Aixun T3A overshooting?
  • tony359
    • Oct 2018
    • 264
    • United Kingdom
    #41
    Re: Aixun T3A overshooting?
    yes it's coming from the handle.
    This is the video I have sent Aixun for review.
    https://youtu.be/KzfpZB6R6js
    That said, @Capleaker, I won't be able to go back to my standard iron. For fun I tried de-soldering a power connector from an XBOX 360 board. Half of the pins were the shell of the connector itself. It's taken a while, with braid, but I did it and didn't damage anything. Impressive.
    • CapLeaker
      Leaking Member
      • 8340
      I think your T3A is faulty.
      Indeed there was a cable that came with it, just mine has banana plugs on both sides. I plugged that in, put a crocodile clip to it and grounded out the outside of a USB port, then started solder around on the case and everywhere else, no problem. Grounded out an old VHF tranceiver and I solder around like nobody’s business. I did exactly that what you did in the YouTube video. My T3A works just fine, as it supposed to. My T245 pencil does not hum and that ground point on the back of the T3A is connected to the earth pin on the AC cable. I measured abou 0.05VDC between the hot tip and that ground point.
      So yours must have “special features”. Lol
      • tony359
        • Oct 2018
        • 264
        • United Kingdom
        #43
        well that's great news I guess! What FW are you on?
        Let's hope Aixun replies with something helpful!
        Really appreciated the time you spent on doing this test for me!
        • CapLeaker
          Leaking Member
          • 8340
          Running firmware 1.26
          • tony359
            • Oct 2018
            • 264
            • United Kingdom
            #45
            Maybe I should try that LOL!
            • CapLeaker
              Leaking Member
              • 8340
              Nah, it’s something electrical related, not firmware based. That’s what I think anyway.
              I did buy mine from Aixun official store through Ali.
              • tony359
                • Oct 2018
                • 264
                • United Kingdom
                #47
                I didn't know Aixun had an official store but I bought it from a recommended store based on SDG Electronics review. So finger crossed.
                1.34 behaves differently than 1.33. On 1.33 I have "no tools" when the "fault" shows up. On 1.34, the power jumps 0-100% until I remove the tip and by that time the overshoot is +120C.
                Slightly off topic, what is an alternative for a T245 station without spending an arm and a leg?
                • CapLeaker
                  Leaking Member
                  • 8340
                  The Aixun was the best bang for the buck when I researched and ordered mine. I am so happy with mine, I even got the T12 pencil and elements. Wouldn’t consider trading it.
                  • tony359
                    • Oct 2018
                    • 264
                    • United Kingdom
                    #49
                    Ok, then I hope mine is defective!
                    • tony359
                      • Oct 2018
                      • 264
                      • United Kingdom
                      #50
                      Aixun asked me to contact their support team directly at this address? https://www.jcprogrammer.com/
                      Who is making those stations in the end?
                      • tony359
                        • Oct 2018
                        • 264
                        • United Kingdom
                        #51
                        I've now found others reporting the same issue I am reporting. As speculated, it sounds like it's something to do on how the station is measuring the temperature. I'm yet to get a feedback from Aixun but the fact that others are seeing the same probably means it's "normal".
                        I guess the vast majority of people won't use a pre-heater or solder on grounded equipment.
                        • CapLeaker
                          Leaking Member
                          • 8340
                          Can’t be. Why doesn’t mine have your symptoms? If you don’t mind, in what countries are the others? Does it have to do using 220 vs 110V?
                          • tony359
                            • Oct 2018
                            • 264
                            • United Kingdom
                            #53
                            It really needs a specific PCB and specific pins. Could it be that you didn’t stumble into that? On the mobo I was soldering only 4-5 pins of an ISA connector were showing the issue.
                            I’m 220V, UK. Not sure about the others.
                            • harp
                              • Jun 2022
                              • 643
                              • Planet Earth
                              #54
                              Nobody concerned about 1.5A - 1.74A...?
                              • tony359
                                • Oct 2018
                                • 264
                                • United Kingdom
                                #55
                                I am.
                                But as you noticed nobody else seems to be so I’m not sure what to think ��
                                • redwire
                                  • 3912
                                  What is happening is the thermocouple op-amp is picking up noise due to the ground loop from touching the tip to something earth-grounded.
                                  Usually this noise is from the SMPS, high frequency say 66kHz.
                                  You could prove it by taking a say 10nF cap one leg to earth ground, and touch the tip to the other leg. If it freaks out then that is the problem.
                                  There's a few ways to fix it.
                                  • CapLeaker
                                    Leaking Member
                                    • 8340
                                    I don’t understand why some units have that problem, while others not. I only had 0.05VDC measured coming out of my tip to earth ground. Could the problem be the T245 element itself? How else would voltage to be able to get on the tip?
                                    Yours definitely went crazy if you used that earth pin. Mine absolutely does not care if the earth ground touches the soldering tip. I’ve tried a few times now hooking the earth ground to everything I repaired.
                                    I fixed a HDMI port on a PS5 today and used the earth ground. No problem. Voltage between the tip and earth ground was again 0.05V. Yesterday, I fixed a PA phone Paging speaker and a Motorola CDM1250 VHF. No problem then either. What gives?
                                    • redwire
                                      • 3912
                                      They're trying to fix the hardware issue with software. What F/W rev are you running?
                                      You have a lot of noise on the temperature signal, you can only take a temp reading when the heater is off due to voltage drops in the wiring.
                                      If you are skilled at writing real-time code, you can read the sensor and filter out noise before going into the PID routine. But... the firmware is not any good at that yet.
                                      Is the tip connected to PE? Or is it floating?
                                      Another issue I have seen is the SMPS transformer wound by some villagers end up really noisy with the primary coupling too much noise to the secondary. Or the SMPS is not stable.
                                      Also the thermocouple op-amp can vary widely in quality. That was the cause of many problems with bad temp readings.
                                      • tony359
                                        • Oct 2018
                                        • 264
                                        • United Kingdom
                                        #59
                                        I don't understand why some units have that problem, while others not. I only had 0.05VDC measured coming out of my tip to earth ground. Could the problem be the T245 element itself? How else would voltage to be able to get on the tip?
                                        I see you are using the station extensively so I don't mean to patronise you here, just clarifying things.
                                        Voltage is only measured when the tip is actively heating. If I measure when it's keeping a stable voltage, I'd probably get the same reading.
                                        To reproduce what I did, set one pre-set to 400C, then cool down the tip to 100C, then place your meter on the tip (not in auto mode, it won't be fast enough, I selected an appropriate range on my Fluke and set the Fluke to display the maximum reading).
                                        Now the tip is 100C, select the 400C channel. The tip will be constantly heated for 3-4 seconds and then is where I measure the voltages I reported.
                                        Yours definitely went crazy if you used that earth pin. Mine absolutely does not care if the earth ground touches the soldering tip. I've tried a few times now hooking the earth ground to everything I repaired.
                                        Again, just a clarification: not an earth pin. Nothing happens if I touch an earth pin. It's "some" pins on a grounded PCB.
                                        I don't know what to say though. I had that issue 10 minutes into using the station. 3-4 pins of each ISA slot would show the issue.
                                        Then I was practicing on an XBOX on a pre-heater and the USB connector was buzzing loudly when touching the pre-heater itself.
                                        What I am trying to say is that it feels like an obvious behaviour to me, I didn't do anything so special to see that.
                                        I agree with that.
                                        I tried 1.34 and 1.33. 1.33 is "louder" but at least keeps the temperatures where they are supposed to be. Also 1.34 doesn't show "NO TOOL" when the issue happens but the power level goes 0-100 like crazy until the tip is on the affected pin.
                                        I read full continuity to ground but only when not heating. It could be because my Fluke won't like sensing voltage when in continuity mode though.
                                        Will try that thanks!
                                        • CapLeaker
                                          Leaking Member
                                          • 8340
                                          Ok, redone the voltage measurement as you suggested, but at 0.5V I am still nowhere near the 1.5V. What elements did you get? Mine are made by Aixun with the black rings. Maybe there are low quality elements that are the problem? Dunno… I give up, as I can’t replicate the crazy behaviour of your station no matter what I try.
                                          • CapLeaker
                                            Anyone tried or got the Aixun T3A with the T245 pen?
                                            by CapLeaker
                                            On the recent sale I've ordered a new Aixun T3A with the T245 soldering pen and it comes with the fancy pen holder. Wonder if anyone has one and if your happy with it? It's got some decent reviews. On YouTube a guy compared it with the JBC and results were pretty darn good fur such a cheap rig.
                                            12-04-2022, 02:12 PM
                                          • tmcw
                                            Drying Oven - Preset Temp Fail
                                            by tmcw
                                            Here's an unusual one...
                                            This is a Gallenkamp oven, used in a laboratory space, goes up to 220 Celcius, but is usually maintained at about 115 Celcius. Used for drying glassware, molecular sieves, and so on. Oven is in excess of 20 years old.
                                            It heats up fine, there is an orange light on the front that indicates that the unit is heating, and when it reaches the preset temp, the orange light goes out. All good so far.
                                            However, after the preset temp is reached, the temperature continues to rise, power to the heating elements isn't cut off.
                                            01-21-2021, 03:11 AM
                                          • foshland
                                            MSI MAG Z390 Tomahawk BIOS temp, allways at 0ºC and CPU goes protection 800Mhz
                                            by foshland
                                            Hi to all, my motherboard (bought second hand as faulty, but now working after cleaning the ram slots) have a strange failure that shows 0 Celsius degrees in BIOS, because of that, the CPU goes to protection mode and gets stuck at 800Mhz.
                                            Since its a 8-9 Intel generation, I know the CPU temp is the hottest temp of the cores (as i have read in intels documentation) so its not a diode or sensor on the board.
                                            External temperature (motherboard temp) is working OK, 27ºC more or less
                                            In windows, all the software I have tested shows correct the Core temps
                                            12-16-2023, 09:08 PM
                                          • mosfetratus
                                            concerning gtx675m vram temp
                                            by mosfetratus
                                            Is 98C vram temp are safe? Less demanding games goes 80ish.
                                            Funny thing, there were old non stock thermal pads very botched, so i replaced them. After, temperatures remained the same, but performance (fps) improved significantly. With both thermal pad application GPU core temp was similar.
                                            furmark goes about 104C, amperage keeps rising so do temps.
                                            01-30-2025, 08:41 AM
                                          • Sudoer
                                            DIYPHONE Store and AIXUN T420D
                                            by Sudoer
                                            I've seen enough reviews of AIXUN T420D on YouTube and decided to try it. One handle defective from the inside, ruined 3 JBC tips, just destroyed the plastic on the tips. One stand does not work, the soldering handle not drop the temperature. Because the seller refused to return the money, and AliExpress supported him and even PayPal did not help, I can disassemble this piece of shit and see what inside, if anyone is interested. The seller said that the station does not work with JBC handles, but I checked that it works. It's just a pity to connect the original handle to this shit. Beware of order...
                                            05-04-2023, 04:55 AM
