Lutron DM-9023 Capacitance Meter
  • japlytic
    • Oct 2005
    • 2086
    About a month ago, I bought a Lutron DM-9023 Capacitance Meter, since I want to go through my stock of used electrolytic capacitors.
    It goes down to .1pF units, and can measure up to 20,000uF (it is not likely that I will ever measure a capacitor which is over 10,000uF or even over 20,000uF).
    Since Lutron (Taiwan) has been making quality test equipment for over 30 years, I can trust the accuracy of this particular equipment.
    With this equipment, I found a number of off-brand (Jun Fu, JP etc.) 200/250V electrolytic pairs from computer power supplies were way out of tolerance and I got rid of them.
    I even got rid of two known-brand 400V units which had very little capacitance when measured compared to the capacitor label.
  • RetroComputingGrotto
    Opinions/Advice on Do/Should I replace ALL Electrolytic Capacitors on old equipment?
    by RetroComputingGrotto
    I've just been repairing some (very) old speakers with a loud hum that occurred as soon as you powered them on regardless if any actual audio is played through them. I work in a School so it's 99% likey that the Teachers have hardly ever turned the power off on them for well over 10+ years.
    As you can see the top large capacitor on the right has a bulge on the top so defincately needs replacing. As the one next to it is exactly the same capacity and voltage I planned to replace them both.
    What is your advice/opinion on whether or not on old(er)...
    04-03-2024, 08:30 AM
    Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
    by sam_sam_sam
    I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
    I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
    12-31-2023, 06:04 AM
  • goodpsusearch
    Sony RCD-W3 Deck A (Playback only) not playing CDs (Disk Error) repair
    by goodpsusearch
    Recently I was given for free a Sony RCD-W3 with the following symptoms, CD recorder drive reads CDs without any issues (haven't tested recording function yet because I don't intend to burn CDs on that machine) but the reader drive shows disc error after some seconds of it trying to read CD. Tried both CD-Rs and commercial audio CDs with same results.
    First thing to do was to clean the lens but that didn't change anything. Googling the issue revealed that this is a common issue on several Sony CD recorder machines and the culprit is SMD electrolytic caps located on the PCB bellow...
    05-05-2024, 02:04 PM
  • jorpec
    Changing the scale of an analog meter
    by jorpec
    Hi
    I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
    I wonder how i can accomplish this so the meter would be precise at any temperature ?
    Thnaks
    01-23-2023, 10:37 AM
  • ttmi100x
    HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
    by ttmi100x
    Greetings everyone,
    I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
    The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
    Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
    Upon closer inspection...
    07-31-2024, 06:36 PM
