)
                I am in the market to upgrade to a DSO though...
                • redwire
                  • Dec 2010
                  • 3910
                  The EICO460 shipping weight is 30lbs! $$ You don't buy a vintage scope unless you love them, they are high-maintenance. The CRT could be shot too, it's like 60+ years old. It's too slow for any digital work.
                  Popular low-cost modern DSO's people are buying Rigol or Owon for ~$350 or you could look at a USB scope.
                  • DXseekerMO
                    Backlight strip quality, Amazon vs Ebay vs ShopJimmy. Is there really a difference?
                    by DXseekerMO
                    Hello everyone!
                    Recently I've noticed that some ShopJimmy backlight strips don't have double-sided tape installed upon them when an application calls for it, and I must purchase the tape separately. In a recent chat conversation with a customer service agent I told them if this tape wasn't applied when it was called for I would begin to consider ordering my backlight strips elsewhere. It looks like this time may have come.
                    I recently got a TCL 65S4 with bad backlights. After looking at the SJ listing here: https://www.shopjimmy.com/tcl-jl-d65...365as-m-led-ba...
                    Yes
                    0%
                    1
                    All backlight strips are the same quality
                    0%
                    1
                    No
                    0%
                    0
                    12-16-2021, 03:58 PM
                  • Topcat
                    Windows 10 Enterprise - From Ebay...
                    by Topcat
                    https://www.ebay.com/itm/324996085177
                    You find these on ebay all the time. Seller feedback is good in regards to them being legit...but I'm still leary. Anyone with experience with these? Seems quite a few around here are running enterprise; and unless ya'll are stealing the keys from your employers, where are you getting them?
                    03-02-2023, 03:16 PM
                  • shovenose
                    Spare Parts + eBay's Finest = Worst Gaming PC of 2021?
                    by shovenose
                    Alright folks, today I present my latest "build", consisting of mostly spare parts with a few things off eBay.
                    Parts List and Pricing
                    CPU: 3/0GHz 4C/4T Intel Core i5-7400. Nothing exciting here, got it off eBay for $80.
                    RAM: 16GB (2x8GB) Corsair DDR4-2400. Had it floating around. Free.
                    Motherboard: Gigabyte B250M-Gaming 3. Because I had it floating around and the model number contains gaming so it must be better, right? Free.
                    Storage: 240GB WD Easystore SSD. As far as I know, it's just the Best Buy rebadge of...
                    12-21-2021, 08:34 PM
                  • neilc6
                    Sold Sharp LC-50LB370U Board on Ebay - Return Requested
                    by neilc6
                    Sold this board on ebay with this warning in the description and pic of working TV.
                    "Pulled from a TV with a damaged panel. NO REFUNDS.
                    This model suffers from LED backlight failures. Make sure your backlights are working before replacing boards. Symptom is TV turns on and off with no backlight or a flash of backlights."
                    Ebay Return Request
                    Reason for return - Doesn't work or defective
                    Details - Powersupply board has sound,but verry dark screen.I would like to return,You send for me another one. Thank You.
                    With ebay, if...
                    07-16-2021, 04:00 PM
                  • myth77
                    how do you resolve problems with ebay (and other shop) scammers!?
                    by myth77
                    When i need to replace cpu or gpu or pch ...i mostly order reballed chip from china, but lately there are more broken ones then working.
                    So lately i tried with ebay "not working motherboards". I ordered a few broken motherboards from ebay but i have found out that there are many scammers on ebay. The most of them are selling already destroyed motherboards with pictures in low resolution, some of them are being scammed and just scam forwarding...
                    First board i ordered last month was ok. Cpu was dead but i could use gpu and pch. The second arrived 2 weeks ago...and it was...
                    09-02-2022, 04:53 AM
