oscilloscope
  • mitchell2120
    • Mar 2011
    • 8
    oscilloscope
    oscilloscope not showing trace have checked out lots of thing and show to be fine but ran a cross two 3.9kΩ resistor one getting very hot the other nothing both show good resistance Help pl
  • japlytic
    • Oct 2005
    • 2086
    Re: oscilloscope
    What is the make and model of the oscilloscope?
    This would help you find a fix to the problem you are experiencing.
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      Re: oscilloscope
      Please do not start multiple topics on the same issue, it only makes our job harder.
      https://www.badcaps.net/forum/showthread.php?t=13613
      https://www.badcaps.net/forum/showthread.php?t=13620
      I'd just continue in this one: https://www.badcaps.net/forum/showthread.php?t=13620
      A working TV? How boring!
      • chth96
        Is it possible bridging tiny broken trace
        by chth96
        When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
        cutting tiny trace.
        This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
        Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
        But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
        12-03-2022, 11:32 PM
      • Tarot Superstars
        How not to Damage an Oscilloscope
        by Tarot Superstars
        Hello.
        I have jut got my first analogue oscilloscope. An Isotech 620 20MHz.
        I want to learn how not to damage it, and I found instructions on the internet obscure.
        They talk about ground, earth, floating ground, this, that....
        But they don't actually say anything anything useful so far.
        I want to know:
        Don't connect exactly this to exactly there or it blows up.
        For example, I am tracing a signal from a function generator in an audio amp, or testing for voltages in different parts of a circuit.
        I want to know what not to connect...
        08-29-2023, 02:27 PM
      • OOF DIO
        ASUS FX505DV no power shorted at PWM controller Pin 3 VREG3 TPS51225C, need pinpointing of the short.
        by OOF DIO
        (If anyone has a functional boardview file of FX505DV/DU that would be helpful)
        (Had 3 problems, now just 1)
        I have no experience or knowledge and usage of tools to repair devices besides the entire past 12-10 days of researching, watching YouTube repair videos and troubleshooting this laptop motherboard. ChatGPT was used as a guide to ask questions.
        I used boardviews of mostly FX505GD-M, and some FX505DU, FX505DD. Used schematics of FX505DU.
        I had originally intended to replace the BQ24780s first (due to previous battery removal while benchmarking) but I...
        04-19-2025, 05:03 PM
      • MasterCap
        AVR-2802 no audio, chip questions
        by MasterCap
        I do some hobby repairs mainly of my own junk, and I don't know much programming level repair/mods.
        I got the AVR-2802 over the weekend, sold as working of course, and it worked for 1 night, using EXT. IN 5.1CH jacks, then after power down, the audio never came back. I've reset it, and get nothing on EXT IN or PHONO, despite having everything set right, hooked up right. I can hear lots of relays work tho.
        I just want it for 5.1CH analog inputs , for PC surround sound. I'm not worried about the video or most of the digital stuff for now.
        So far I've traced...
        01-15-2024, 10:52 PM
      • Evets
        Dynamco analogue oscilloscope
        by Evets
        I have recently acquired a Dynamco D7100 analogue oscilloscope without a user manual. As this is the first time I have owned or used an oscilloscope I would like to try and find an instruction book. The manufacturers no longer hold any information and a Google search only found one site but when I downloaded a 'service manual' all I got was gobbledegook. Any help would be gratefully appreciated or even pointers to a generic manual where I could learn more.
        08-30-2024, 06:54 AM
