Rca led52b45rq
  • RDC55
    • Dec 2017
    • 180
    Rca led52b45rq
    RCA LED52B45RQ no video, no backlight, status light illuminated red and does not change when power is depressed. Power Supply shows a constant on state (On/Off 4.6V) when plugged in and voltages at the connector appear normal, but PFC voltage is only 165 volts suggesting no boost.
    Pin----------Name----------Plugged In Measured
    12----------12V-------------12V
    11----------12V-------------12V
    10----------GND--------------0
    09----------GND--------------0
    08----------GND--------------0
    07----------5V---------------5V
    06----------5V---------------5V
    05----------5Vsb-------------5V
    04----------ON/OFF----------4.6V
    03----------5V----------------5V
    02----------5V----------------5V
    01----------GND--------------0
    So it seems strange that the voltages are there, but the PFC is not working?
    Checked Power Supply on bench (unloaded) and when On/Off is tied to 5Vsb through 1K resistor 12V and 5V appear on connector, but boost is 165V instead of the expected 395V.
    Verified all components in the area of U101 (FAN7930C), verified VCC present on U101 pin 8 and it has 5V referenced to AC ground.
    Power MOSFET and Diode check OK
    No pulses (a bit of noise) on output pin 7 of U101
    Any thoughts - order and replace U1
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Rca led52b45rq
    The Vcc voltage needs to be a lot higher to start the PFC (FAN7930C) to operate. See attachment.
    Data sheet says
    Once the supply voltage of the PFC
    block exceeds 12V, internal operation is enabled until
    the voltage drops to 8.5V.
    • RDC55
      • Dec 2017
      • 180
      Re: RCA LED52B45RQ
      Data sheet says
      Yea I missed that, and I am fairly clueless on the SMPS's. I just checked again and VCC is 6.5 VDC with respect to the negative lead on the large cap, which I wanted to mention just to be sure this is the correct return.
      I tried to trace some of that out to understand how VCC is made but kudos to you guys that can make sense of these circuits when trying to follow the etch and maybe make a drawing since a schematic is not an option - that pin 8 seems like it goes everywhere when you look at the components that look like they could affect that voltage.
      So, any helpful hints on how VCC might be made?
      Would I be looking for something like the standby transformer rectified output on the AC side making that VCC, and then that would be dependent upon a seperate PWM driver doing its thing while also being able to enable / disable the VCC voltage from conditions on the DC side? But, since I have standby voltage doesn't that mean it should be working and making VCC, or maybe I am just missing enable / disable signal?
      And just a note there are two PWM devices both LD7750 - data sheet attached.
      • R_J
        • Jun 2012
        • 9606
        Re: Rca led52b45rq
        The standby circuit usually supplies the vcc voltage, it is then switched and regulated by Q108, This transistor will have a zener diode (ZD102) in its base which sets the voltage (15~18v) The supply will be on the collector and the output will be on the emitter. I would also replace those small electrolytics EC104, EC102 & EC103 in the standby circuit. EC102 is the filter for vcc for the regulator/switch Q108 input, EC104 is on the output.
        Also check that R132 in the pfc mosfet source is ok.
        • RDC55
          • Dec 2017
          • 180
          Re: Rca led52b45rq
          Thanks for that input, I pulled EC102, 103, and 104 and measured each one as I pulled it thinking I should be able to identify if one or all were bad. I only used a simple DMM in cap mode and they all tested close to their advertised value. Consequently, I was surprised when I installed new ones and powered it up and VCC was 14V :-)
          Note I had been near there the night before and when I was checking the output (anode) of D105 I was only getting 6.8V, so perhaps EC102 was the real culprit. Q108, ZD102, and R132 all appear to be OK in circuit testing.
          So, that is definately progress, but I guess there are still issues. The PFC voltage unloaded is 360V and when installed in the TV it drops to 315V. I have read other threads on here that suggested PFC voltage should be close to 390V.
          And some other info I should have added earlier I had already replaced EC4, 5, and 8 earlier for obvious bulging, so perhaps this board is just full of.... BADCAPS!
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Re: Rca led52b45rq
            It's the ESR (Electrical Series Resistance) of capacitors that tend to fail by increasing. It's well worh investing in a cheap component tester as advertised on Ebay which can test ESR and capacitance along with other components like diode, leds, Mosfets, tansistors etc.
            • RDC55
              • Dec 2017
              • 180
              Re: Rca led52b45rq
              Anyone ever see a connector like this before - the wired connector has 18 pins of double rows, and the Main board has 20 pins of double rows. The photo is how the set was received but the connector can be moved up one or two pins as there is no keying.
              So how would you know what is correct?
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                Re: Rca led52b45rq
                The two reds wires are probably connected to the positive voltage so you can check if you have 12V on them.
                And yes there are quite a few sets like this
                • RDC55
                  • Dec 2017
                  • 180
                  Re: Rca led52b45rq
                  So I finally got some video on this set and was pleased to see the panel is OK. However, I wanted to enquire a bit more about the PFC voltage that when unloaded is 360V and when installed in the TV it drops to 315V. I have read other threads on here that suggested PFC voltage should be close to 390V.
                  Any thoughts on those numbers and if low, what would be likely issues that I need to check?
                  Just to add the board has been completely recapped as far as electrolytic capacitors. The FAN7930C feedback resistors into pin 1 (INV) check OK, but this Power Supply seems to sum that with an output of the bridge rectifier, which is a bit confusing. Measured voltage at INV was 2.48 with unloaded condition and PFC at 360.
                    Acer Aspire A514-54-395V Notebook 5 Specification for Upgrade or Repair
                    This specification for the Acer Aspire A514-54-395V Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A514-54-395V boardview and A514-54-395V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                    09-07-2024, 04:30 AM
                  • alltvrepairs
                    Vestel 17IPS12 using IC U101 BM1Q001 BM1Q001FJ pdf
                    by alltvrepairs
                    Hi
                    Am after a schematif for 17IPS12 that uses the BM1Q001FJ-E2. I have pdf for the V3 version that uses FAN6300 but circuit is not the same.
                    Any help appreciated!...
                    02-01-2024, 07:46 AM
                  • erxmo1
                    RCA LED52B45RQ power on issue
                    by erxmo1
                    I have an RCA LED52B45RQ television. Does not turn on, but if I unplug it for 10 seconds or so and plug it back in it will power up after a few tries. Any ideas? Has a RE46HQ1350 power supply board. Thanks...
                    10-28-2019, 11:23 AM
                  • electrocute
                    Lenovo Yoga 3 14 (NM-A381) not powering on
                    by electrocute
                    Laptop: Lenovo Yoga 3 14 (80JH)
                    Logic Board: BTUU1 NM-A381 REV:1.0 2014-11-17
                    Issues:
                    • not powering on
                    • bottom of the laptop getting hot
                    Background:
                    Laptop not turning on. On-board voltage from AC adapter was jumping between 3V (do not recall correctly) and 4.xV, and the fan spinning/stopping on its own.
                    Initial readings:
                    Code:
                    PL202=4.12V  10.5 Ω   .010V drop  Hot Area
                    PL201=1.06V  44.1 kΩ  .320V drop  Hot Area
                    PL401=0V    55.4 Ω   .143V drop
                    PL801=0.04V  71 Ω    .050V drop
                    PL301=0V    112 Ω
                    10-28-2021, 10:44 AM
                  • Radio Fox
                    Acer AL1916 monitor PSU repair (DM0565R blown)
                    by Radio Fox
                    I'm repairing an Acer AL1916 monitor PSU at the moment. The 400v high voltage smoothing capacitor C114 is measuring completely O/C. The case of U101 has blown apart. Fuse F101 has blown. ZD121 reads 6 Ohms in both directions & ZD120 reads 99 Ohms in both directions. While looking at the data sheet of U101 (DM0565R), I noticed that the absolute maximum voltage for Vcc is 20v. However, the zener diode across the Vcc pin to GND is a 1N4748A (22v).
                    Now, whether that zener is used to constantly regulate the voltage, or whether its's used to protect the Vcc voltage from rising too high,...
                    04-13-2024, 06:32 AM
