DELL N5010 discrete to uma conversion
  • elwess93
    • Jan 2021
    • 7
    • tunisia
    hello!
    i'm kinda new to this and i found this picture/tutorial, can anyone give some simple instructions since there are some yellow squares that don't say what must be added and i didn't understand "remove green shild of pcb and connect to near capacitor pin"
    if someone could spare me some time to explain things it would be much appreciated.
    thanks in advance
  • stingerchamp
    • Sep 2020
    • 425
    • Pakistan
    Re: DELL N5010 discrete to uma conversion
    This is very well explained
    Follow a,b,c,d,e,f,g,h,I,j.
    A is first step
    It is asking to remove and add some resistor and a crystal and remove a ic etc
    Find schematic and you will find same written in schematic with blue colour UMA
    A few extra added here rest is same as schematic
    • lapfix
      • Mar 2020
      • 2715
      • my workshop
      There's many video in youtube about this classic conversion that can help you .
      But before this be sure that the problem is a graphic
      • elwess93
        • Jan 2021
        • 7
        • tunisia
        thank you all for your answers, some letters can be found twice so if for example there's A with red and A with yellow that means i should take that component from red and move it to yellow respecting the same
        letter? am i understanding this right? and how about that "remove green shield...." sentence what should be done there? ( in simple terms please) and thank you
        • stingerchamp
          • Sep 2020
          • 425
          • Pakistan
          Yes yellow is addition
          Yes red is to remove
          I think Green shild is light green lines which connect components
          • elwess93
            • Jan 2021
            • 7
            • tunisia
            i understand now thanks a lot, one last question what should i connect here? sorry if i asked a lot of questions
            thanks again
            • Sametbey
              • Jan 2021
              • 229
              • Turkey
              juper add
              I'm not happy to be so strong. because it's not humanly
              • elwess93
                • Jan 2021
                • 7
                • tunisia
                thank you ALL for your help, i appreciate it.
                • elwess93
                  • Jan 2021
                  • 7
                  • tunisia
                  Originally posted by Sametbey
                  juper add
                  thank you.
                  • stingerchamp
                    • Sep 2020
                    • 425
                    • Pakistan
                    After successful completion
                    Do share results
                    Good luck
                    • Mert38
                      • Feb 2020
                      • 15
                      • Turkey
                      Do we need uma bios for this new conversion?
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        No
                        • Mert38
                          • Feb 2020
                          • 15
                          • Turkey
                          I did this way to motherboard but now when I plugged the adapter, mobo draws 0.15 amps and 3v-5v chip gets hot. What should I do? I already changed it.
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            check resistance on VREG3/Vreg5
                            • Mert38
                              • Feb 2020
                              • 15
                              • Turkey
                              Vreg 3 is 194 Kohms
                              Vreg 5 is 186 kohms
                              • Mert38
                                • Feb 2020
                                • 15
                                • Turkey
                                Before doing uma conversion, Mobo was woking fine. Just gpu was dead and coming 8 beeps. I decided to do Uma but now Mobo not coming on. No start, power PU 4601 gets hot I dont Know why...
                                • Mert38
                                  • Feb 2020
                                  • 15
                                  • Turkey
                                  I changed nuvoton chip. When I disassembly the nuvoton, short was gone. But I soldered new chip, results same. Still shorting somewhere
                                  • lapfix
                                    • Mar 2020
                                    • 2715
                                    • my workshop
                                    Try to identify the short area..after you can proceed to solve it
                                    • Mert38
                                      • Feb 2020
                                      • 15
                                      • Turkey
                                      I identified the short area. İn the picture, caps around chip shorting. I removed chip but short not gone. What is the meaning of this situation?
                                      • Rezvan666
                                        • Oct 2021
                                        • 3
                                        • Iran
                                        Hi.do we connect them like this?
                                        thank you
