Defective Multimeter?
  • briand
    RocketScientist
    • Jan 2011
    • 12
    Re: Defective Multimeter?
    ...agree with the others here, regarding cheap meters. I have an $11 meter I picked up from Wally World that I throw in the truck.
    At home on the bench, I have a Fluke 8100B -- gotta love those nixies!
    • kaboom
      "Oh, Grouchy!"
      • Jan 2011
      • 2507
      A few years ago, someone PAID FOR one of those arc blast initiators and asked me to fix it.
      After plugging GOOD test leads into it, I found that the range switch was too flimsy to maintain contact pressure and for some ranges, some parts were bad. So I decided to play spot the violations.
      Here's what I found:
      10A range unfused
      Leads on both front and back of PCB were WAY to long, nonexistent clearances
      'Clips' for .25A fuse were the same cheese, I mean metal, that chinese copies of chinese copies of things are made from- no way they'd even hold
      That stupid '3 hole' board for the jacks- it's about 3/8" wide and 1.25" tall and holds the three jacks. The current shunts are on the 'main' board and this little board is connected by NOTHING but three little solder drops. They'll melt while carrying current, either while measuring OR during an 'accident.' You will then have a nice series arc inside the meter case.
      Metal battery case practically in contact with 10A shunt
      I did the guy a favor and destroyed it.
      I just LOVE how these 'meters' are 'IEC1010' rated, 5x20mm low-interrupting fuse and all. If that thing were put across voltage while set for resistance or current, the circuit board would 'protect' the fuse. On the 10A range, you'd blow the meter and leads apart.
      Look at that label! It says you can float the meter common 500V above ground! I'll just set it on a panel can and put the black lead on an ungrounded phase of a 480V corner grounded delta system- nice knowing you...
      Seriously now, just get a Fluke, Amprobe, Wavetek, Greenlee. You'll appreciate it each time you use it. You'll also be less 'accident-prone'
      -Paul
      "pokemon go... to hell!"
      EOL it...
      All style and no substance.
      guilty,guilty,guilty,guilty!
      guilty of being cheap-made!
      • Agent24
        I see dead caps
        • Oct 2007
        • 5037
        • New Zealand
        Originally posted by jpartanen
        "Happy" owner of a Mastech M-830B here... The meter is ~6 yrs old, bought from a department store. Didn't get a manual in Finnish, clearly a violation of regulations. Current measurement stopped working 4 yrs ago, fuse's good.
        I had the same problem, fuse looked good, but the wire had separated from one of the end caps, back behind the metal where you couldn't see it.
        -David VanHorn
        • PanicMechanic
          Extech EX330 multimeter current range offset fault
          by PanicMechanic
          My multimeter has developed this fault, a few months ago. I tried to fix it, but had no success.
          The fault is that on the current ranges it never shows 0. Does not matter if the probes are open or shorted.
          As you can see from the pics, the offser is the same (just multiplied for other rages):
          -4.9 uA
          -0.49 mA
          -0.49 A
          I don't know what exactlly caused the fault.
          The meter had a battery leak before I noticed the fault, but I am not sure if the fault was present before that happened. I just did not noticed. The battery leaked...
          05-11-2021, 11:13 PM
        • yayayee
          ASUS GU502GV not powering on - 1285A hot
          by yayayee
          I have a laptop that isn't turning on. When I disassemble it and plug in the power connector with the pcb by itself, I can see with a thermal camera I bought that TPS51285A is the only thing getting hot.
          So of course, the first thing I do is google the laptop model and the IC, and it just happens that I stumble upon a video by Northridgefix attempting to repair the exact same problem, only for it to catch on fire.
          I thought that maybe I'd be lucky so I bought a 1285A, that came in as a 1285B. The only difference I can see between them is that the 1285B...
          01-08-2024, 11:04 PM
        • dj8452000
          How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
          by dj8452000
          I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
          02-18-2025, 08:28 AM
        • Pize92
          Defective BIOS chip
          by Pize92
          Hello everyone.
          I have a problem.
          The BIOS chip on my Lenovo Legion 5 17ACH6H appears to be defective. I wanted to read the chip first with the ch431a programmer and then with the t48 and create a dump. However, it always threw an error during verification.
          I then bought a new BIOS chip from Aliexpress and loaded an existing dump onto the chip. With the corresponding DMI.
          Unfortunately, the laptop now keeps restarting.
          My question is, can you simply use the DMI from a foreign dump, or is the motherboard completely lost due to the defective BIOS chip?
          08-19-2025, 10:59 AM
        • rumpumpel1
          How do I find a defective RAM chip
          by rumpumpel1
          I have a ThinkPad T14 which always finds an error at a very specific address during a RAM test. I therefore believe that exactly one of the RAM chips on the mainboard is defective. How do I find this defective RAM chip?
          07-29-2025, 11:55 AM
