TurboExpress - looking for schematic to diagnose low power to backlight/lcd
  • DrunkenMonk
    • Jan 2021
    • 13
    • England
    So as per the title, I've got a turboexpress here that was recapped with nichicon caps, the fuse and one of the coils was replaced (possibly popped due to an over-voltage or negative voltage?) and the audio is now great but the backlight doesn't show a bright vibrant white like it should, and doesn't look like it adjusts at all using the wheel, but after checking the wheel it looks like it's reading fine, so I can only assume I'm not getting the correct voltage somewhere... FUN
    So I'm not sure if it's part of the coil circuit or one of the regulators since I don't know what they should be outputting or where the backlight circuit is in it's entirety.
    If anybody has some schematics, ideas or even just some chickenscratch notes I'd be very appreciative
    • 31285
    Re: TurboExpress - looking for schematic to diagnose low power to backlight/lcd
    post lots of pictures, i have an idea.
    • DrunkenMonk
      • Jan 2021
      • 13
      • England
      Took two high-ish res photos, there's a couple of scratches into the solder mask on either side where the glue was removed, but upon checking they seem to be just the mask and I've got epoxy to tidy that up after I get the backlight working as intended.
      And here's the backlight when it's turned on at full or low power
        • 31285
        oh shit!
        firstly, look at your soldering - you have atleast 2 bridges.
        second - wtf is going on with those cap sizes??
        and you cant have them on long wires - that's inductive.
        did you ever see the backlight working right btw?
        because i suspect it may use a flourescent lamp like the gamegear and lynx - those wear out.
        • DrunkenMonk
          • Jan 2021
          • 13
          • England
          oh shit!
          The cap sizes are just in place for testing purposes, they'll be replaced with the correct SMDs.
          The lamp itself doesn't seem respond to voltage changes at all, so I don't think it's an issue with the the tube itself so much as the driving voltage, though I'll have to actively test that just to confirm, I'll get back to you on that one.
          I'm not seeing the bridging you're referring to, you'd have to circle the areas you believe there to be bridges.
          The long leads on the caps isn't an issue for this test case and they're specifically on the sound circuit which is running flawlessly
            • 31285
            bridges are not between cap pins, but between caps and other tracks
            the gold one,
            the 22uf c109 on the right,
            • DrunkenMonk
              • Jan 2021
              • 13
              • England
              the gold one,
              Double checked them, and I do see where you mean, but they're just close - I can take pictures from an angle and with the meter on continuity if you'd like to see?
              But I can confirm they are not bridged, that is assuming you meant cc901 and cc704. The tiny bit that looks like it's sitting on top of the silkscreen is just a piece of debris on 901. 704 is just close to the via and not actually touching it.
              Any other ideas?
              *edit - actually I'm going to just use some common sense and try check the coils under t900 and t500 and see if they read right
                • 31285
                whats in the metal shields?
                i dont see a transformer that could drive a tube.
                • DrunkenMonk
                  • Jan 2021
                  • 13
                  • England
                  Yeah the transformers are under the metal shields, I'll be removing them and testing them to see if they read back alright.
                  Q900 is the 24v transformer under the larger shield
                  Q500 I believe is 19v(?) for driving the LCD I'm not entirely positive on this one though. On the inverse of the board there's T900 and T901 which are also related to the backlight circuit, but I'm not sure what they're supposed to read
                    • 31285
                    on the top edge of the board is a teal (blue/green) film cap - it may be related to the tube drive.
                    • DrunkenMonk
                      • Jan 2021
                      • 13
                      • England
                      Yup it is, that BLH bridge is also able to be removed to disable the backlight entirely
                        • 31285
                        i wonder if that cap is still good to pass current.
                        • DrunkenMonk
                          • Jan 2021
                          • 13
                          • England
                          I can remove it and check? But I'm not too sure what it's rating should be
                          • DrunkenMonk
                            • Jan 2021
                            • 13
                            • England
                            Okay I eventually got around to checking, and the larger transformer T900's primary isn't open, but the smaller T500 transformer seems to be testing okay - so I think I'll try find a replacement for T900 at this point or failing that, just replace the LCD with a modern backlit system where I can just tap 5v somewhere for the backlight.
                            *edit:
                            game gear transformer seems perfect for it and I've got a few lying around, huzzah ��
                              • 31285
                              if your adventurous, maybe you could swap the tube out for a tiny led strip.
                              like in the fake "filament" lamp bulbs.
                              does the console run o.k. other than the light?
                              • DrunkenMonk
                                • Jan 2021
                                • 13
                                • England
                                Can't tell with the backlight being so dim, but I can at least hear the sound and hear button presses and etc in games playing the sounds I'd expect to hear, one problem at a time since I know the ram is another point of failure on these suckers aha, if it does end up working I'll clean it all up, put on the rest of the smd caps and leave it stock for now opposed to replacing the ccfl since that way it's still oem looking from the outside.
                                Will update tomorrow(later today when I wake up) if replacing the transformer works though, still not sure if q500 and q900 are okay, the transformer might've taken q900 out with it too
                                • DrunkenMonk
                                  • Jan 2021
                                  • 13
                                  • England
                                  Looks like a solid NO on replacing the transformer, same issue with the backlight being low brightness and the wheel seemingly not changing the brightness any. So I know the transformer is good since I took it from a game gear that it was working fine to drive the ccfl.
                                  I'll swap over that little green film cap too, but I doubt that'll affect anything. It's probably got to be Q500 or Q900, I'll have to get some readings from them to verify they're actually outputting something...
                                  I don't really want to just give up and swap the screen with an LCD aha, but it looks like that's definitely on the cards. The primary is open on this replaced transformer though, so it definitely does seem like something went awry around this area and something probably burnt out...
                                    • 31285
                                    i really think you should see the image on the lcd!
                                    maybe the problem is upstream and some power rail is low.
                                    • DrunkenMonk
                                      • Jan 2021
                                      • 13
                                      • England
                                      I'm pretty sure it's just incredibly dark, but I do have a potential donor pc engine for a video chip if that does end up being a problem too, I've attempted to shine a light at it to see if i I can see anything displaying but the polarization seems a little too strong for the dainty little light from my phone camera aha. I might try hook up a composite LCD without fully modifying the system to get the skinny and see if there's a different story to be told
                                        • 31285
                                        if you can slide out the tube, you could poke a white led into the hole in the reflector
                                        it will be funny if it turns out to be a contrast control problem!
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
                                        • DanPoka
                                          Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                          by DanPoka
                                          I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                          Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                          This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                          02-15-2025, 05:05 AM
                                        • Comp_Pro
                                          No Backlight Macbook A1990 820-01041
                                          by Comp_Pro
                                          Hello all,
                                          Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                          Tests performed:
                                          There is no backlight even with a good screen.
                                          Backlight IC is receiving the correct support voltages.
                                          Fuse F8400 ok
                                          Current sense resistor R8400 ok
                                          Backlight IC is receiving 3.3V on enable pin.
                                          Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                          Backlight IC receiving 5V from PP5V_G3S
                                          Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                          I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                          05-06-2024, 10:23 PM
                                        • cheebster
                                          iPad Pro 12.9 5th Gen Backlight Issue
                                          by cheebster
                                          Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                                          Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                                          Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                                          The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                                          Anyone...
                                          05-20-2025, 09:17 AM
                                        • canadaboy25
                                          LG Flatron 24EN33TA No Backlight When Cold
                                          by canadaboy25
                                          I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
                                          I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
                                          03-07-2023, 12:23 AM
