HP w1907 Powers On Then Doesn't Detect Signal.
  • zylcho
    Padawan Learner
    • May 2010
    • 52
    Powers up fine, shows bios and refreshes to desktop for about 10 seconds then flashes "Input signal not detected" and shuts off. This happens in both VGA and DVI.
    On dissection I see nothing visually that would be a possible suspect. Some minor oxidation of a few joints.
    Video board "appears" to ok.
    Any assistance in this would be greatly appreciated. Thank you in advance.
  • delaware74b
    • Apr 2009
    • 628
    Re: HP w1907 Powers On Then Doesn't Detect Signal.
    What brand and series caps on the power supply board? That board has lead-free solder and usually doesn't look good when compared to the old 60/40 lead/tin solder. I'd reheat those connections that don't look good and apply some 60/40 solder (if you're in the US).
    Stupidity should be a crime, especially for drivers. I have NO patience for them.
    • zylcho
      Padawan Learner
      • May 2010
      • 52
      Couple different brand of caps, suscon, samxon, teapo and a symbol that looks like Leton. Sorry not quite following you as far as series?
      Can you mix the 2 solders? Or do I have to remove all existing? As I have plenty of 60/40.
      Yes I am in the US. Thank you for the assist.
      • retiredcaps
        • Apr 2010
        • 9271
        One cap series might say HM(M). It is a two or three letter code.
        The 0405 (4 digit number) indicates year (2004) and the week (5th week) of when the cap was made.
        I think that is Lelon.
        Re the 10 seconds, try turning down the brightness and contrast down to say 25/100 and see if you get more than 10 seconds of operation.
        --- begin sig file ---
        --- end sig file ---
        • zylcho
          Padawan Learner
          • May 2010
          • 52
          OK powered on with Marlboro and plastic insulators to run while dissembled. The damn thing started working!
          Of course passed all brightness tests as it is now working.
          Been over 10 hours without power save and still good to go....
          Did I wiggle something to cause this to function?
          • zylcho
            Padawan Learner
            • May 2010
            • 52
            Crap! Reassembled and back to original problem.... What I did notice now is that the blue power indicator (led) is now turning yellow (power save mode?)when the screen is not on.
            So is not displaying "Signal not detected" anymore.
            Screen turning off after 5 seconds and instantly turning power light yellow.
            Could this be a problem with the video board?
            • retiredcaps
              • Apr 2010
              • 9271
              Try the configuration where you had it working for 10 hours again and see if it works. If it works, maybe check the cable connectors?
              Also try gently rocking the caps back and forth to see if you have a loose solder joint. I found one cap on a Benq PCB board that looked good from the backside, but it was obviously loose when I rocked it back and forth on the frontside.
              Crap! Reassembled and back to original problem.... ?
              • zylcho
                Padawan Learner
                • May 2010
                • 52
                Well it was dissembled when it worked for 10 hours, took apart again and same crap, no work.
                I have stuck, measured, wiggled and inspected every "movable" part on both boards.
                Will try some heat on the joints and see what that gets. Thanks for the reply.
                • delaware74b
                  • Apr 2009
                  • 628
                  zylcho, I try to remove as much of the lead-free solder as possible, but sometimes I have to add some 60/40 to the existing solder connection before I can remove the old solder or component. I'm willing to bet you have a cracked solder connectionon that board. It also sounds like the backlight circuit could be shutting down due to overload condition in either the inverter or you have a backlight starting to fail.
                  • mathog
                    • Mar 2010
                    • 2655
                    I had a display where the VGA socket was slightly dirty inside. The DVI might have been too, don't know, didn't have a DVI cable to plug into it. Scraped out the inside of each VGA socket "tube" with a paper clip, which happened to be just the right size, and then a VGA cable was able to make a decent connection to the socket, and it saw signal. The display was still broken though in other ways. Apparently, the remaining failure had put it out of action originally, and then it sat around a long time with nothing plugged into the VGA port, so by the time I saw it VGA cables were not making an adequate electrical contact with the socket.
                    If you see the no signal symptom and there was no cable plugged into it when you first obtained the monitor suspect dirt in the video socket.
                    • zylcho
                      Padawan Learner
                      • May 2010
                      • 52
                      Definitely not a dirty VGA socket. But thanks for the tip.
                      I took an iron to some of those oxidized joints and now monitor wont even attempt to power on. Not giving up just gets frustrating.
                      Thanks everyone for the assist. Will fiddle with later on.
                      • alexanna
                        • Mar 2010
                        • 1346
                        I have a very similar problem with several monitors. [ 2 sec off] I can not rembember the exact status of the power led, but running them on bench lcd out of case laying flat I could not get them to fail by wiggiling wires taping on screen they worked perfect. I have not run them for 10 hours, if they worked I put them back together,Then they would start their 2sec out problem. What I have found is poor or over heated wiring on the return side of the UPPER ccfls. Not sure why they work out of case laying flat other than added heat when they are assembled, an that heat rises.
                        • AstutePauciloquent
                          Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
                          by AstutePauciloquent
                          Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
                          I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
                          11-23-2023, 11:02 PM
                        • CoinCoin88
                          Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                          by CoinCoin88
                          I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                          Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                          09-15-2025, 03:36 AM
                        • howardc64
                          Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                          by howardc64
                          Failure Symptom
                          No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                          Where is the short?
                          Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                          Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                          05-27-2025, 02:56 PM
                        • JayPoorJay
                          Converting +/- 5v to a Usable Hz Signal
                          by JayPoorJay
                          Good morning.
                          I have posted here before and have gotten AMAZING advise (thank you!). I'm back for more. This BCaps Sub Forum is so well attended I thought I would post here.
                          This question is for an automotive application but has to do with what are essentially electrical questions and problem solving... If this is inappropriate I get it. Feel free to delete it or move the question.
                          The V 12 Jaguar XJS is notorious for overheating in stop and go traffic in hot weather... Y'all will be potentially helpinh a LOT of people. The solutions and directions...
                          08-07-2022, 08:35 AM
                        • supravit2000
                          PS4 fat has inconsistent signal after HDMI replacement
                          by supravit2000
                          Hi, guys!
                          I am not a professional, all I can do is solder stuff on the boards, so I would really appreciate it if someone with knowledge shares his experience/thoughts on a problem I have with a PS4 console.
                          My friend gave me an original fat PS4, board model SAB-001, with WLOD, that has been previously opened. I changed the HDMI port, couple of pads on the board were ripped, which I connected to the corresponding caps/resistors? Just did so as in a shown diagram (one of the ground pads I ripped off and left it not connected). However, there was still no signal, so...
                          12-19-2022, 08:08 PM
