Rejoin cut flat cable ?
  • zioricci
    • Jan 2023
    • 125
    • Italy
    Is there a way to rejoin the two parts of a cut laptop keyboard flat cable? I was thinking about silver paste but I don't know if it can be done well.
    I assume that the soldering iron can be left closed in the drawer.
  • harp
    • Jun 2022
    • 645
    • Planet Earth
    Re: Rejoin cut flat cable ?
    Yes you can...
    First you must ensure that make mechanical joint extremly good done, maybe put some plate under and glue it to not move or even bend on that place again. Then proceed like this in video:
    https://www.youtube.com/watch?v=PO6b5VD7bbg
    Precise repair of damaged lines on flat flex ribbon cable
    If it is more easely you can prepare cable on flat surface before streight them with plate glued plate.
    BTW I hope that cable is made of some material who can solder...
    • lotas
      • Jan 2016
      • 4819
      • Russia
      There's nothing you can do about it, there's nothing to solder, the tracks here are made with conductive coating, it's easier to buy a new or (used) keyboard
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • Patch2
        Cable Repair
        by Patch2
        I have a broken connector (believe it's a 6 pin mini-DIN) on a cable. The metal shroud and all but one of the pins are separated from the cable, and just stuck together for the photo. The other end is an unknown rectangular connector. The cable is for the foot pedals on an Italian made electronic piano, and the company is out of business. Looking for ideas on how to fix it. I have a soldering iron, but I'm not very skilled at soldering, so getting a retrofit for the broken end may be beyond my ability. The other end would be easier to replace, if I could get a mini-DIN cable with the same number...
        01-02-2025, 06:04 PM
      • Tr0ll
        by Tr0ll
        Original T-con:
        First replacement T-con:
        10-07-2023, 07:48 PM
      • conghuyms
        I need datasheet cable eDP LCD 30 pin slim pls help me!
        by conghuyms
        My 30-pin eDP cable from the mainboard to the LCD screen got cut and damaged at the screen connector side. I found another cable and took the screen-side connector from it, but the wire colors are different. So I really need the wiring diagram for both ends of the eDP cable to solder it back properly. If anyone has the diagram, please kindly help me out. Thanks a lot...
        08-22-2025, 11:16 AM
      • lcdcaps1
        A1229, Flat / Flex Cable 821-0511-A repair
        by lcdcaps1
        Hi
        I am trying to repair the above flat / flex cable for an A1229 machine
        I cant see where the traces are coming from
        I have attached photo of the cable taken from online and highlighted the pins I need to solder a jumper wire to and then mask but cant see where the traces are for the side where the pads have been ripped
        Look forward to the help, again
        Many Thanks...
        10-02-2020, 05:29 AM
