Just got an Atlas Peak 70 and i have a few ??
  • Mr Bill
    • Nov 2011
    • 648
    I just want to make sure i'm reading the meter correctly. Most of the caps that have in my box of used caps have an esr reading under 1 omh. But a few of the smaller ones (less than 100uf) have reading in the 2-3 range.
    Whats the "rule of thumb" for a low esr cap to be bad? The manual that comes with the meter has a "rough" chart but these readings seem WAY up there.
  • severach
    • Aug 2007
    • 1055
    Re: Just got an Atlas Peak 70 and i have a few ??
    ESR is often listed in datasheets. Low ESR caps should be lower than the chart. GP caps should be above it.
    sig files are for morons
    • SuperAman
      PS5 HDMI port diode reading?
      by SuperAman
      I did an hdmi port repair for a PS5 and I lost the small diode z71 SOD923 on the back of the port. I did a trace repair for pin 19 of the port as well. Without the diode I get no display at all. I tried replacing the diode twice but after I get flux on it the marking comes off so I can't tell if I have it on the right orientation. When I measure I get a reading of 1(open) and 923 in diode mode. Is 923 a normal reading for these and also which side should the reading be with regards to the arrow on the board?...
      02-03-2024, 10:16 PM
    • Fuzzy Fix
      0.00 ESR reading on a capacitor
      by Fuzzy Fix
      Howdy all I have a 90uF Capacitor 200/275 VRMS and measured the ESR . Reading says 00.3 Ohms and about 1/2 a second later 00,0 and says low ESR (Really No Kidding).
      I have checked it on the multimeter and reading is 94.7uF well within soec as ir has a 25% tolerance on it.
      Can anyone advise me is this capacitor likely to fail in the near future or still good to use.
      07-26-2024, 12:05 AM
    • kalilinux25
      no 3v and 5v section voltage reading
      by kalilinux25
      Hi my board is HUSK MB 11309-248.4TU05.021
      The board is plugg and consuming 13 milliamp
      measuring the 3v coil no reading and the 5v coil no reading
      Ive measure the pins in PU4103 ( RT8223M)
      1- NO READING
      2- NO READING
      3- 4.4V
      4-NO READING
      5- NO RADING
      6- NO RADING
      7-3.3V
      8- 5V
      9-19V
      10- NO RADING
      11-3.3V
      12- 3V
      13-
      14
      15
      16-4.4V
      17-3.3V
      18- NO READ
      19-5V
      20- NO READING
      21-2V
      22-2V
      23-NO READING
      24- 5V
      01-27-2020, 03:01 AM
    • Stephan Mathers
      EDMI ATLAS MK10 Electronic Meter Discussion
      by Stephan Mathers
      Greetings, new guy here but always interested in the crazy universe of modding
      We just finished construction of around 25 vacation houses, all inside the same private area.
      Each house has 3phase power , and we bought an atlas MK10 meter for each house (25 meters total ! )
      The metering on a per-house basis is done privately. Its not done by a utility company. The utility company will only charge us for the total consumption of all 25 houses together.
      Id like to do a small modification on the firmware of our MK10 to make it easier identify each house's...
      05-20-2025, 09:09 AM
    • lapfix
      Dell latitude 5320 South peak 13 not power on.
      by lapfix
      Hello friends
      Got this laptop dell 5320 not power on , just a fast and a dim blink amber light at the power on led indicator.
      motherboard south peak 13 mb 213252-1
      i'm using schema and Bvd similair to this motherboard. https://www.badcaps.net/forum/troubl...-latitude-5320
      i don't have a type-c meter for the moment , so i m taking the voltage using his original charger.
      As i undestand from many topic here ,...
      04-29-2025, 06:22 AM
