Thinking of getting a clamp ammeter
    I am looking for a clamp ammeter.
    I would like to use it for debugging and profiling power supplies as I have had a few troublesome TVs where it could have been quite useful (can see if PSU is attempting to start up, for example.)
    My ideal device would be:
    - Capable of measuring AC & DC current
    - Capable of up to 20A current (more is good, but I don't tend to use much that much more...)
    - True rms for typical full-wave rectifier input current measurement - good crest factor
    If possible:
    - Output for the current signal from the probe to plug into a scope - I can potentially measure power factor and line noise with this
    - Built in second multimeter could be useful
    This Uni-T looks good, but it doesn't have the scope output (which would be very useful for me): http://www.ebay.co.uk/itm/Brand-New-...ht_1348wt_1189
    I suppose I could get a separate hall probe for my scope but those are pricey plus I would loose the ability to make simple rms current measurements without the big scope with built in rms digital measurement (which stays upstairs mostly...)
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Thinking of getting a clamp ammeter
    I wish I knew more about clamp meters to offer some feedback, but unfortunately I don't.
    PS. I see you added the don't PM me for help in your sig file. That is a good sign of the respect you have earned from others.
    --- begin sig file ---
    --- end sig file ---
      Yes, I get a lot of PMs from help. Mostly people asking about TVs I've never heard about. I do not know everything about TVs!
      • repair-it
        Need advice testing a samsung power supply board with scope
        by repair-it
        I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
        07-12-2025, 11:00 AM
      • caspian
        Can Ammeter damage Power Supply?
        by caspian
        Dear Members,
        My DC linear Lab Power Supply does not display the current and voltage correctly. Thus, I am going to connect an Ammeter/Voltmeter Module to the DC output of the power supply. Then, a load will be connected the takes about 1-5volts with 0.1-1.5Amps.
        But I heard If I connect an Ammeter to the output of the power supply, then the Ammeter module is not isolated from the power supply so that the Ammeter can damage the power supply.
        Is this true?
        I have attached the photo of a sample Ammeter module that I am going to buy....
        06-05-2022, 01:42 AM
      • Sparklingx
        CH341 disconnects, test clamp not working, soldered bios chip but not erasing/writing how I fixed
        by Sparklingx
        So i've bough a ch341 programmer, and the chip was CH341B . the test clamp was not working( when connecting bios using test clamp, ch341 device was disconnecting) I tried soldering the bios on the provided board, soldering the bios I could read the chip but could not write or erase. ASprogrammer , neo, ch341a programmer... all programmer software was hanging and device was disconnecting after few second of erase/write operating.
        So then I have soldered a capacitor(whatever I had..[10v ~470uf ] ) from VCC to GND on my provided pcb where you solder the bios
        now all...
        08-29-2024, 01:53 PM
      • marce002
        UT210e clamp revival eeprom
        by marce002
        Hi
        I was trying to flash the chip in the board with my ch341a programmer, wiring as documented by https://www.youtube.com/watch?v=fX-Fhq9R4uY
        it did not read anything so desoldered the chip from the clamp and put into my programmer board and also not reading real data, it only brings emptyness...
        maybe i ruined the memory? turning the clamwith no chip shows Error and a beep wich is correct.
        put chip back to the clamp, and shows some random numbers like calibrating and offers a 0.000 DC display and nothing else can be selected...
        10-05-2023, 01:28 PM
      • EasyGoing1
        Reading input and output of bridge rectifier on the same scope?
        by EasyGoing1
        I have a 40 volt AC transformer that I put a bridge rectifier on, and I wanted to see the input signal and the output signal on the same screen on my scope, so I set one channel up with the test lead on one side of the input and the ground lead on the other side of the input, then I used another channel on the scope and clipped the test lead on the positive side of the output then the ground on the negative side of the output.
        When I connected the transformer to power, the wire that was connected between the ground lead on the second channel and the negative side of the bridge rectifier...
        06-26-2022, 12:52 AM
