Hantek scopemeter
  • barry wilkins
    • Aug 2009
    • 172
    Hantek scopemeter
    Unfortunately I have damgaged channel 1 on this scope ,I was hoping the maker would supply me with the circuit for the Y amplifier ,but they wont play ball.
    I think I have found the fault ,after the input circuits there is a dual JFET in a 8 pin SM package and this has blown. I have managed to remove this and and I going to try a couple of BF244 fets to see if the amplifier now works .
    Has any body got a simliar circuit that uses a SST5912 dual Jfet ? It could be a cascode design ,I think Pico scopes use this device .
    Also I need to find a replacement SST 5912LF ,does any body know where I can get hold of one ?
    thanks
    Barry Wilkins
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Hantek scopemeter
    For the last one look at 2N5912 and see if that's right.
    https://cdn.badcaps-static.com/pdfs/...8bdc3800cd.pdf
    If it is there are some on eBay. [Tripped over it, wasn't really looking.]
    http://cgi.ebay.com/130423905521
    BF244 aren't too tough to find unless you have a thing about using the original brand.
    http://shop.ebay.com/?_from=R40&_trksid=m570&_nkw=BF244
    How do you like that thing anyway? - Umm, before it blew up that is.
    Mann-Made Global Warming.
    - Dr Seuss
    • barry wilkins
      • Aug 2009
      • 172
      Yes I saw the 2N5912 on ebay its in a metal can ,the one i removed was SM 8 pin ,so suppose it should work if i could fit it.
      Found a scope circuit that uses 2x BF556A JFETS ,that might be a possibility.
      The scope itself is very nice ,good display one channel defunt .One thing i did not realise when i bought it was the DVM is seperate to the scope with different leads.Not like the Philips PM97 which all works from the BNC input ,I dont really use the DVM side anyway so not too fussed about this.
      I will let you know how I get on with the fix,took some pickies so I will try and figure out the circuit from them ,and took voltage readings on channel 2.
      Barry Wilkins
        Hantek scope that can hook up to your iPad or computer IDSO1070A feedback wanted about it specifications
        I thinking about about buying one later on this year depending on what feedback I get from this forum members that know more than I do about what is importance about what to have in a scope
        https://www.aliexpress.us/item/32568...3333736563%21s...
        04-12-2025, 10:24 PM
      • FALKLAN
        Oscilloscope Selection - Hantek DSO2D15
        by FALKLAN
        Howdy all!
        I'm a newb concerning electronics repair and I'm looking at a Hantek DSO2D15 oscilloscope. It's on sale for a good price IMO. I'm asking any feedback concerning this device and a few power supplies if anyone is willing the help an old tech.
        The Hantek seems like a decent machine for $175 new. I'm also looking at a 60v 24a power supply for $60. Sound like a good deal?
        11-29-2023, 04:33 PM
      • sofles
        Bowers & Wilkins PX7 S2 Needed help with identifying charging IC
        by sofles
        Hi there,
        Recently I bought broken Bowers & Wilkins PX7 S2, the problem with them is that battery discharges on its own even with headphones turned off. It is a quite common issue with this model and even with model higher PX8.
        With help of thermal camera I found out that there is one IC that is hot even with headphones turned off. To check if I'm correct I bought another PX7 S2 working one and replaced small charging board with this IC and problem solved, battery no more drains on its own. After changing board back to original problem returned so I'm 100% sure problem...
        05-30-2025, 01:11 PM
      • EasyGoing1
        Reading input and output of bridge rectifier on the same scope?
        by EasyGoing1
        I have a 40 volt AC transformer that I put a bridge rectifier on, and I wanted to see the input signal and the output signal on the same screen on my scope, so I set one channel up with the test lead on one side of the input and the ground lead on the other side of the input, then I used another channel on the scope and clipped the test lead on the positive side of the output then the ground on the negative side of the output.
        When I connected the transformer to power, the wire that was connected between the ground lead on the second channel and the negative side of the bridge rectifier...
        06-26-2022, 12:52 AM
      • Vanillaboard
        Hantek 6022BE USB Port pulled out
        by Vanillaboard
        I'm currently working on a Hantek 6022BE where the USB port and vias have been ripped off the PCB. Here are the steps I've taken so far:
        1. Power Supply: I've tapped the power supply next to the via from the tracer.
        2. GND: I've successfully connected the GND as well.
        3. Data Lines: I soldered the D+ and D- lines directly to the USB controller (CY7C68013A-100AXC) at pins 17 and 18.
        Now I'm wondering if I need pull-up resistors. According to my observation, the tracer goes directly from D+ and D- to the USB Port. Could that be right?
        Despite these steps,...
        09-22-2024, 06:41 AM
