Sceptre x22wg-Gamer 22" LCD
Panel: AUO M220EW01 V.0 TN Film
Power Supply: FSP050-2L02 3BS0144112GP REV:1 E116921 K3502 2SK3502 SG6841SZ BI3101A
Video Board: AL012 REV.1 MTK810NGD MST9251DA-LF-165
Inverter Transformer: SPI 8TC00291
Another revision of the FSP050-2L02 uses a set of 4 transformers similar to the SPI 8TT00006.
Disassembly:
Do not remove 3 black angle head screws in back near connectors
Split front with putty knife working from any corner, no force extract LED from front cover
Panel: 4 gray angle head
Power Board: 2 gray plastic thread, 2 gray machine thread, 1 gray machine thread to ground lug
Video Board: 4 gray plastic thread, 4 VGA standoff, 1 gray machine thread at HDMI connector
Reassembly: Ensure all buttons click. Unfortunately the monitor must be mostly reassembled to test.
Bulged caps on power supply:
C551, C552: CapXon 470uf 25v (runs at 5v, good ESR=0.05, bad esr>=1.1)
Other caps that did not fail yet:
C664: CapXon 470uf 25v (runs at 12v)
C554: CapXon 470uf 25v (runs at 5v)
C1, C661: Taicon 1000uf 16v (runs at 12v)
C210: CapXon 33uf 35v (runs at 12v)
The video board has a dark spot near C37. C37 tests good.
C37: Jackcon 47uf 25v, esr=0.06 in circuit, esr=1.1 out of circuit
This TN Film panel running on DVI is as clear as my PVA monitors with excellent bleed control.
One person here on badcaps was able to fix their x22wg-Gamer entirely from the debug menu.
Disassembly:
