reballing problems
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: reballing problems
    Direct heat are the small ones that you leave on the chip after you put the balls on, and heat the chip with the stencil still in place.
    Indirect heat are the ones you put in a jig and lift away after you put the balls, then heat the chip to get the balls attached.
    A working TV? How boring!
    • Stanley1843
      BEST 505 Vs Mechanic Brand Reballing Balls with Lead
      by Stanley1843
      has anyone use these Brands of solder balls? The brand BEST writes on the label of the jar the specs of the solder balls instead of the Mechanic brand. I beleive that BEST brand must be more professional (in labeling at least) but I have never try one of them so I would like your opinion. By the way I hardly can I find the Mechanic brand in aliexpress (the only where I found was lead free solder balls) and on ebay these that I found are approximately15USD per jar. If you know any other trusted brand of solder balls please tell me.
      06-22-2024, 11:06 AM
    • dreico33
      Bga Stencil set and base? ,for Vram reballing.
      by dreico33
      Hellow guys,
      I am looking for a good set of stencils and bases(dont kbow exacly the word) for vram exclusive bga reballing.
      Your recomendations are very welcome
      Thank you.
      09-23-2024, 09:00 PM
    • petemanuk
      Z270 PCH Reballing help needed pls
      by petemanuk
      I'm trying to reball a Z270 PCH, i've got the right stencil for the PCH and it's direct heat type.
      I initially tried using 0.3mm solder balls (leaded type) but am having lots of problems with the balls not wetting to the chip, basically some of them just wont solder to the pads.
      I'm making sure the chip is as clean (using ipa) then putting a thin layer flux on then putting in in the holding jig with the stencil on. I'm the heating to about 400degC with minimal airflow (4% on my Atten) but some balls just refuse to stick!!
      I've repeated the above using...
      01-28-2023, 12:19 PM
    • DynaxSC
      Each GPU reballing produces different MATS results, looking for root cause ?
      by DynaxSC
      I have an Nvidia card which makes me wondering, what is the root cause for Mats errors. The story is as follows:
      1. When I received the card Mats showed one memory with errors.
      2. Replaced the memory chip, but no change, still same error, so memory chip is ruled out.
      3. Made a carefull reballing of the GPU, MATS showed 3 memories with errors, the one before, and 2 other new chips.
      4. Made a second reballing of the GPU and Mats shows again only one memory chip with errors, the same on as in the beginning.
      5. Made...
      12-11-2024, 07:44 PM
    • jean luc ferre
      laptop hp g72 b52sf screen problems
      by jean luc ferre
      on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
      the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
      i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
      i don't understand the reasons of the white stripe at the bottom of the screen below the task...
      06-07-2025, 03:27 PM
