recommend ESR meter, Multimeter, hot air rework station
  • Bob Parker
    replied
    Re: recommend ESR meter, Multimeter, hot air rework station
    Originally posted by DDRAMbo
    Why would you spend $100 for a 'Blue' ESR meter which only displays a 99-digit estimate of the ESR of electrolytic caps...
    "Thank you". I put 3 months of my life into designing that ESR meter for my own use and it only went public when we realised its value in electronic repair situations. The reason it's well known is because people have told each other that it does the job, not because of aggressive marketing.
    If you believe that it merely "estimates" ESR values and is overpriced, it shows how much electronic knowledge you've got.
  • Agent24
    replied
    I apologise for calling you out as a spammer, I guess you are not.
    It's just when I see someone with a low post count who writes a post that looks like advertising along with strange\funny errors it just really does look like spam.
    As for Dave Jones, remember he is a designer, not a repairman.
  • DDRAMbo
    replied
    Excuse me, I was exhausted last night, and I should have said... '100 count' and '20,000 count'.
    I have the Aktakom AMM-3035, the 'Blue' meter (purchased first) and three high quality DMM's, two of which read capacitance, but all three read frequency and resistance. I've been comparing readings with each to assess accuracy. At this point I have only discussed my tentative conclusions with a friend with a degree in EE, so I'm open to other interpretations. If I'm correct, there's a cloud of confusion and distortion surrounding these ESR meters, not only due to the usual 'higher power' of advertising influence and sales integrity -- the 'profit' motive, but also a lack of concern or awareness by folks like Dave Jones of EEVBlog popularity. But, that's another thread.
  • Agent24
    replied
    Why would you spend $100 for a 'Blue' ESR meter which only displays a 99-digit estimate of the ESR of electrolytic caps, when you could spend $160 for a professional quality, 20,000 digit, dual display LCR meter that measures capacitance from 20pF to 20mF (within 2.5%) using 5 different frequency signals (100, 120, 1k, 10k and 100kHz) along with the D (dissipation factor)/Q (quality factor)/phase angle and ESR, in addition to L (20uH - 2000H) and R (20 Ohm - 2,000MOhm), the Aktakom AMM-3035 from www.tmatlantic.com, which includes $100 worth of meter leads?
    Clearly you're a spammer, but this is funny, I just had to respond.
    You apparently sell an ESR meter which has a 20,000 digit display? Twenty-Thousand Digits? TWENTY THOUSAND???
    Is this kind of accuracy even physically possible?
    Also, how many workbenches, nay, workshops, do I have to buy to be able to fit this glorious ESR meter in?
  • DDRAMbo
    replied
  • indomitus
    replied
    Originally posted by mariushm
    Otherwise, I found out the ESR Micro does display a bit higher capacity values up to about 470uF. Over that, it gets pretty accurate when measuring capacity.
    I mean, on a 330uF it shows 350uF while my multimeter says 337-340uF. Same with 10uF capacitors, it read 12-14 uF.. not a fault, it's how it measures the capacity imho.
    But that's just with my Uni-T UT61E, which has a 5% margin of error in the first place.
    Im just thinking is the ESRmicro measure so much more with low value caps. maybe the ESRmicro also measure ESR to high with low value electrolytic caps???
  • indomitus
    replied
    Yes the ESRmirco is calibratet before use.
  • mariushm
    replied
    Originally posted by indomitus
    Another thing that make me think that these caps is way out of spec. is that i use a ESRmicro 4.0 and the ERS readings is way to high, but again the capacitance is within spec.
    Another thing is, i think the ESRmicro 4.0 it is not precise enough to measure such low values.
    If i measure a new 10uF and a 6.8 uF cap. the readings is:
    ESRmicro 4.0 measure: 12uF - 0.61 ESR
    Amprobe 37XR-A measure: 9.93uF - ? ESR
    ESRmicro 4.0 measure: 7.36 uF - 0.93 ESR
    Amprobe 37XR-A measure: 6.43 uF - ? ESR
    Did you calibrate your ESR Micro before measuring?
    If you use the leads and you previously used the socket, you need to recalibrate it.
  • Bob Parker
    replied
    The last time I looked, the tolerance of normal electrolytic capacitors was -50% to +100%. They are made for bulk capacitance in a small volume where the exact value is not important (e.g. signal coupling, power supply filtering), not for precision (e.g. timing circuits).
    Now I have to continue my packing.
  • indomitus
    replied
    Originally posted by Bob Parker
    If you really want to test them, measure their capacitance with a DMM etc. If you get a crazy reading, see if they're shorted.
    I use my DMM and i measure fine with most of the caps, and i just cant believe that all these caps. is good.
  • Bob Parker
    replied
    Yes i know The Blue dont measure capacitance, i use my DDM for that.
    Your spot on, its not a electrolytic i need to test, its PIO and Mylar cap.
    I have alot of old PIO and Mylar caps. i want to test.
    Happy packing Bob
    Any recommendation for equipment to testing these old caps.
    Thanks.
    Sorting through everything in an old family home, finding new homes for stuff I don't need and packing up what I need to take with me has been an experience I wouldn't wish on anyone.
    But getting back to electronics... non-electrolytic caps aren't known for regularly failing or needing to be tested. I've never heard of their characteristics changing while they're in storage. When they fail, often they go short-circuited and sometimes open circuit (I've seen SMD ceramic caps do that if they're mechanically stressed). But usually they just keep working unless they get hit with excessive voltage or are physically damaged.
  • indomitus
    replied
    Originally posted by Agent24
    Note that the Blue meter does not measure capacitance, it measures ESR.
    It shouldn't be an issue to test them but 0.02uF is pretty low, seems unlikely to be an electrolytic capacitor and if it's not an electrolytic capacitor I don't know if there's any reason to test the ESR.
    No. The Blue meter was designed to test electrolytic capacitors of about 1uF and above. There aren't many with values below 1uF.
    The whole reason for measuring ESR is because only electrolytic capacitors have a big problem with increasing ESR causing faults. They don't make electrolytic caps with values as low as 0.02uF.
    I hope this has clarified things a teensy bit. Now I'll go back to packing for my big house move.
    Happy packing Bob
    Thanks.
  • Bob Parker
    replied
    Can you test 0.02uF caps with the Blue meter?
  • Agent24
    replied
  • indomitus
    replied
  • KeriJane
    replied
    Another vote for Blue!
    Even I managed to build it and quickly too.
    Building it yourself is great because you're on an up close and personal relationship with it. If something goes wrong, you'll have a far better idea where to start.
    Mine's been great since day 1.
    Flukes are great meters. There's a lot of perfectly good also-rans though.
  • Bob Parker
    replied
    Originally posted by jgmanza
    Very good meter, this ESR Meter. I recommend highly.
    Thank you!
  • jgmanza
    replied
  • Agent24
    replied
    Bob's Blue ESR meter is probably as cheap as you're going to get while still retaining quality (In fact it's probably better value\quality than some that cost more)
    It's also fun to build and since schematics\spares are available repairs are easy.
    If you can't justify even that price, there are many schematics on the internet for even more basic (and not so basic) ESR meters you can make from scratch.
  • MrVik
    replied
    The "Blue ESR Meter" by Bob Parker has a website, http://members.ozemail.com.au/~bobpar/esrhints.htm, with hints for reducing battery usage. Also, how to use an outside power supply to power the unit. Several other hints as well. This meter is well discussed in this forum.
  • shahnld
    wds-580 rework station issue
    by shahnld
    Good day.
    i received used bga rework station wds-580 which was not going above 300c despite the parameter was set to 350c, Everytime beeps at 300c so i did a factory reset and by mistake washed data and log etc. now the station boots to a white screen.
    Does anyone has a firmware for this station and want to share with me. i will really appreciate any help possible..
    kind regards...
    03-28-2024, 01:14 PM
  • minimania
    Need Schematic for jbc am6800 rework station
    by minimania
    hi all im looking for a Schematic for jbc am6800 rework station
    mine has stopped working fully
    it started with turning off when switched on then after a few off and ons it worked sort of for awhile
    now it wont turn on at all...
    01-28-2025, 03:44 PM
  • shahnld
    Seamark ZM-R6200 Rework station
    by shahnld
    Good day Experts.
    I have recently aquired a rework station SEAMARK ZM-R6800,. Is there anyone using this or some other similar station and give me some info about profile temp curve etc for removing leadfree soldered gpu chip..? just 1 profile will be enough to get started.
    Kind regards
    01-24-2024, 10:55 AM
  • petemanuk
    Help with IR6500 rework station
    by petemanuk
    I been playing with a recently acquired IR6500 rework station and watching lots of YouTube tutorials to see how to use it with not much success. I’ve only recently joined badcaps but going through the forums there is a lot of knowledge here, so though it best is if I ask my question here.
    1. Firstly is the IR6500 any good for BGA rework or should I be spending my money on a better one.
    2. The instruction manual is pretty useless on explaining how to set the PID loops (no information at all!!) both top and bottom heater for th Kp, Ki and Kd...
    10-14-2022, 12:31 AM
  • aaronkatrini
    by aaronkatrini
    - Autorange
    - DC volts up to 30V
    - Accurate Resistance
    - Diode test (Beep mode)
    - Frequency up to 200MHz
    - Capacitanze up to 5000uF
    - as cheap as possible
    05-06-2024, 09:54 AM
