Thorn 65thl4kst1
  • viewerau
    • May 2020
    • 305
    Thorn 65thl4kst1
    My friend has this television.
    It stopped working, but still has power, but no image or sound.
    It was under warranty, and instead of fixing it, the company sent him a new one.
    The repair agent whom inspected the television reported that the fault was the main motherboards.
    My friend would like to buy the parts and get his old one working as well.
    I have looked online for spares, but note that this panel contains 2 x motherboards.
    One is a B.RK3288.3 LC550EGE-DHM4 and the other part of it is 20F2 Main Board - T.MS3458.U801
    Some pictures attached.
    Each part is AU$93 each.
    Is there any simple way to know which board is faulty, or is it a case of eenie meenie miny moe.
    Signature:Seemingly hopeless tv fixer
  • nomoresonys
    • 12206
    • U.S.
    Re: Thorn 65thl4kst1
    The little one is your wifi board, the other is the mainboard.
    • viewerau
      • May 2020
      • 305
      Thanks...that seems a big wifi board, but so be it.
      Looks to me I may be best buying the one on the left with the rf/tuner, and hope for the best....
      • nomoresonys
        • 12206
        • U.S.
        Could do some voltage testing if you want to try to narrow the issue, start there:
        Test the voltages at the connector on the powerboard with EVERYTHING hooked up, it's the connector that the cable from powerboard to mainboard hooks into, most times there's a legend/map nearby that gives the expected voltages, you measure them with your mutimeter, set meter to 20 vdc then report them, put neg probe on chassis metal ground, pos probe on pin of connector, measure in standby take note, leave probes where they are then power on tv and again take note of voltages, report them here, example pin 1-ps-on-0 volts standby-power on-3.3 volts.
        • viewerau
          • May 2020
          • 305
          Many thanks nomoresonys...
          I hope to have the tv dropped to me in the next few days for me to open it up.
          I have noted today, during googling, that the left hand mainboard seems common to a number of different tv's on the market. One seemed to be JVC, Sceptre, and a couple of others, Bauhn too, I think?
          Thank you.
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            They both appear to be mainboards. The only way to be certain is to open up the set and identify the correct mainboard for the LCD panel in the set
            In post #1 the LC550EGE-DHM4 I believe is the LCD panel number it is paired with.
            • viewerau
              • May 2020
              • 305
              Thanks dick...I think the actual number is LC650EGE-DHM8...which is different to the described part???
              Googling those, I also found this link, indicating an LG telly???
              https://www.panelook.com/LC650EGE-DH...iew_29029.html
              • viewerau
                • May 2020
                • 305
                These were where I got the original photos
                https://www.ebay.com.au/itm/313240251503
                https://www.ebay.com.au/itm/313240273336
                Naturally, I know taking the back off the telly will reveal correct numbers for me...cheers
                • Diah
                  • Feb 2013
                  • 6399
                  dont be hurry LOL. if this was yours boards search this forum, before one year one user from Philippines posted dead JVC and it was the fault just one regulator under the main IC heat sink
                  • nomoresonys
                    • 12206
                    • U.S.
                    I thought it was an odd looking wifi board too but there it is evidently: https://www.ebay.ca/itm/254905757045...kAAOSww3FfYde2
                    • viewerau
                      • May 2020
                      • 305
                      Hi...still awaiting this tv to look at.
                      I was searching for parts online, and noticed this:
                      This first photo is from a JVC T.MS3458.U801 Main-Board for U65CV-UMR ATVU65-0916 RTU6549-C 65UGX35 at a price of AU $53.99
                      https://www.ebay.com.au/itm/264935935927
                      The second photo is from a GENUINE THORN 65THL4KST1 20F2 Main Board - T.MS3458.U801 at a price of AU $90.35
                      Naturally the JVC board is the cheaper, but are the two mainboards the same, or could there be something on the main chip that makes each one either suit JVC only or Thorn only.
                      Could I be making a big mistake in buying the cheaper JVC one, rather than the more expensive genuine Thorn one, which is for a THorn TV?
                      Thank you.
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        The difference may be the LCD panel the mainboard is matched with.
                        • viewerau
                          • May 2020
                          • 305
                          Thank Dick...does that sort of mean that one board will behave different to the other, when viewing the tv screen? Some functions may work differently?
                          Sorry...
                          • viewerau
                            • May 2020
                            • 305
                            deleted
                            • viewerau
                              • May 2020
                              • 305
                              Ahhh...my bad luck...I put another motherboard in, but all remains the same.
                              TV powers to on, but the screen is just white...grrrr
                              On inspection of these boards, I also note that the T-Con board also has texta letters on it....would this indicate that this may have also been replaced at some time?
                              • viewerau
                                • May 2020
                                • 305
                                I have been advised, via a youtube search on ShopJimmy (https://www.youtube.com/watch?v=yTnkOfwBGGE ) that a way to check that my t-con board has power, is to check power on an ic for power on the drain, gate and source to determine?
                                On picture number 2, can anyone identify the component to check please?
                                Thank you
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  "The screen is just white".....so the backlight is working.
                                  Disconnect one cable from the tcon to the panel and see if you have half a picture then reconnect and repeat for the other cable.
                                  • viewerau
                                    • May 2020
                                    • 305
                                    Thanks for your reply.
                                    Do I have to power off the tv whilst removing and reinstalling the ribbon cables please?
                                    Nearly 1:00 am in the morning now, so will look for a reply in the morning and try then
                                    Thank you
                                    • viewerau
                                      • May 2020
                                      • 305
                                      Sorry to be a pain again...
                                      I just don't want to make things worse....do I need to power off the tv whilst removing and reconnecting these cables?
                                      • viewerau
                                        • May 2020
                                        • 305
                                        Ok...
                                        I disconnected one tcon ribbon, and it all looked the same.
                                        I then reconnected that ribbon, and removed the other.
                                        This caused a change...one side illuminated bright white (left side) and the other side jet black.
                                        Does this help with any diagnosis please?
                                        Thank you.
                                        EDIT...
                                        I reseated all the cables, still no difference.
                                        I could not work out how to open, remove this ribbon...is there a special way so I can ensure it is seated correctly?
                                        Other picture shows with one ribbon connected.
                                        • Geeker007
                                          Friend messed up my laptop motherboard while working on my bench
                                          by Geeker007
                                          Hi All,
                                          So my friend was visiting and he wanted to use my solder bench to solder on some WLED circuit board. My laptop was open on the side for RAM upgrade. I know my mistake.
                                          So while soldering he had too much solder on the soldering iron tip and he just shook off the soldering iron on the table itself to remove extra solder on the soldering tip and it landed on the motherboard of laptop. He then out of fear tried to remove it using solder wick and did more damage by removing some components as well. So here I am with weird situation.
                                          I have not tried putting...
                                          06-16-2025, 01:40 PM
                                        • qwerty99
                                          Xbox 1.6 Motherboards and Polymer Capacitors
                                          by qwerty99
                                          Hello!
                                          I need to change the capacitors on my three original Xboxes.
                                          Two of them are 1.6B revisions and have Hynix RAM, and the other one is a 1.6 with Samsung RAM.
                                          The 1.6 has the infamous Nichicon HM capacitors around the CPU, which have all bulged and started to leak. This Xbox no longer powers on.
                                          The 1.6B revisions have Rubycon MBZ capacitors that all look fine, but I’ll change them in due course. Both of these work fine.
                                          I’ve seen some excellent threads on the forum about replacing/upgrading capacitors, but I can’t...
                                          06-26-2022, 12:53 AM
                                        • Foetuss
                                          Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
                                          by Foetuss
                                          Hi all
                                          Hope this is in the correct place.
                                          I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
                                          Could use some double checking to see if I'm not doing something stupid .
                                          Pictures of the boards are attached.
                                          What I will be replacing with what : (planned)
                                          Soltek Golden ::
                                          4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
                                          6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
                                          01-18-2025, 11:44 AM
                                        • matthewmcconaughey
                                          I need help with my friend Sony GDM-FW900 24” CRT
                                          by matthewmcconaughey
                                          Hello, Badcaps is my last resort. I am the first owner of the monitor. I reached almost every repair store in my area, but no one even wanted to hear about troubleshooting an old CRT monitor. At this point, I have been trying to figure it out by myself, but I have no idea where to start or look for.
                                          I wish to know how to think and locate a failing component. I will put all my efforts to learn and contribute.
                                          1. It started with a bright and greenish picture upon starting a cold monitor.
                                          2. About 2 years ago, only on the cold boot, the screen started to occasionally flash with
                                          05-16-2023, 03:15 PM
                                        • Jackching
                                          Intel PC hooked to X90L television picture cut-off
                                          by Jackching
                                          I have my Intel PC hooked to my Sony X90L television and each time the power is cycled on the tv, the bottom of the PC screen gets cut-off. Only half of the taskbar shows until i go into display settings and cycle the display size and it'll work fine until the next time I power off the tv. I updated the drivers. The graphics is UHD 630.
                                          10-27-2024, 11:43 AM
