Atten 858D review
  • Jasgriff
    • Feb 2012
    • 578
    Atten 858D review
    Retiredcaps has got me into watching crazy dave's videos and I came across this. Looks like they only cost around £35 and they might come in hand for removing SMD IC's rather than trying to use the soldering iron all the time.
    What do you think?
    ATTEN 858D Review
    Fixed so far : 1 Home cinema system, 16 LCD Monitors, 4 LCD TV's
    How to resize your pictures guide click HERE
    Retiredcaps Ideal post example click HERE
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Atten 858D review
    I borrowed my friend's non temperature controlled heat gun and use kapton tape to protect the surrounding components when removing SMD ICs like a sot-223. It takes about 30 seconds and I use low heat and use the smallest nozzle possible.
    Check out norcal715's videos. He makes removing SMD ICs look easy with just a plain soldering iron. He does it faster than the time it takes to read this whole post.
    His channel
    http://www.youtube.com/user/norcal715
    See him remove a 1117 regulator at (he starts at 8:45 and is done at 9:08)
    http://www.youtube.com/watch?v=cNFzBJELFoU
    He also shows some desoldering skills in his other videos.
    PS. I added his Vizio/1117 video to my how to test a voltage regulator FAQ.
    --- begin sig file ---
    --- end sig file ---
    • retiredcaps
      • Apr 2010
      • 9271
      I don't know the difference between the 858D and the 858D+, but see this thread if you are thinking of getting one.
      http://www.eevblog.com/forum/general...ework-station/
      • Jasgriff
        • Feb 2012
        • 578
        I had a read of the Atten issue on the eevblog forum. That must have been a one off.
        You do find some very good videos. I looked at the ones posted above and as always I it inspired me to find an old board and get the soldering iron out. Its strange how I seem to be able to desolder chips nice and easy when they are not important. But when I am concertrating on a chip that is important I tend to nearly mess it up.
        The guy in the video scares me when he starts to touch parts of the tv and desolder just after turning it off. Looks like he know what he is doing but going near a live transformer is crazy!
        I havent seen a video of anybody desoldering from a really thick board yet? have you come across one of these videos?
        Budm.... When are you going to get some video tutorials up and running? I am sure that they will make good viewing!
        • mariushm
          • May 2011
          • 3799
          I have the Atten 858D+
          It works OK but I don't have much use for it, I like to desolder surface mounted parts with my Hakko 936 more than using hot air gun.
          Probably used it 2-3 times.
          My unit didn't have the fan ears on the sides chopped to fit in the handle (as you can see in the eevblog video), the fan was from the start without those.
          The only scary part is that he removed the mains cable and therefore there's no more ground to the tv.
          Otherwise, mains voltage and high voltage only exists on one corner of that board at the top which is the power supply. I don't see him touching that so it's nothing to worry about.
          The board with the tv tuner and decoding chips and all that only receives at best 24v DC at low amps so it's 100% safe to work on without special precautions besides making sure you're grounded (or discharged yourself of static electricity before you went to work on it).
          • Jasgriff
            • Feb 2012
            • 578
            Have you looked at the other video of him desoldering the Inverter straight after turning it off? Either way I would much prefer to stay well away from anything live.
            • retiredcaps
              • Apr 2010
              • 9271
              PC motherboards are usually multilayer with lots of copper planes to suck away heat from the iron tip and most here recap motherboards with no problem.
              In Dave Jones' soldering tutorial #2, he does show how tip size matters when dealing with a sot-252.
              Some people use ChipQuik to help desolder stuff. See
              http://www.youtube.com/watch?v=3NN7UGWYmBY
              • mariushm
                • May 2011
                • 3799
                The inverter receives 12-24v from the secondary side and generates 700-1400v for the lamps. But it doesn't "hold" a charge in it.
                Once the TV/monitor is off, only the stand-by section on the secondary side MAY be powered on the board. The secondary side dedicated for powering the inverter isn't active.
                So he can do whatever he wants in that area, because it's nothing there that could cause problems.
                • Geeker007
                  Please review my ESP based WLED controller board for WS2815 12V LED Strips - New to electronics.
                  by Geeker007
                  I'm designing an ESP-based WLED controller board for WS2815 12V LED strips, with a primary focus on energy efficiency.
                  To minimize power consumption, my goal is to completely shut down the system when the LED strip is turned off.
                  However, the current buck converter powering the ESP module draws about 8 watts even when the LEDs are idle, making it unsuitable for low-power operation.
                  I am using below components:
                  • Buck Converter: TPS562201 (12V → 5V regulated)
                  • Microcontroller: XIAO ESP32-C3 (with built-in USB-C)
                  • LED Strip: WS2815 (12V digital LED strip)
                  • Switching
                  06-29-2025, 05:20 PM
                • draag de wereld
                  ATTEN ST 8800 D calibration ?
                  by draag de wereld
                  I have an ATTEN ST 8800 D. I tried it out and I have a problem with this machine. When I get the machine at 500°C at 50% airspeed. My motherboards (I tried on several) barely heat up to 180°C. I know how to calibrate the machine, but it can't be a calibration of 300°. Anyone has the same problem with this machine. I know buying cheap is buying expensive but a 300° difference is a rip off.
                  02-28-2025, 05:17 AM
                • petemanuk
                  Atten ST862D hot air station weird message!!
                  by petemanuk
                  Went to use my Atten ST862D hot air station today all fired up as normal but after few min's the heat stopped (air stil blowing) and the display popped up with the messasge COL.
                  I've read the manual (all 6 pages of it) from cover to cover but no mention of a display message COL ??
                  I'm guessing the heating element has gone and will investigate futher but just wondered if enyone else with an Atten ST862D has seen this message an knew what it ment? Just incase its something else.
                  01-14-2023, 01:11 PM
                • SarcasticOP
                  Seeking Guidance on Motherboard Diagnostics
                  by SarcasticOP
                  Hello everyone!
                  I hope this is the correct place to post this, if not please let me know and I will post in the appropriate location.
                  I'm venturing into the intricate world of board repair within electronics, and I'm reaching out to this community for some guidance and shared wisdom. I have tried to do some research myself and find this information on my own, but I don't know what I don't know, and that is really starting to become an insurmountable issue that I cannot overcome. The only person I had nearby that I could turn to passed away recently so I do not have anyone...
                  01-10-2024, 03:35 PM
                • dbuergi
                  Need assistance for reballing / replacing i5 CPU on a Macbook A1466
                  by dbuergi
                  i have some A1466 logicboards for gaining soldering and electronic experience. One board has a dead CPU and since i have several spares i want to change it. Unsoldering it was no problem but heat from the top showed that the CPU bent. I think too much heat was the problem.
                  So for unsoldering my spare parts and soldering back i would ask for some advises.
                  On most youtube videos you don't get any temperatures. Only helpfull video was one where the heat came from the bottom.
                  I have a small USB heating plate and a Atten ST-862D with several nozles.
                  06-27-2025, 02:59 AM
