Hot air rework station to reflow a BGA chip
  • brethin
    • Dec 2008
    • 1907
    Will a Hot air rework station work to reflow a BGA chip?
    I have a laptop motherboard that needs the southbridge chip reflowed. I can not deside if I should just buy a new motherboard for $50. Buy a hot air rework station for $100 and try and reflow it myself.
    I cant see paying $100+ for a reball/reflow when I can get a new board for $50. And I cant see paying $50 for a reflow when I can get a new board for $50. But maybe paying $100 for the hot air rework station and fixing the board I have. Then maybe I could pay off the station doing a few more reflows?
    Looking for suggestions please.
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: Hot air rework station to reflow a BGA chip
    Yes, it works. Use a lot of flux and you'll be fine. In fact the only trick for a lasting reflow is that you'll need a special tip for your hot air station to make the flux go under the chip.
    A working TV? How boring!
    • brethin
      • Dec 2008
      • 1907
      Ok maybe this is a dumb question but how do i get the flux under the chip. Should I heat it untill I can remove it with the suction arm then add flux and place it back on the board? Or is there flux I can somehow get under the chip before I heat it so I dont have to move the chip and risk it being moved and not making proper contact.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        That's the point. You can buy a special angled tip that you use to get the flux under the chip.
        • brethin
          • Dec 2008
          • 1907
          Ok so I never have to move the chip just add flux around the edges and use the proper tip on the hot air gun? What type of flux should I use?
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            Obviously the "no clean" type because it's gonna STAY in there.
            • Toasty
              • Jul 2007
              • 4171
              There's a seller on eBay that has liquid flux from Kester. Sells it in 1.25 ounce bottles with buy 2 get one free deal. Fast ship.
              It's Kester type 951 and is crystal clear and like alcohol in its flow characteristics. The solvent flashes off and leaves the flux in place. Just tip the board and let it flow under the chip, then do the same to the next side. It should run out the adjacent side both times.
              http://cgi.ebay.com/ws/eBayISAPI.dll...m=130498007259
              seller: joelouis2600
              veritas odium parit
              • ecking767
                • Oct 2009
                • 492
                That depend on the size of the BGA chip. I will say no to using a Hot air station on a BGA CHIP that size. you will most likely damage the board or the BGA chip in the process. Assuming you buy a strong enough Hot air station
                • brethin
                  • Dec 2008
                  • 1907
                  I thought the idea behind reflow was not to remove the chip but just reflow the solder. Reballing would require removing the chip but that requires much more than a hotair rework station. The chip isnt that big and there are nozzles that are the proper size, I think its a safe bet to give it a try.
                  • Joun
                    • Jul 2011
                    • 191
                    • Greece
                    Just have in mind that a hot air station might not be enough..You will need a preheater to heat the board from the bottom,so when you apply heat to the chip with the hot air station it is much easier to melt the solder(with enough solder flux of course)..
                    The flux Toasty linked is very low quality it probably will not do the job..The right flux for the job is in a gel like form,not liquid..
                    It also is much more expensive than $3 .. Just a result I found on Google: http://www.mgchemicals.com/products/8341.html
                    In my opinion don't try it just for one board..
                    • DynaxSC
                      ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                      by DynaxSC
                      Hi
                      I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                      08-04-2025, 12:20 PM
                    • acedogblast
                      by acedogblast
                      11-02-2024, 05:13 PM
                      Common SPI bios chip programming Questions and Answers
                      by SMDFlea
                      Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
                      A: If you can`t read from it how do you expect to write to it ?.
                      Q: Why is my bios chip unreadable ?.
                      A: The programmer is faulty or has a worn or broken zif socket.
                      The USB cable is frayed,connector pins worn or some other physical damage.
                      Not enough amperage or voltage to power the programmer properly.
                      Bad...
                      09-02-2021, 04:40 PM
                    • BMCappelletti
                      Asus Chromebox CN62 - wrong chip put on BIOS reader
                      by BMCappelletti
                      Long story short:
                      - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                      - gave the computer to his son a couple years later
                      - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                      - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                      (seems like the story was not that short)
                      He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                      01-08-2025, 07:27 PM
                    • shahnld
                      wds-580 rework station issue
                      by shahnld
                      Good day.
                      i received used bga rework station wds-580 which was not going above 300c despite the parameter was set to 350c, Everytime beeps at 300c so i did a factory reset and by mistake washed data and log etc. now the station boots to a white screen.
                      Does anyone has a firmware for this station and want to share with me. i will really appreciate any help possible..
                      kind regards...
                      03-28-2024, 01:14 PM
