PCB Drill
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    PCB Drill
    Guess what arrived today in the mail. A high torque DC motor fitted with a little keyless chuck, a push switch, a power jack and a random HP power brick tossed along with it. Works with 0.4 to 1mm bits. Looks super ghetto but it only cost me $17.60 postage included.
    Does it work? Hell yeah. Drills thru blank PCBs in a blink of an eye, clears soldered holes with ease (someone mentioned using a sewing needle for that...), i even drilled thru one of my screwdrivers with it! It's centered very well, no breaking bits. Just the thing i needed to get serious about making PCBs.
    I'll post some pics for the curious later on.
    A working TV? How boring!
  • Toasty
    • Jul 2007
    • 4171
    Re: PCB Drill
    >>clears soldered holes with ease <<
    Just don't use it on via's, or multilayer boards.
    veritas odium parit
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      Re: PCB Drill
      A via is a tube so i can't see why it wouldn't work. I have a couple motherboards i can sacrifice, we'll see.
      • mathog
        • Mar 2010
        • 2655
        Re: PCB Drill
        On multilayer boards vias can have electrical connections at internal layers. If you drill out a via the odds of destroying the conductive tube are high, and the odds of reconnecting those internal layers with just the blob of solder in the resulting hole are not good.
        Should be safe to use your tool on a two sided board though. Just be careful not to push up a trace on the side when going through. Also, don't breath the dust.
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          Re: PCB Drill
          Who said anything about drilling OUT vias? The thing works with drill bits smaller than the via so i can simply drill THRU. I tested it on a scrapped Geforce 4 Ti and drilled thru almost all the vias - NONE came out and the sides of the vias are visible.
          • severach
            • Aug 2007
            • 1055
            Re: PCB Drill
            Sewing needles are lousy for clearing holes. Solder sticks to needles. Needles are too small. The pointy end doesn't clear much.
            Put that drill backwards into a needle nose vice grip, apply heat, and you can clear those holes without damage to the vias. The solder gun and the drill can be on the same side of the board if access is limited.
            When the via is full of solder you can't center the drill well enough to keep from drilling the via and everything else. Lots of vias are only half full and drilling works much better. Unfortunately between brass vias and carbon steel drill bits, any mistake and the brass loses.
            sig files are for morons
            • capfiz
              Diamond Core Drill ELU SB43EK, Blown Capacitator
              by capfiz
              Hi, new to this forum and new to most things electronic component related.
              As in my introductory post, I'm good for soldering, fixing up the grandkids console games but that's about it.
              I am based in the UK.
              17 odd years ago I purchased an ELU diamond core drill, model ELU SB43EK, I had never heard on the brand here in the UK at the time but it has been a faithful tool and has undertaken a number of jobs without issue.
              Last week it failed to start when depressing the trigger, initial checks, it wasn't the fuse or plug top, delving further and...
              11-24-2023, 07:31 AM
            • arsharpe
              Hitachi drill charger UC18YKL
              by arsharpe
              I am fixing the charger (UC18YKL) for a Hitachi battery drill (DV18DCL2) but, as it charges Lithium batteries, I need to know the correct replacement device for the blown (smd) FET2.
              As I have spent many hours trying to find a schematic for this DV18DCL2 charger without any luck, does anyone know where I can get one or a parts list?
              Thanks in advance for any help,
              Rob
              07-12-2025, 11:53 AM
            • zen
              Drill control unit switch required ,help please
              by zen
              Hi all , it's part of a control unit that operates a drill.
              Striped it down & cleaned contacts but not reliable
              Hoping some one out there in the ethos can help me source one . ( see pictures )...
              05-16-2024, 03:49 AM
              by momaka
              03-15-2023, 10:17 PM
