CH341a won't work with a 25Q128JVPQ
  • tman2023
    • Aug 2023
    CH341a black programmer
    NeoProgrammer 2.2.0.10
    Winbond 25Q128JVPQ
    With the above, NeoProgrammer just outputs "IC not responding" when I try to detect the chip.
    I've tried two different flash chips, same thing.
    I'm using an adapter PCB in the CH341 and all the pin connections check out and no shorts.
    This isn't my 1st rodeo, I've used the CH341a with lots of other chips.
    Any ideas?
  • harp
    • Jun 2022
    • 598
    • Planet Earth
    Re: CH341a won't work with a 25Q128JVPQ
    Dont know exactly, but I have also a reliability problem with ch341a.
    I found that it work well with different softwares (programs), so, check to have it collect as much as posible
    https://www.badcaps.net/forum/showpo...0&postcount=64
    So it can be done with ch341a.
    I am working with atmega328p and have success only with siberiaprog, it is on forum.
    https://www.badcaps.net/forum/showth...=111791&page=3
    Even with same programs but different version can be a fault or success...
    Have you modified ch341a for 3.3v?
    Example
    https://khandishnetwork.com/2020/07/...ftware-update/
    • tman2023
      • Aug 2023
      Thanks Harp.
      Following one of your links, I've modded my CH341 to 3.3V - I didn't realise it was signalling at 5V without that.
      I tried Siberiaprog and a few others as you suggested but no luck for me.
      Unless anyone has any other suggestions, I think I might have to buy an RT809H
      • asustuf
        • Feb 2023
        • 18
        • Austria
        Before investing into RT809H, you might also try AsProgrammer https://github.com/nofeletru/UsbAsp-flash/releases
        There is also for around 15€ new version of CH341 with swtich for different voltages (1.8, 3.3, 5V), but it probably won't be any different than your current one. However, CH341 is very prone to failure (and you mentioned using it a lot), so it might also be worth trying a different one.
          • 31009
          i would recoomend the T48 myself - it's pretty cheap and does a hell of a lot
          software is simpler to get too.
          https://xgecu.aliexpress.com/store/g...001828848.html
            How to add chip support to NeoProgrammer software for the CH341A Programmer
            by SMDFlea
            Adding chip support is quite easy,there`s even some instructions included with NeoProgrammer,although its not obvious where they are
            and once you do find them there`s a few crucial steps missing.
            Extract chiplist.zip to a folder,the instructions are in Import_EN.txt and in Import.xml .Its the xml file where we add the new chip.
            Open Import.xml with notepad or any other text editor.In this example i`m adding a Macronix MX77L25650F SPI_NOR chip.
            After adding the chip save the xml file and copy it to the root directory of the...
            05-26-2024, 07:15 AM
          • intelg
            HP Elitedesk 800 G6 lost BIOS admin password
            by intelg
            Hello everyone, I am looking for help as I am struggling to remove lost BIOS Admin password on an HP EliteDesk G6 800 series desktop. I wanted to reset the vPro remote control IP kvm for homelab use.
            Here is the hardware identification specs:
            HP EliteDesk 800 G6 Desktop Mini PC
            Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
            BIOS ver S21 Ver. 02.05.01 01/05/2021
            Born on date: 07/26/2021
            SN MXL11841GN
            SKU 3X8V9UCHABA
            UUID 8116E79EF6FFE94DB0B98A3188270C5C
            SYSTEM BOARD ID 8710
            SYSTEM BOARD CT NUKBER PJLHQ0A8JF236L...
            11-03-2023, 02:05 AM
          • Jérémy Vanbaelinghem
            The CH341A doesn't read anything, but maybe that's because I'm a noob :D
            by Jérémy Vanbaelinghem
            I'm desperately trying to get my CH341A to work, but it seems that all my attempts have failed. Despite everything, I want to check that it works, the aim being to read at least one chip and “screenshot” the configuration for me to use as a reference.
            Here are the steps (software part):
            - I'm running Windows 11 Pro 64-bit (10.0 build 26100)
            - Drivers are installed (no error messages) and there are no problems in the Device Manager.
            - Set the language to English (to avoid the CH341A's basic software bug)
            - Does not work on AsProgrammer...
            05-05-2025, 02:30 AM
          • hollox123
            ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
            by hollox123
            Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
            1. Laptop keyboard doesn't work
            2. The backlight on the laptop keyboard doesn't work
            3. The x2 side LEDs (red) on the laptop don't work
            The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
            I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
            But I am strongly aiming that it is somehow a BIOS-related problem,...
            05-11-2025, 08:05 AM
          • JoWed
            Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
            by JoWed
            Hello Community,
            I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
            07-01-2025, 09:32 AM
