Induction soldering
  • japlytic
    • Oct 2005
    • 2086
    Induction soldering
    Have you read about induction soldering stations, such as the Thermaltronics TMT-9000S?
    An article about this station shows the larger tips are excellent on large ground traces, and that a conventional soldering station would burn up the flux too quickly, leading to a dry joint.
  • Agent24
    I see dead caps
    • Oct 2007
    • 4950
    • New Zealand
    Re: Induction soldering
    That one is a ripoff of the Metcal MX-5000, apparently.
    Specifications show it has about half the wattage of the Metcal.
    When you say 'article' do you mean this? http://forums.overclockers.com.au/sh...d.php?t=971697
    Would love to see a 'proper' review if there is one.
    -David VanHorn
    • CTMS
      • Dec 2011
      Here is another review for this system
      http://www.eevblog.com/forum/index.php?topic=6318.0
      • Agent24
        I see dead caps
        • Oct 2007
        • 4950
        • New Zealand
        Not bad, better photos, would prefer a video though, but that station does sound pretty good.
        -David VanHorn
          07-01-2024, 06:34 AM
        • chth96
          What soldering station should I purchase for 900M-TJ-I tip?
          by chth96
          hello.
          A few months ago,I have purchased 0.1mm Soldering Iron Tip of below aliexpress link,But I noticed that It is totally impossible to use this 0.1mm iron tip in the T12 soldering station
          https://ko.aliexpress.com/item/4001275635593.html
          Is there any good soldering station which is possible to use 900M-TJ-I tip and have inexpensive or reasonable price in aliexpress?
          Any reply would be appreciated.
          11-24-2023, 05:08 PM
        • caprider
          Recommendations of quality soldering station and (separate) hot air station
          by caprider
          Hey,
          I'm looking for some recommendations of a decent quality soldering station and a separate hot air station. I'm just a hobbyist, so even if (ultra)premium tools are not required, I still want some good tools. They should be available in Europe.
          I now have a TS100 and some soldering irons and looking for some better tools.
          1. Soldering station, budget around 200-240€
          JBC BT-2BWA seems to be a good product in the budget.
          2. Hot air station, budget around 200€
          Up to now I've found ATTEN ST-862D to be a good option....
          01-15-2022, 02:05 AM
        • mkbehbeh
          KSGER C245 Soldering station PSU 220V only?
          by mkbehbeh
          I purchased this soldering station when it was on sale at amazon. It had a slew of one star reviews, but the price was low enough that even if the controller and PSU were toast, the handle tips and stand were worth more than the price. All of the reviews mentioned that the unit was either DOA, or died on the first use. I looked on Aliexpress and the first clue was that KSGER still sold the 220V version of this station, but all of the 110V versions had been discontinued. I figured That there was a problem with the 110V on the power suppply and the controller would be fine.
          I am...
          04-17-2023, 03:11 PM
        • Peter_1402
          Yihua 992DA+ Hot air gun and soldering rework station, burnt mark
          by Peter_1402
          Hi Everyone,
          I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
          1. Soldering iron works great
          2. There is a burnt mark on the hot air gun handle.
          I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
          Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
          Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
          Reed switch tested ok with a magnet.
          From the above test, I can conclude...
          07-12-2025, 11:50 AM
