how to remove unscrewable screw?
  • paparazzo79
    • Dec 2018
    • 303
    • Bosnia
    Ok guys,the laptop is Lenovo Yoga 2 Pro.
    It had hinge problems so guy repaired it,and we change the back cover becase the top left part was broken.
    But back then the repair guy on local service (whom I don't talk now) did some weird thing.
    Dunno if he glued the screw onto the chasis but I can not unscrew this screw no matter how much torque I apply.
    So what to do now?
    The back is from plastic and it can be easily broken.
  • Sametbey
    • Jan 2021
    • 229
    • Turkey
    Re: how to remove unscrewable screw?
    with the appropriate diameter drill, you can break the screw head. then you can remove the remaining body with pliers. good work.
    I'm not happy to be so strong. because it's not humanly
    • paparazzo79
      • Dec 2018
      • 303
      • Bosnia
      Yeah but I can break thje hole where screw goes too,right?
      You mean just to drill the top/head of the screw?
      That would be tricky since I don't know how long to drill.
      • petehall347
        • Jan 2015
        • 4450
        • United Kingdom
        you could try warming it with your soldering iron but not enough to melt plastic .just to soften the glue .
        • tomrlopes
          • Sep 2011
          • 15
          According to the service manual the screw is M2 x 5mm
          https://cdn.badcaps-static.com/pdfs/...a86552fd0f.pdf
          Use a 2mm bit and drill the center of the screw head until it falls off.
          Then once you have the bottom cover off you remove the remaining screw shaft. (maybe use side cutters, but don't squeeze too hard)
          Another way: cut a slot in the screw head with a Dremel, then use a slotted screwdriver. (I once screwed myself by putting Loctite red on the hinge screw. Used Dremel 9909 bit)
          • paparazzo79
            • Dec 2018
            • 303
            • Bosnia
            Yeah just to get 2 mm bit and drill special for such small bits.
            I'm not a driller I'm a PC built technician in my free time,and my brain is f..ed up from terrible disease.
            • petehall347
              • Jan 2015
              • 4450
              • United Kingdom
              use a reverse drill bit if you can find one
              • howardc64
                by howardc64
                Problem
                08-04-2024, 10:36 PM
              • longmt1990
                Panasonic Cf-w5 bios password remove
                by longmt1990
                Hi, i have a Panasonic Cf-W5 with the bios password, I tried remove cmos but problem didnot solve.
                I uploaded the picture after remove cmos battery, It look like this is a Phoenix bios. The bios dump file in the link i attached
                Please help me remove bios password.
                Thank you so much
                07-06-2025, 10:50 PM
              • Maxpower3
                Hantek 365 Remove screen on startup
                by Maxpower3
                every time I open the tool, I have the screen that appears
                and I am always in a hurry to use it so I click and it automatically sends me a link to the manufacturer.
                It annoys me lol.
                2 solutions to remove it.
                Either you remove pic.bmp and it no longer appears so no more links when clicking.
                hope this helps users...
                01-15-2025, 03:24 PM
              • MICHAEL_2013
                Macbook Pro Core I7 A2251 EMC3348 Help Remove MDM
                by MICHAEL_2013
                Good afternoon. My client brought me a Mac A2251 EMC 3348 that he bought at a sale. The computer is completely iCloud-free, but it came with MDM installed. He has tried contacting the company that provides the MDM in every way possible, but they are unwilling to offer a solution. The device is:
                Model A2251 EMC 3348. Serial Number: C02G54CZML85
                Apple MacBook Pro Core i7 2.3, 13" 2020, 512 GB SSD, 16 GB RAM.
                I've tried changing the serial number of the SoC ROM MX25U3235F, but it hasn't worked:
                C02G54CZML84 only works up to Monterey.
                C02G54CZML86 doesn't work (I...
                11-20-2025, 11:18 AM
                Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
                The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
                Securing a good thermal interface between...
                10-07-2024, 04:35 AM
