AC power circuit tracing
  • PlainBill
    • Feb 2009
    • 7034
    I'm sure many people have had the problem of figuring out which circuit breaker supplies an outlet or light switch. When a home is new the breaker panel may be well labeled; after a few years that may no longer be true. After a few decades, it's almost certain not to be true.
    Of course, you can always turn off circuit breakers until the outlet / light in question goes dead. That usually results in resetting clocks, a lot of trips back and forth, etc. Necessity forced me to discover how to use a common piece of test equipment to make the process much easier.
    The long story is Sunday afternoon I was using a power saw in the garage when suddenly the light went out and the saw stopped. "Darn, I tripped the breaker" (or something more pungent) was my first thought. Go out to the breaker box, no circuit breaker has been tripped. Not good, definitely not good. A few years ago I upgraded the wiring in the garage, maybe one of those junctions is bad? Definitely not good, the junction point is up on the ceiling.
    On my way through the kitchen I discover the utility room, kitchen and dining room lights are not working either. OK, that moves the likely problem area back to the kitchen, which was remodeled nearly 8 years ago. As part of this remodel some wiring was torn out, and the kitchen lighting and outlets completely rewired. New circuits were run for the outlets, but the kitchen lights tapped into the old circuit. Clearly, the garage is on the same circuit. Now, where did I tie the new to the old??? After a quick phone call, I discover my son won't let me use his Tone 'n Probe. It looks like I'll have to do this the hard way.
    After removing half a dozen cover plates and outlets I locate the box that has both old and new wiring. And sure enough, one of the wires has escaped a wire nut. Removing the wire nut and gingerly trying to group the wires together isn't working. Eventually I get the dining room and kitchen lights working, but the wire to the garage won't cooperate.
    Well, now I can at least start flipping off breakers until the dining room lights go out. There are only about a dozen candidates (UGH!!!). Then inspiration strikes. I've got a clamp on ammeter. And if I pull the covers off the breaker box, I can reach the individual wires to each circuit breaker.
    So I induce my wire to sit at the light switch for the dining room, switching it on and off every two seconds while I check the current flow through each breaker. On the 8th try, I find one that the current changes by about 1 amps every two seconds. Eureka!!
    A few minutes later with the power off I can get all wires to cooperate, and once again everything is working. Well, until I put the outlet back into the box and one wire popped out again (sigh). Time to use a new wire nut.
    PlainBill
  • delaware74b
    • Apr 2009
    • 628
    Re: AC power circuit tracing
    I have the previous generation of the circuit tracer in the attachment. Works great on live circuits. Connect into circuit, scan breaker panel twice. Steady tone on circuit breaker to be turned off.
    It has two problems. First is you can't use the transmitter on circuits protected by arc fault breakers. The transmitter trips the arc fault, can be a good thing if you're trying to turn off that circuit. Second, all dimmers in the house must be turned completely off. They generate noise that is similar to the signal the transmitter generates.
    I've modded an extension cord so the transmitter can be connected to a light switch or tied into a junction box to trace circuits.
    Your local Lowe's and Home Depot have the Ideal 61-532 tracer for about $35USD.
    Stupidity should be a crime, especially for drivers. I have NO patience for them.
    • smason
      • 1652
      Great idea using the clamp on ammeter!
      As for wires falling apart, ouch. I always twist the wires together solidly with pliers, so they stay together even before the wire nut goes on.
      • PlainBill
        • Feb 2009
        • 7034
        Thanks for the information. That probably would have helped locate bot the bad junction and the breaker. The price is reasonable, too.
        PlainBill
        • BigTroll
          help with home a/c and circuit breaker
          by BigTroll
          while I was gone today the women called me and said the a/c isn't working and the breaker is buzzing so she turned off the breaker. The a/c is a old 1993 model York so its nearing the end of its days, on really hot days the a/c will trip the breaker.
          I visually checked the cap and contactor and they looked okay, I also pulled the 250v ac fuses and switched the main ac breaker on and got no buzz. I did get buzz when I put the ac 250v fuses back in and flipped on the breaker nothing but buzzing. could it be a shorted wire or did the circuit breaker just finally give up the ghost?...
          09-05-2020, 07:53 PM
        • beetle1303
          Electric oven tripping circuit breaker after turned on for 3-5 minutes
          by beetle1303
          My electric oven was working fine all the while from purchased 2 years ago. I have been using it weekly for about a year, but stopped using for a year now since then.
          When I turn it on again yesterday, the tripped the circuit breaker and whole house no power supply. I reset the circuit breaker, and retried. Same thing happened.
          This is what happened:
          - Turned on the oven power supply, set temperature to 200c, everything worked for a few minutes, then the power tripped. Oven was warmed/hot.
          - Reset circuit breaker, retried, same thing happened.
          05-03-2020, 09:18 AM
        • dicky96
          Thermal Circuit Breaker Problem - can we fix it?
          by dicky96
          Hi guys
          I have this ETA 3120-F321-P7T1-R14XB3 Circuit breaker from a Hill DX3000 Power Amplifier.
          The first problem I found with the amp was a faulty 25A Bridge rectifier FB2506 that was short circuit on one leg AC to negative
          I've replaced that but the amp has no power. That is because the ETA circuit breaker is open circuit on one pole. The other pole switches OK. The primary of the transformer seems OK (not short or open and doesn't look distressed) so I think that ETA circuit breaker is the only other problem I need to fix.
          Problem is finding...
          03-08-2019, 06:45 AM
        • Astonished
          Fixing the Charge Circuit of the Batteries of the DC Motor
          by Astonished
          Hi friends of electronics
          What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
          The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
          Please help me fix this circuit.
          (the datasheet of the IC: https://pdf.datasheet.live/28...
          01-28-2025, 06:24 AM
        • rddube
          Lenovo L490 Ram voltage circuit malfunction
          by rddube
          Hello friends,
          Looking for some guidance here. The RAM voltage circuit on this motherboard keeps burning out PU301 which is a RT8231AGQW. Copy of the board with the burnt chip attached with some voltage measurements and copy of the schematics also included.
          I think I've checked almost every component in the circuit, but when I change the RT8231, the laptop starts I have 1.2V on the inductor for about 10 seconds and then the RT8231 goes south and no more voltage on the inductor. All other voltages on the laptop are good, this is the only one conking out for a reason I...
          07-15-2025, 04:41 PM
