Analog ESR meter design
  • marcdima
    • Oct 2012
    • 10
    • Morocco
    #81
    Re: Analog ESR meter design
    Originally posted by vhr
    all things are clear now thank you very much
    • vhr
      • Aug 2012
      • 21
      • Russia
      #82
      marcdima
      • vhr
        • Aug 2012
        • 21
        • Russia
        #83
        ESR/L/C/F/P/t meter
        http://www.youtube.com/watch?v=a-mXYYr3KjY
        • mariushm
          • May 2011
          • 3799
          #84
          ^ i think this is the meter :
          http://pro-radio.ru/measure/10248/
          The links in the text point to an older and similar through hole version with source code and everything available.
          • youpla
            PowerColor rx 5700xt dual fan : current sense resistor
            by youpla
            I’m repairing a PowerColor RX 5700 XT Dual Fan (not the Red Devil or Red Dragon model) with a burnt pin 5 on its 6-pin PCIe connector.
            The previous owner had it repaired by a shop. They soldered an enameled wire to reconnect pin 5 to the current sense resistor (shunt).
            The card wasn’t displaying anything after this fix.
            When I inspected their work, I found that the sense resistor had fallen off after reheating the solder joint (likely due to damaged pads from resistor).
            I tried to resolder it with a hot air station, but the resistor wouldn’t...
            12-01-2025, 07:52 AM
          • eccerr0r
            lowest current galvanometer/analog meter (passively powered!)
            by eccerr0r
            Most analog meters are actually current driven - a current is needed to deflect the pointer full scale. They can be lots of different values. There are ones that can take several amperes to swing the pointer as they have internal shunts.
            On the other hand there are many that are rated in microamps for the intent that they draw as little power as possible from the devices under test. Some are 1mA, 500µA, 200µA, 100µA, and the ubiquitous 50µA frequently used in analog VOMs. There are even 20, 25, 30 µA and even down to 10µA. Been collecting a bunch of different ratings and...
            04-16-2025, 12:41 AM
          • jorpec
            Changing the scale of an analog meter
            by jorpec
            Hi
            I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
            I wonder how i can accomplish this so the meter would be precise at any temperature ?
            Thnaks
            01-23-2023, 10:37 AM
          • jinu_j
            by jinu_j
            Hi
            05-03-2025, 10:51 PM
          • Darren Hibbert
            Replacing a Current Sense Resistor
            by Darren Hibbert
            Hi.
            Quick question.
            I have a laptop that is completely dead. I opened it up and it looks like the current sense resistor is blown. However, because it's blown, the value printed on the top has disintegrated and there is no schematic available for this particular laptop (Dynabook Portege) so I'm not sure what to replace it with.
            04-08-2024, 08:36 PM
