alienware 15 r3 La-D751p bios fix
  • nissimezra
    • 178
    Hi friends
    I have this dell with black screen after bios update,
    I did find the bin file here but find the chip type in the programmer or even on the net
    25B128CSIG
    https://ibb.co/2qwBbS3
    I did try ASprogtammer but can't figure which setting to use
  • Pfudaniel
    • Feb 2021
    • 91
    • Netherlands
    La-D751p alienware 15 r3
    Hello guys im in need of a bios to use with programmer.
    Alienware 15 r3 ( i7 6700hq- gtx 1060 )
    prefer version 1.10.0
    https://www.dell.com/support/home/nl...1QT090/drivers
    if have any question please ask!
    thanks!
    • Pfudaniel
      • Feb 2021
      • 91
      • Netherlands
      Re: La-D751p alienware 15 r3
      this is the original file from dell page
      • peste
        • Dec 2016
        • 13573
        • ROMANIA
        post the backup of the bios
        • Pfudaniel
          • Feb 2021
          • 91
          • Netherlands
          thanks!
          my problem is usb ports + webcam + lights not working.
          also regular bios updating through ez flash wont work.
          With programmer i've tried older versions from this forum but no success. this backup is 1.5.0, i wanna try 1.10.0 to see if it will solve the issues...
          anyway thank alot for ur time!
          • peste
            • Dec 2016
            • 13573
            • ROMANIA
            thanks!
            try..
            • Pfudaniel
              • Feb 2021
              • 91
              • Netherlands
              try..
              Thanks Peste! il try this! il post back
              • Pfudaniel
                • Feb 2021
                • 91
                • Netherlands
                try..
                nop doesnt work. 3 red lights 1 blue. after a while it comes on back to 1.5.0
                • Pfudaniel
                  • Feb 2021
                  • 91
                  • Netherlands
                  Hi guys i need a bios fix!
                  Thanks in advance for helping!
                  • Claudiomfa
                    • Nov 2015
                    • 455
                    • Portugal
                    Re: alienware 15 r3 La-D751p bios fix
                    try and report
                    • Pfudaniel
                      • Feb 2021
                      • 91
                      • Netherlands
                      Originally posted by Claudiomfa
                      try and report
                      not working, 2 red light 1 blue. no boot
                        • 21853
                        Try these.Flash the EC as well if you have a programmer for it.
                        • Pfudaniel
                          • Feb 2021
                          • 91
                          • Netherlands
                          thanks ! yes i got ch341a programmer, this is fine for it yes ?
                          please check my post in laptops, can u point me out wich is the EC to flash ?
                          • Pfudaniel
                            • Feb 2021
                            • 91
                            • Netherlands
                            i flashed bios, also give 2 red 1 blue light.
                            not sure how to flash EC. I connected the ch341a programmer and chip is recognized but on reading it just gives F only. not sure i shoud write in that case..
                              • 21853
                              Use NeoProgrammer or ASProgrammer software
                              https://www.badcaps.net/forum/showpo...04&postcount=7 NeoProgrammer
                              https://www.badcaps.net/forum/showpo...6&postcount=10 AsProgrammer
                              • Pfudaniel
                                • Feb 2021
                                • 91
                                • Netherlands
                                yes i use ASprogrammer
                                  • 21853
                                  Try NeoProgrammer. Are you using a clip or have you desoldered the chip
                                  • Pfudaniel
                                    • Feb 2021
                                    • 91
                                    • Netherlands
                                    with neopgrammer same, i can identify chip but not read or write. im using clip, the clip working fine on the bios chip. can u confirm EC chip is UE2. foto is on my topic from laptops forum.
                                      • 21853
                                      Desolder it if you can,its the most reliable way. You have some adapters for it ? . Do you have the ch341a black edition,can you check the voltage and make sure it hasn`t got 5V on pin 28.You may need to modify it so it only uses 3.3V https://www.chucknemeth.com/usb-devi.../3v-ch341a-mod .Its possible to flash the EC with the ch341a you`ll need to solder wires to the JEC connector.
                                      • Pfudaniel
                                        • Feb 2021
                                        • 91
                                        • Netherlands
                                        Yes i can desolder no problem, thanks il look into that link. Yes its black edition i think. Attached foto, this is included adapter?
                                        • STKR123
                                          The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                                          by STKR123
                                          Greetings badcaps community,
                                          I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                                          So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                                          Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                                          I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                                          These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                                          I learned that desoldering...
                                          10-29-2024, 06:03 AM
                                        • drux
                                          Alienware Aurora R15 accidentally flashed with XPS 8960 BIOS
                                          by drux
                                          I've had an ssd that was previously used on dell xps 8960 and then it was installed in Alienware Aurora R15(intel version). On first windows boot in R15 windows started bios update and loaded bios for xps 8960(r15 and xps8960 essentially have same motherboards).
                                          Now it has xps 8960 bios that looks different from alienware bios and when I'm trying to run bios update files for R15, I get unsupported platform error.
                                          These models have AMI/Aptio BIOS.
                                          Tried to edit product info with DMI Edit to change values back to Alienware R15, but it does not want...
                                          11-03-2024, 01:18 AM
                                        • hotcrossedbuns999
                                          M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                                          by hotcrossedbuns999
                                          My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                                          1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                                          2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                                          3. I could only locate two chips that look like bios chips. Could someone verify this
                                          01-03-2025, 12:32 PM
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • zlr8r
                                          looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
                                          by zlr8r
                                          looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
                                          cheers
                                          Dell Inspiron 17 (7786) Laptop
                                          Service Tag: 5J0NHT2
                                          Bios: 1.9.0
                                          MOBO: RO 15 17 WHL 2GB MB / 18706-2
                                          Attached;
                                          1. My saved bios using a programmer
                                          2. Dells Bios updater .exe (v1.16)
                                          3. Dells Bios recovery file
                                          4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
                                          5. Image of ME...
                                          12-18-2023, 03:08 PM
