Hakko FX-888 vs 936
  • senndogg
    • Dec 2011
    • 383
    • Albania
    Hakko FX-888 vs 936
    i am in front of a choice.
    -a genuine new 220V 936 from the seller of the Japanese lot. i contacted him and he said that he had a new one somewhere, found it and listed it for me. i have bought it but not paid yet. 150$ (postage included and 5 genuine tips)
    -he told me to wait because a lot of new genuine FX888 was coming these days. he claims that he has worked with both and the 888 is 10 times better. it is 30$ more expensive, and i need a 220-110 adapter also. this would also come with extra tips for 180$.
    question is, is it worth it? 30$ less and the ease of just plugging it into the wall for 936, against the proclaimed supremacy all over the web of FX888... is this that good?
  • mariushm
    • May 2011
    • 3799
    Re: Hakko FX-888 vs 936
    The FX888 is not ten times better.
    It has just about 5 watts more power which means it reaches the temperature and recovers a few seconds faster which is not making a difference in normal usage.
    The tips are also compatible between 936 and fx888, the new ones for 888 are just a few mm longer. They can be used with 936, just being a few mm longer the temperature is slightly off - like.. you preset the heat to 350c on the knob and you actually have 325-335c on the tip.
    Really, it makes no difference, the solder melts at 215c for lead free but you keep the solder iron at 300-350 anyway so that it recovers fast and there's a heat reservoir in the iron, so being +/- 10c off is not an issue. (and you can open it and adjust the accuracy with a potentiometer inside if it really bothers you)
    If it's the genuine Japanese with micro controller it's a good buy, i'd say stick with that one, too much bother with ac adapters for very little benefit.
    • senndogg
      • Dec 2011
      • 383
      • Albania
      thank you mariushm for the feedback. yes, its the japanese one, i was browsing some threads and found good feedback for this seller so i think i can rely on it.
      • senndogg
        • Dec 2011
        • 383
        • Albania
        bought it! now waiting for it to be shipped with the 10 extra tips.
        • smason
          • 1652
          Sweet. You won't be disappointed.
          • Hondaman
            Japanese language -- Win7 or Linux Mint?
            by Hondaman
            I ordered a Japanese book, it will never be published in English. A Mr. Fujumoto was a Japanese sushi chef who became a cook for Kim Jong-Il. He was not perceived as a threat to the dictator's power, so he became very close to the dictator. Apparently, the dictator is QUITE hedonistic, with a lot of debauchery. Although he can spend as much as $700,000 per year on alcoholic beverages and this alcohol is NOT actually the highest quality. Also, the dictator has 24 palaces. One of them is as large as TEN YANKEE STADIUMS PUT TOGETHER. Are they all that large?
            Does anyone have experience...
            09-12-2025, 04:32 AM
          • redwire
            Hakko 950 SMT hot tweezers but no base or stand
            by redwire
            I got gifted a Hakko 950 SMT hot tweezers but no base or stand.
            Any suggestions for building one?
            "The 950 is compatible with the Hakko 936, 937, 939, 703, 926, 927 and 928 soldering stations." Apparently it has two heaters in parallel "24V 50W", one RTD temperature sensor 43-58Ω at room temp. 5-pin DIN.
            I don't have any of those, have a 470-2 (no RTD in) and a FX-888A.
            04-17-2025, 03:01 PM
          • estabilito
            Tips geting oxidized when using wick
            by estabilito
            Hi, i have weird problem - when i'm using soldering wick to clean BGA balls under CPU or PCH on motherboard my tips(different types) getting oxidized very fast and lost all power.
            i Was trying different types of wick, flux - no difference. I can't even clean one full socket and i need to use deoxidizer in half-time.
            Temperature: 350-365celsius
            station: jbc cd-2bqe
            Wick: edsyn
            flux: warton hf rework jelly
            Do you have any tips?...
            04-12-2025, 11:55 AM
          • sdinelli
            latitude e5550 - no charge- all battery not recognized as genuine
            by sdinelli
            -latitude e5550 all batteries sense as non genuine(ive tried two working genuine and two new non genuine).
            -battery led flashing white and amber which indicated non genuine AC adapter. tried multiple bios.
            -ive tried multiple genuine chargers
            -the circuitry seems to be working fine and battery and charging seems to be controlled by EU2 which is ECE5048-LZY
            https://datasheet.octopart.com/ECE50...-147335658.pdf
            does this chip have to be programmed? or is it replaceable? do you all think this could be the reason?
            i have two of these same...
            11-14-2021, 09:52 AM
          • tony359
            Aixun T3A overshooting?
            by tony359
            I've just purchased an Aixun T3A T245 soldering station and I am pretty happy with it, coming from a Hakko knockoff.
            However, I purchased a genuine JBC tip and the temp massively overshoots with it. I can see a similar behaviour with the Aixun tips but not so horrible.
            With the JBC tip on the thermometer I see the temp more or less stable but slowly dropping. At some point there is a 100% power spike and the registered temp goes +40C from where it was - obviously the display doesn't show anything!
            Is this "expected"?...
            09-12-2023, 10:19 AM
