Tips for reduce shaking ?
  • corrize
    • Apr 2021
    • 272
    • France
    Hello, I have a little problem. When I use hot air, I'm shaking a little with tweezers, and I'm scared to push a little qfn for check if it floating. So sometime, I prefer to not try and « hope » the solder is done.
    I use the blue tweezers mechanic AAC-14 and a I put just my fist on the table.
    Do you have tips to reduce shaking pls ? Maybe shorter tweezers, or something for wedge the fist or arm ?
    (I add : no coffee, no alcohol and I don't smoke).
    • 30985
    Re: Tips for reduce shaking ?
    thats half the problem
    but seriously, instead of poking, spin the hot air around the package to make it wiggle on the balls
    • harp
      • Jun 2022
      • 598
      • Planet Earth
      This is ergonomic in question, you shoud try to put some stiropore (polystirene expanded) plates at fist rest. Try very range of hight from 5mm to 35mm, and go with confortable one, or on some other support.
      Second, do apply some tension at worked arm, like finger who slightly push and amortizate shaking, of corse the hot air is tied to rope and hanging...
      Also, position of tip is important, has you try a bent tip, because it change position how you handle the tool...
      • Green Probe
        • 26
        I agree that ergonomics helps a load. I found it a lot easier to use the hot air in my secondary hand, and the tweezers in my primary hand. It took a second to get used to, but having my primary hand do the fine work is worth it. I find it easier holding the tweezers with the base of them resting on top of my hand, like holding a pencil or chopsticks; instead of the base of the tweezers being in my palm like holding tongs. Lowering my chair helps too. Watchmaker's workbenches are armpit height, so there has to be some advantage to it for fine work. They also commonly have arm rests, which you may find useful. These might be obvious things, but they did help me when I tried them.
          • 30985
          have something to rest your wrist on while holding the tweezers
          • estabilito
            Tips geting oxidized when using wick
            by estabilito
            Hi, i have weird problem - when i'm using soldering wick to clean BGA balls under CPU or PCH on motherboard my tips(different types) getting oxidized very fast and lost all power.
            i Was trying different types of wick, flux - no difference. I can't even clean one full socket and i need to use deoxidizer in half-time.
            Temperature: 350-365celsius
            station: jbc cd-2bqe
            Wick: edsyn
            flux: warton hf rework jelly
            Do you have any tips?...
            04-12-2025, 11:55 AM
          • redwire
            Hakko 950 SMT hot tweezers but no base or stand
            by redwire
            I got gifted a Hakko 950 SMT hot tweezers but no base or stand.
            Any suggestions for building one?
            "The 950 is compatible with the Hakko 936, 937, 939, 703, 926, 927 and 928 soldering stations." Apparently it has two heaters in parallel "24V 50W", one RTD temperature sensor 43-58Ω at room temp. 5-pin DIN.
            I don't have any of those, have a 470-2 (no RTD in) and a FX-888A.
            04-17-2025, 03:01 PM
          • corrize
            Quality solder iron tips and Kapton ?
            by corrize
            Hello, I have a solder iron pen (50w) with tips « 900m » (hollows ones, standard). I'm searching to replace mines because it's impossible to tin, they remain black and impossible to unsolder a mini SMD capacitor with. Bad ones.
            I'm looking to replace the iron tips but, on Amazon, Ebay… all no names, the sames. Sold by 10, 15 or more at low price and « pro » websites only one Hakko tips sold 20 dollars. I'm lost.
            Do you have brand of qually tips pls ?
            Same question for Kapton (for my other hot air iron), do you have brand or good place to buy, the true...
            05-24-2021, 11:35 PM
          • Davi.p
            Reduce the size of photos please..
            by Davi.p
            Hi all, i'm asking all to reduce photos to a more comfortable resolution before post, the better like around 2000x2000, otherwise many PC / Tablets / phones refuses often to load them or has strong defection... today's digital cameras integrated in phones especially are a mockery because them saves photos at enormous resolutions with much less the real definition, so reducing them is only a good deal.. THANKS!!...
            05-16-2024, 12:53 AM
          • aaronmacdonald
            Mix & Match Hot Tweezers with Station
            by aaronmacdonald
            Hey guys; I have a cheap soldering station (Txinlei 8586) and was wondering if it was possible to use Aoyue hot tweezers on it.
            Digikey has a couple options for Aoyue hot tweezers available, and although you're not really "supposed to" use them on anything other than intended Aoyue stations, I was wondering if any of you have experience/knowledge and can tell me if I can safely use any of the available options on my cheap station.
            These are affordable, and the quick shipping speed (I'm about to do a digikey order anyway) makes them attractive over a Chinese...
            08-29-2022, 08:00 PM
