alienware 15 r3 La-D751p bios fix
  • Pfudaniel
    • Feb 2021
    • 91
    • Netherlands
    Re: alienware 15 r3 La-D751p bios fix
    Found a video for the mod. Thanks alot for that, il do this tomorrow and report back.
    https://m.youtube.com/watch?v=-ln3VIZKKaE
    • Claudiomfa
      • Nov 2015
      • 455
      • Portugal
      try this file and report..
      • Pfudaniel
        • Feb 2021
        • 91
        • Netherlands
        Originally posted by SMDFlea
        Desolder it if you can,its the most reliable way. You have some adapters for it ? . Do you have the ch341a black edition,can you check the voltage and make sure it hasn`t got 5V on pin 28.You may need to modify it so it only uses 3.3V https://www.chucknemeth.com/usb-devi.../3v-ch341a-mod .Its possible to flash the EC with the ch341a you`ll need to solder wires to the JEC connector.
        ive done the mod, i read 3volts on all pins but still i cant read the EC chip for some reason.
        foto to mod:
        Im not 100% sure this is the IC chip, can u confirm ?
        Foto to connection EC:
        if i plug programmer into usb and quickly press read id. it reads id, but on reading nothing. writing nothing
        battery is disconnected / power plug disconnected/ motherboard battery disconnected
        Thanks!
          • 21874
          foto to mod:
          Thanks!
          Check the part number on top of the chip, then do a google search with that part number to make sure it is a bios chip. Look in the schematic as well,search for SPI .
          • Pfudaniel
            • Feb 2021
            • 91
            • Netherlands
            Thanks for ur answer once again, i have got the schematic
            But if i press ctrl+f and type SPI. i can only find the 128mbit ( 25b128cs1g )
            i cant seem to find the EC in the schematics ?
            if i check the other chips under the microscope i can see 2 chips with 80,
            25q80csig.
            (https://datasheet4u.com/share_search...Word=25Q80cSIG)
            and on another location at the motherboard 25q80dvsig.
            ( https://www.datasheetq.com/datasheet...ond/25Q80DVSIG )
            the one where i tried to read and flash is the 25q80csig.
              • 21874
              25q80csig.
              The GD25B128C is the bios chip. Notice the Mb ,the capital M means Mega,and the lower case b means bits. Divide 128 by 8 to get 16.Its 16MB ,with a capital B for bytes, MegaBytes.
              https://cdn.badcaps-static.com/pdfs/...75588d6e59.pdf
              GD25B128C 128Mb 2.7V-3.6V 128Mb = 16MB .Bits and bytes are all confusing.
              • Pfudaniel
                • Feb 2021
                • 91
                • Netherlands
                #27
                haha alright i might have figured it out 25q80dvsig is the one i can read and write. i saved the original and flashed the 1.8 now on it including bios 1.8 on the bios chip. il test now and report back
                  • 21874
                  See post #18 posted a few moments before yours. If you made a backup of 25q80dvsig flash it back and leave it well alone.The bios chip in the schematic doesn`t always match with the part number on the board,U4 is the bios chip W25Q128FVSIQ in the schematic.
                  The 25q80 chips are for the thunderbolt firmware and gpu bios .
                  • Pfudaniel
                    • Feb 2021
                    • 91
                    • Netherlands
                    #29
                    yes but i was looking for the EC chip. i believe i found it 25q80dvsig
                    • Pfudaniel
                      • Feb 2021
                      • 91
                      • Netherlands
                      #30
                      alright done, flashed back original. than where shud i flash the EC to ? also on the bios chip ?
                      • Pfudaniel
                        • Feb 2021
                        • 91
                        • Netherlands
                        #31
                        Try these.Flash the EC as well if you have a programmer for it.
                        with just the bios flash the laptop gives 2 red lights, 1 blue.
                          • 21874
                          I said at post #11 the EC can only be flashed through the JEC connector. Whatever you just flashed i hope you made a backup, flash the backup back onto it and leave it alone.Just flash the 16MB bios to the 128 16MB bios chip the GD25B128CSIG
                          • Pfudaniel
                            • Feb 2021
                            • 91
                            • Netherlands
                            #33
                            alright thanks , thats clear now. no EC flashing for me.
                            • kylobeetle
                              • Jun 2021
                              • PANAMA
                              #34
                              Re: dell alienware 15 r3 LA-D751P bios bin
                              Hello there, I think I can help you, let me know if you are around. I have worked with this IC from another dell model.
                              • peste
                                • 13581
                                • ROMANIA
                                #35
                                post the backup of the bios..the original bios of the laptop.
                                • gfd2016
                                  • Mar 2022
                                  Hello! Can anyone help me by chance. I updated both my alienware 15 r3 and alienware 17 r4 with the 1.4 bios a while back and it broke my intel me which in turn, now my usbs don't work and my pc will not shut down unless held power button. I tried to flash both bios files linked in this thread but no prevail. They both result in 2 red flash followed by 1 blue flash. I reflashed my original backup and now im back where I began. I have done the 3.3v mod also. Any help would be highly appreciated!
                                  • peste
                                    • 13581
                                    • ROMANIA
                                    #37
                                    read post # 35 in this thread.
                                    • gfd2016
                                      • Mar 2022
                                      just flashed the 1.8 bios from on here and it works but still have the non working usbs and will not shutdown. Will upload my original backup now
                                      • gfd2016
                                        • Mar 2022
                                        Original bios backup with broke ME which disabled my ports and power shutdown. 3.0 eXtensible Host Controller showing up not working in device manager also
                                        • hoaca388
                                          Badcaps
                                          • Jan 2022
                                          • 12329
                                          #40
                                          Alienware 15 r3
                                          • STKR123
                                            The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                                            by STKR123
                                            Greetings badcaps community,
                                            I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                                            So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                                            Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                                            I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                                            These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                                            I learned that desoldering...
                                            10-29-2024, 06:03 AM
                                          • drux
                                            Alienware Aurora R15 accidentally flashed with XPS 8960 BIOS
                                            by drux
                                            I've had an ssd that was previously used on dell xps 8960 and then it was installed in Alienware Aurora R15(intel version). On first windows boot in R15 windows started bios update and loaded bios for xps 8960(r15 and xps8960 essentially have same motherboards).
                                            Now it has xps 8960 bios that looks different from alienware bios and when I'm trying to run bios update files for R15, I get unsupported platform error.
                                            These models have AMI/Aptio BIOS.
                                            Tried to edit product info with DMI Edit to change values back to Alienware R15, but it does not want...
                                            11-03-2024, 01:18 AM
                                          • hotcrossedbuns999
                                            M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                                            by hotcrossedbuns999
                                            My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                                            1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                                            2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                                            3. I could only locate two chips that look like bios chips. Could someone verify this
                                            01-03-2025, 12:32 PM
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • zlr8r
                                            looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
                                            by zlr8r
                                            looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
                                            cheers
                                            Dell Inspiron 17 (7786) Laptop
                                            Service Tag: 5J0NHT2
                                            Bios: 1.9.0
                                            MOBO: RO 15 17 WHL 2GB MB / 18706-2
                                            Attached;
                                            1. My saved bios using a programmer
                                            2. Dells Bios updater .exe (v1.16)
                                            3. Dells Bios recovery file
                                            4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
                                            5. Image of ME...
                                            12-18-2023, 03:08 PM
