BIOS for ASUS n550jv
  • questore
    • Dec 2015
    • 564
    • csongrád
    badcaps bios:
    https://www.badcaps.net/forum/attach...2&d=1522948346
    My bios backup:
    https://www.badcaps.net/forum/attach...1&d=1616507440
    Sticker on ram:
    https://www.badcaps.net/forum/attach...1&d=1616507817
    • 21916
    Re: BIOS for ASUS n550jv
    The model number on the green sticker is N550JK and version 206 ,thats the original bios for your board.
    Try the attached bios,,JK version 210 merged with your backup + your DMI + win key.
    • questore
      • Dec 2015
      • 564
      • csongrád
      Thank you.
      • grimacelord
        ASUS TUF GAMING Z790-PLUS WIFI - BIOS Help
        by grimacelord
        I have spent the last hour on this and I guess this is just over my head, so here I am.
        I have an ASUS TUF GAMING Z790-PLUS WIFI motherboard here that needs to have the BIOS updated in order to accept the latest CPUs.
        The BIOS chips seem to come as a set of two: GD25B64ESIG and GD25B128ESIG. My guess is one of them is a fail-safe for the main BIOS? I really don't know. Or one of them is ME and other is BIOS? I don't know.
        Anyway, I took dumps of both chips and then downloaded the latest update for this motherboard from ASUS's website...
        07-10-2025, 02:52 PM
      • lrouw84
        Asus vivobook s510ua bios changed to x510un
        by lrouw84
        Hi there,
        I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
        I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
        01-28-2023, 01:31 PM
      • ferah831208
        help with bios decompose for Asus s5506ma
        by ferah831208
        I have an Asus s5506ma that was bricked after a Windows update supposedly when it was updating bios. It seems to be a meteorlake Intel CPU core ultra, I cannot find too much info regarding this hardware, anyone have info about if it contains Intel ME engine and if there is any tool for disassemble spi image like we do with all CSME or TXE versions using the appropriate Intel ME tool? The problem is original bios file Asus provides, has bios guard protection, I downloaded the latest update for Ami_pfat_extractor from plomatov (previous versions of AMI bios guard extractor doesn't work),with that...
        08-24-2025, 05:35 PM
      • DynaxSC
        Need real mobo dump of BIOS v402 for ASUS PRIME Z590-A - stock image no help
        by DynaxSC
        I have a serious problem to program the Z590 chipset SRAM with a Management Engine after replacing the chipset.
        The new chipset is factory new and is not containing any Management Engine. Any attempts to program it into the chipset under Windows ends with a failure (eg. Error 20: Management Engine Device not present, or something similar).
        Due to the lack of the ME several ports on the board, including all M.2 ports aren't working, booting OS works only on USB. So it's now other way, as to program the chipset with a ME.
        Usually on ASUS boards it worked...
        06-14-2024, 03:49 PM
      • chudofermer
        Asus Ally rc71l bios
        by chudofermer
        Hello!
        Received Asus Ally rc71l with the wrong bios.
        Have the original package and all serial numbers.
        Can anyone help me understand what is wrong?
        Condition:
        Received with an original box with all serial numbers
        Due to the bios updating, something went wrong and I can not check in the bios. The recovery mode sometimes appears, usually was stopped on the logo.
        Got the flash dump, nothing found on DMI section
        No Windows key, just key ID on the box
        What is done:
        1. Flash the latest bios version with serial numbers...
        03-05-2025, 05:42 AM
