Ok guys I'm still new to the soldering thing and dknt know what solder I should use. I have two types on hand rosin and zinc chloride inorganic flux. I was told by someone that zinc chloride flux is too strong for general electronics and could eat through copper traces over time but that is more effective at removing oxides then the rosin. Could anyone point me in the right direction??
Question about flux
Re: Question about flux
Read this:
https://cdn.badcaps-static.com/pdfs/...21d3b7fd1e.pdf
http://www.ehow.com/list_6361756_typ...ng-fluxes.html
It's not comprehensive but it's good enough.
Basically, there's several types of flux, some attack the surface in time so after soldering you need to take it off using cleaning solution ( i think a simple solution is a mix of isopropylic alcohol and acetone), there's some flux types that are somewhere in the middle and then there's other flux combinations called no-clean or water soluble..
Quality solder wire has flux in the middle of it so in this case you shouldn't have to add flux separately.
I don't know what to tell you about zinc chloride flux...
You can see here various types of flux solutions - if you wish, click on the items and you have the datasheets there - they may explain more about the composition and its effects.
http://uk.farnell.com/jsp/search/bro...atchallpartial
And here's for example a quality solder wire with non-corrosive flux inside it (read the datasheet if you wish) : http://uk.farnell.com/multicore-sold...250g/dp/419552
And when you have time, i recommend watching these:
http://www.youtube.com/watch?v=J5Sb2...ayer_embedded#! (at about 10:00 in, it explains about solder wire and flux)
http://www.youtube.com/watch?v=fYz5n...layer_embedded
http://www.youtube.com/watch?v=b9FC9...layer_embedded -
Zinc chloride flux doesn't sound like anything I've ever used on electronics. Is it an acid type? you're not supposed to use those. They're more for general metalwork and plumbing etc."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
-David VanHornComment
After working on printed circuit boards for over 30 years, I finally settled on "Ersin Multicore, SavBit" solder. No extra flux is required and the solder contains copper, so it has an affinity to copper clad boards and copper wires, and also prevents the erosion of your soldering iron bit, as so many other solders will do. I'll not use anything else.
Just one old tech's opinion.
Experience is truly the best teacher.
Backup! Backup! Backup! Ghost Rocks!Comment
Zinc chloride flux is an acid type.Mann-Made Global Warming.
- Dr Seuss
Acid flux works wonders if you're trying to desolder something that's near a grounding plane, but be careful, it can eat the laminate.
It's also great if you want to use a low-wattage iron to desolder lead-free solder.
You can use it in electronics, just make sure to wipe it thoroughly with acetone afterwards.Comment
Just one old tech's opinion."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
Soldering small SMT components without flux is a really bad idea - I know because I've tried that before. It's not impossible, but it's very frustrating, especially when trying to solder those tiny SMT ceramic caps.
The stuff I use for soldering SMT components is no-clean flux from MG Chemicals. It works great. In fact, I like it so much that sometimes I use it on regular through-hole projects as well. The solder joints always end up looking right (nice and shiny too), even though I use lead-free solder.Comment
Actually it's not acid based, on the label it clearly reads "Does not contain acid"
It's an inorganic heavy mtealbased flux. Although it does not contain acids it is still corrosive. I used it and it did a good job. And alcohol seems to remove the residue without problems.
Last edited by Koda; 09-16-2011, 04:05 AM.Guns don't solve problems. I'll take 12Comment
You've been lied to.
Your second clue was that it's corrosive.
The first was in post 5.
Zinc Chloride + Water => Hydrochloric Acid + Zinc Hydroxide.
http://www.superiorflux.com/sold_soft.html
That alcohol you use has water in it.
You are making Hydrochloric Acid on your PCB when you clean it.
Use Rosin Core for anything electrical.
.Last edited by PCBONEZ; 09-16-2011, 06:55 AM.Mann-Made Global Warming.
- Dr Seuss
Kester 44 is a rosin based multicore solder. It is clearly stated in the datasheet that the flux residue is non corrosive and non conductive and can be left on the PCB. I'd say this applies to most rosin based solder fluxes.
I clean my joints occasionally with a can of flux remover and a nylon brush just for looks not because I have to.
Stay away from water based (no clean) fluxes. Don't bother with them I once got a reel of no clean flux by accident and the joints were horrible. The joints were so dull looking I thought I was working with lead free.
If your solder is not for electronics use just buy a new reel it's not that expensive. If whatever you're repairing is worth fixing do it right with the proper flux.Last edited by Krankshaft; 09-16-2011, 08:05 AM.Elements of the past and the future combining to make something not quite as good as either.Comment
i recently bought a block of solid rosin flux from aliexpress. i intend to use it for reflowing cold solder joints and cracked solder joints. but im not sure how im supposed to be using it? do i just break off bits and pieces of it with a knife and put the bits of solid rosin on the bad joint im soldering then bring on the iron?
i tried asking google and they pointed me to a headphone forum and eevblog? and they said to just dip the soldering iron tip into the solid block. a small piece of flux will be attached to the soldering iron tip end and im supposed to use that to reflow... -
by chth96I want to purchase any good flux remover But "chemistronic flux off es835b" is the most common flux remover in my nation..
Is it good to use chemistronic flux off es835b for flux remover?
Or I have to purchase "3m novec flux remover" which is quite expensive in my nation? -
REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
- No Clean Formulations
- Low residue
- Range of activity to deal with different component solderability
- Halide free
- Suitable for dispensing
- Compatible with solder coatings and/or No Clean flux cored solder wire product range
Both products are supplied in syringes or cartridges for application by dispensing....-
Channel: Common Parts Library - Datasheets
10-07-2024, 06:02 AM -
by evilkittyNow that my de-soldering gun is working i was able to remove this panel i made about a week before i noticed a issue the F segment of digits 2 and 3 would go out, digit 2 would go before digit 3, but would come back after the humidity got down from running the ac (note the weather outside is 30.5 / 74%; panel data is from a BME280)
Temp is on the left humidity is on the right
i noticed when the humidity got up one or 2 of the center digits on the right panel would loose a segment
The pin out looking down from the top is (note this is common cathode)...-
by chth96I have tried to bridging tiny broken trace which is shown in the below link,and I found that it is impossible to remove any flux after soldering task.
Is it possible bridging tiny broken trace - Badcaps - Capacitor Search Engine
Because the 0.02 mm copper wire is very very fragile,So It broke itself very easily whenever I tried to rub excess flux with cotton bud.
Is there any way to remove flux with the smallest rubbing or without any rubbing?
Any reply would be appreciated. - Loading...
