Solder sucker a must?
  • Nick
    • Feb 2004
    • 10
    I was wondering if a "solder sucker" is a must for recapping? I know how much it sucks to unsolder stuff without one, but I have never unsoldered components from multi-layer PCBs and don't really know how much more difficult/risky it could be to recap a mobo without a solder sucker (or whatever they are called).
    Could I get away without one without popping the metal sleeves out of the PCB's holes?
    Thanks!
    Nick
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Honestly, I NEVER use a solder sucker! They can destroy your board. If the duct or'sleeve' is removed from the PCB, it's instant death to your board. A solder sucker can pull them right out and/or damage the foil traces around them.
    To clean the holes I use a small metal pick. A stainless steel dentists pick is ideal. heat the hole and remove the old cap. Then once the old cap is gone, reheat the hole and while the iron is still on it, poke the pick through. Remove the iron and let the solder harden, and that's it! You'll have a nice open hole, and most importantly, no damage to the board.
    The first few times you try this, it will feel alkward, but I can do this method faster than most can cock a manual solder sucker. I've NEVER damaged a board this way either.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • Nick
      • Feb 2004
      • 10
      Heh, thanks, I was already thinking about getting a solder sucker because I thought it was the "recommended" way to do it.
      Nick
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        i preheat the mobo with a heatgun and use a vacuum desoldering station.
        the preheating helps you work faster as the thick ground planes wont cool the iron as fast as they are already warm(250-300f)
        you can also carefully heat both pins of the cap with a wide tip and pull the cap when the solder melts.wait till it is ready to drop out.you can use solderwick to clear the holes if you have a good hot iron.
        as for the soldapult type sucker they dump crumbs on the board and are not good on smt boards with fine pitch devices.never seen a thruhole pulled out with one though.the pick method sounds good but i have not tried it.
        been spoiled with all the fancy stuff on my bench i guess
        • stretch0069
          Screwed Up Super Moderator
          • Oct 2003
          • 2658
          • oooo ess aaaaaaaaa
          Yeah...I have used a solda-pult on old military boards. Even used it on a VP6. Got my hands on a good Hakko desoldering iron. Now I need to get new tips. I also have a separate Weller soldering station.
          Hmmm...never tried that dental pick trick.
          "Its all about the boom....."
          Guns kill people like spoons made Rosie O'Donnell fat.
          We now return you to your regularly scheduled drinking.
          "Fear accompanies the possibility of death.....calm shepherds its certainty"
          Originally posted by Topcat
          AWD is just training wheels for RWD.
          • juski
            • Mar 2004
            I prepared my Abit Kt7 board for re-capping this afternoon.
            The removal of the caps was very easy, as was cleaning the holes.
            This technique works very well for me in all multi-layer through-hole rework:
            Apply fresh solder to the hole to be cleaned.
            Then, place some solder wick over the hole and heat with a soldering iron. When the solder melts it should be drawn up onto the solder wick, making the hole clear. It is important to use a wick which contains no-clean flux.
            A solder sucker CAN be used if you are experienced enough. The 'recoil' when you release the plunger can cause the soldering iron to scoot across the board, causing scratches and possibly pad & track damage!
            The best way to use a sucker is to heat the solder to be sucked for a good few seconds, with the sucker primed and ready. Quickly withdraw the soldering iron BEFORE pressing the button on the sucker. This tecnique is not easily mastered so I recommend the solder wick method for newbies.
            BTW with care it is even possible to replace thru-hole components without cleaning both holes! The comparitively heavy weight of copper on power planes makes them conduct heat away from the pad very quickly, which is why they are so hard to de-solder. So, if you only manage to clean one hole of a cap placement, align the lead of the new component to the top of the board and heat it from below. When the solder melts, gently push the component through. You should eventually find you can mount the new cap flush to the PCB. Then simply solder the other lead and crop the excess.
            There is more than one way to skin a cat
            • juski
              • Mar 2004
              I wouldn't advise inexperienced board reworkers to use the pick method - it would be very easy to damage the PTH barrel of the PCB this way.
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16958
                juski,
                First off, welcome to the boards!!
                I wouldn't advise any extremely inexperienced person to try this at all.... HEH... I've used the pick method on well over 200+ boards, haven't killed one, or even damaged one in any way. I've tried the solder wick, and it works fine, but takes too long. I'm impatient... The pick takes literally less than a second to clear a hole, where the wick takes longer and is more tedious and clumsy... Through trial and error, we each develop our own likes and dislikes....
                As mentioned above, a manual solder sucker isn't even a viable tool to use on multi-layer boards, they do more harm than good... If one has the means for a professional vacuum/compressor powered solder sucker, those do work very well. There is no recoil, and they don't blow solder boogers all over the place.... However, most people attempting to try this can't afford such a piece of hardware... If they could, they'd probably spend their cash on a new board, rather than recap their existing.
                Team : 49813
                Join in!!
                Team Stats
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  whatever method you use if you do it with care you should have no problems.
                  if this is your first try at pcb rework practice on a scrap board you dont care about.
                  or send it to me or topcat for repair.
                  • corrize
                    Best way to solder LVDS connector for beginner (and qfn) ?
                    by corrize
                    Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
                    I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
                    I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
                    See the test :
                    https://youtu.be/bNAzC-EvqHs?t=1767
                    With hot air from bellow the board, that's...
                    03-09-2023, 02:57 AM
                  • petemanuk
                    BGA solder balls not connecting - help pls
                    by petemanuk
                    So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
                    I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
                    I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
                    11-16-2022, 05:21 AM
                  • myth77
                    UV solder mask - high temp resistent, recomendation?
                    by myth77
                    Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
                    Is there any solder mask...
                    03-28-2022, 04:04 AM
                  • acedogblast
                    by acedogblast
                    11-02-2024, 05:13 PM
                  • sircastor
                    Solder not reflowing - what am I doing wrong?
                    by sircastor
                    I'm trying to fix a broken MacBook Air, and got a parts board to salvage components from. Following the suggestions of many folks here, I wanted to get in a little practice of using my hot air station (A Quick 957DW+) on the parts board so I know what kind of behavior to expect.
                    For the life of me, I can't get anything done with this thing. I have tried multiple temperatures (from 210-425c), different air speeds, preheating the board (with the hot air, just warming it all around). I have applied what feels like excessive amounts of flux (Amtech V2-TF-559) and the solder on these components...
                    03-03-2024, 02:44 AM
