Can it be handy on monitor fixing ?
  • 820uF
    • Apr 2012
    • 39
    • Russia
    Hi!
    I was wondering am i right if i say it goes out of range on capacitors above 200uF and therefore becomes useless on power supply repairs ?
    http://i.imgur.com/jhpUp.jpg
  • mariushm
    • May 2011
    • 3799
    Re: Can it be handy on monitor fixing ?
    The capacitance measuring is pretty pointless anyway.
    Capacitors can show you the right capacitance value within +/- 20% yet have a high internal resistance which would affect the circuit.
    You need an ESR meter for capacitors, it would be more useful than simply measuring capacity.
    • retiredcaps
      • Apr 2010
      • 9271
      Originally posted by 820uF
      Hi!
      Many ATX power supplies, motherboards, and lcd monitors/TV will have caps as high as 3300uF. Some multimeters will measure capacitance up to 10,000uF so there is no need for a separate device.
      As mariushm points out, measuring ESR is more important.
      Your fellow countryman, RusMike, makes the ESR 4.0 is also a member here.
      https://www.badcaps.net/forum/member.php?u=12802
      http://www.radiodevices.ru/
      --- begin sig file ---
      --- end sig file ---
