Thorn 65thl4kst1
  • mrsith
    • Mar 2021
    • 146
    • Wielka Brytania
    #121
    Re: Thorn 65thl4kst1
    Just in case you can try replacing the T-Con, it won't hurt but probably won't help. The parts you'd like to cannibalise are the two little boards between the T-Con and the panel itself. Not an easy job to replace.
    Double check the capacitors on these board (on your faulty screen), put diode mode and check each capacitor leg-to-leg, also check each leg against the ground. If your meter doesn't beep it's gonna proba ly show ~030 for shorted caps vs ~600+ healthy ones. Most likely you will find quite a lot of shorted caps, the problem is determining which one of them actually causes it.
    In diode mode, just put one probe to one side of capacitor and another one to the other side. Or put negative probe on the ground (i.e. chassis), and positive to each leg of the capacitor. One leg should return high value, while the other should be clpse to 0. If both are suspiciously low then its probably.a short there.
    Do this with everything connected, but without power cable in.
    • viewerau
      • May 2020
      • 305
      THANKS,
      The 10th post on page. 6 shows the readings in continuity, giving a set of numbers according to how I put the probes on each end. I did this with all boards and strips attached as normal, but unplugged from the wall. My panel has 4 of those edge boards . Given nothing has changed, I think the values will be the same. Does this all mean, if I took out every board and replaced them, that it still would not work as one of the four edge boards would still be faulty.?
      Signature:Seemingly hopeless tv fixer
      • nomoresonys
        • 12206
        • U.S.
        #123
        try both the tcon and mainboard from the broken screen tv, see if it works.
        • nomoresonys
          • 12206
          • U.S.
          #124
          important to know is that the same model tv can have many different mainboard and tcons and they are not usually all compatible, that's why you need to match up the white sticker numbers, the silkscreening on the board is just generic, then they populate it with what they need to. NOW do you have a match between any of the boards you are trying to work with?
          • nomoresonys
            • 12206
            • U.S.
            #125
            do the test in post #121, with tv unplugged from power and tcon cable unplugged from driver board/s, it's a simple test. We NEED conclusive test results so we can eliminate possible problems and move on, stay with it, trying every couple months isn't a very effective method, there's no tv these pros can't fix.
            • viewerau
              • May 2020
              • 305
              Thank you chaps...I do appreciate this additional help.
              In the daytime tomorrow (getting dark here now) I will measure all the 4 boards again, and report the readings.
              This is what I got before, will be interesting if I see differences.
              I note mrsith recommends all things connected and unplugged, and nomoresonys recommends the tcon cable unplugged from the driver boards.
              Which way do you both concur with please, as I do want to do this accurately, and eliminate data I may be supplying incorrectly?
              Again...thanks.
              • viewerau
                • May 2020
                • 305
                Woops...forgot old readings
                • nomoresonys
                  • 12206
                  • U.S.
                  #128
                  I tell you to unhook cables from mainboard to driverboard to isolate, because issues can travel, that way you know if there is a problem it isn't traveling from the mainboard to panel driver thru the cable. Also explained in post #94.
                  • nomoresonys
                    • 12206
                    • U.S.
                    #129
                    • nomoresonys
                      • 12206
                      • U.S.
                      #130
                      • nomoresonys
                        • 12206
                        • U.S.
                        #131
                        answer this question, exactly HOW are you testing these caps? I can not help without answers to each question.
                        • nomoresonys
                          • 12206
                          • U.S.
                          #132
                          HERE is what i want you to do, for THIS test forget how he does it in the video. go ahead and isolate the boards like he does if possible, NOW read carefully, 1 put meter in diode mode, so for this do NOT use ohm mode, 2 put one probe on chassis metal ground, 3 put other probe on each side of cap while never moving the probe on chassis ground, one side should read close to 000 the other should read something much larger than 000, do it exactly like that.
                          • viewerau
                            • May 2020
                            • 305
                            Thank you .. I will do this exactly as you advise. Again, your assistance is greatly appreciated.
                            • viewerau
                              • May 2020
                              • 305
                              Well...
                              The tv has remained unplugged from the wall, and checks suggested are undertaken.
                              The multimeter is set in diode mode....the reading on the multimeter is a single "1" digit.
                              If I touch the probes together, then the reading changes to "003"
                              I have disconnected the 2 x cables leading from the t-con board to the side edge boards.
                              With the black probe on the chassis, and at the same time, touching red probe on any side of ALL the caps, nothing but a single "1" changes.
                              So now I get nothing at all.
                              To double check myself, I went and located some same caps on the t-con board, and measured them in the same process as above. In this case, one side of the the caps looked at, they would show "001", and then the red probe changed to the other side of the cap, the display is "171".
                              To me this indicates that the multimeter is working ok?
                              What test do I move to next please?
                              Thank you.
                              • nomoresonys
                                • 12206
                                • U.S.
                                #135
                                ok, it seems like there's a short on the panel driver board.
                                • nomoresonys
                                  • 12206
                                  • U.S.
                                  #136
                                  sometimes you can get lucky and the shorted component is hotter than the rest, i think i would go to those caps that are reading 0 ohms, remove one at a time and check them off the board, if it is a cap issue, when you hit the right one the short will be cleared, check the pads where the cap comes off same way as described and check the cap off the board, because it's usually only one cap that is bad, it just can be a real pain finding it, could also be a different component causing the short.
                                  • nomoresonys
                                    • 12206
                                    • U.S.
                                    #137
                                    there's a good video on the subject, i'll check.
                                    • viewerau
                                      • May 2020
                                      • 305
                                      Thank you...
                                      When you say "ok, it seems like there's a short on the panel driver board" I assume you refer to one of the 4 edge boards?
                                      I count 38 caps on the 4 side boards in total.
                                      Being a novice, how do I work out what type of capacitors I need to purchase please?
                                      Further, will a hot soldering iron remove them easily?
                                      Not too sure I am capable of this either.
                                      Lastly, if all the removeable boards are the same on the broken screen replacement I have sourced, and match my faulty one's to put into my tv, if the edge boards are the problem, could this cause damage to the replacement parts, if I swapped them out?
                                      • nomoresonys
                                        • 12206
                                        • U.S.
                                        #139
                                        video here, he talks about testing and finding the bad component, he uses his tool to find the bad component that's reading less than an ohm, in other cases he injects voltage to find the bad component, there's also a wealth of knowledge in the comments: https://www.youtube.com/watch?v=77tymvTJDxo
                                        • nomoresonys
                                          • 12206
                                          • U.S.
                                          #140
                                          Originally posted by viewerau
                                          Thank you...
                                          yes the "edge boards", was this the one with the stand alone tcon? there is a definite possibility of damaging the tcon if the driver board is faulty but keep in mind. If you have a problem with the driver board, you will not solve it by replacing the other boards, the panel driver board/s must be repaired if possible, unless the "tape cut-off" method will work.
                                          • Geeker007
                                            Friend messed up my laptop motherboard while working on my bench
                                            by Geeker007
                                            Hi All,
                                            So my friend was visiting and he wanted to use my solder bench to solder on some WLED circuit board. My laptop was open on the side for RAM upgrade. I know my mistake.
                                            So while soldering he had too much solder on the soldering iron tip and he just shook off the soldering iron on the table itself to remove extra solder on the soldering tip and it landed on the motherboard of laptop. He then out of fear tried to remove it using solder wick and did more damage by removing some components as well. So here I am with weird situation.
                                            I have not tried putting...
                                            06-16-2025, 01:40 PM
                                          • qwerty99
                                            Xbox 1.6 Motherboards and Polymer Capacitors
                                            by qwerty99
                                            Hello!
                                            I need to change the capacitors on my three original Xboxes.
                                            Two of them are 1.6B revisions and have Hynix RAM, and the other one is a 1.6 with Samsung RAM.
                                            The 1.6 has the infamous Nichicon HM capacitors around the CPU, which have all bulged and started to leak. This Xbox no longer powers on.
                                            The 1.6B revisions have Rubycon MBZ capacitors that all look fine, but I’ll change them in due course. Both of these work fine.
                                            I’ve seen some excellent threads on the forum about replacing/upgrading capacitors, but I can’t...
                                            06-26-2022, 12:53 AM
                                          • Foetuss
                                            Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
                                            by Foetuss
                                            Hi all
                                            Hope this is in the correct place.
                                            I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
                                            Could use some double checking to see if I'm not doing something stupid .
                                            Pictures of the boards are attached.
                                            What I will be replacing with what : (planned)
                                            Soltek Golden ::
                                            4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
                                            6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
                                            01-18-2025, 11:44 AM
                                          • matthewmcconaughey
                                            I need help with my friend Sony GDM-FW900 24” CRT
                                            by matthewmcconaughey
                                            Hello, Badcaps is my last resort. I am the first owner of the monitor. I reached almost every repair store in my area, but no one even wanted to hear about troubleshooting an old CRT monitor. At this point, I have been trying to figure it out by myself, but I have no idea where to start or look for.
                                            I wish to know how to think and locate a failing component. I will put all my efforts to learn and contribute.
                                            1. It started with a bright and greenish picture upon starting a cold monitor.
                                            2. About 2 years ago, only on the cold boot, the screen started to occasionally flash with
                                            05-16-2023, 03:15 PM
                                          • Jackching
                                            Intel PC hooked to X90L television picture cut-off
                                            by Jackching
                                            I have my Intel PC hooked to my Sony X90L television and each time the power is cycled on the tv, the bottom of the PC screen gets cut-off. Only half of the taskbar shows until i go into display settings and cycle the display size and it'll work fine until the next time I power off the tv. I updated the drivers. The graphics is UHD 630.
                                            10-27-2024, 11:43 AM
