i have bios dump file and share it for all
					Lenovo G50-45 - BIOS
	Tags: None
Re: Lenovo G50-45 bavklight problem
why so seriousAttached FilesIm Back... sort of...
Hi
Bios + ECLast edited by SMDFlea; 10-17-2020, 02:08 PM.Comment
			by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
I am attempting to remove the WWAN card whitelist from my Lenovo ThinkPad T560.
Initial Findings:- My current BIOS version is N1KET58W (1.45).
 - I have a CH341A programmer and have successfully created two full backups of my BIOS.
 - I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
 - I concluded that the
							Channel: BIOS Requests ONLY!
08-12-2025, 03:01 PM -
			by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
			by grimacelordHello there.
I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
History:
1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
I searched for this error online and discovered...-
							Channel: BIOS & Schematic Requests!
			by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
I have opened the laptop and identified the main BIOS chip...2 Photos-
			by mkdjDear all,
I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
Here the steps I have taken to fix the laptop:
- downloaded latest BIOS from Lenovo Website... - Loading...
 - No more items.
