Nvidia Shield TV 2017 Dead
  • mmartell
    • Oct 2013
    • 3189
    This is the one with the 19v supply with the proprietary connector. Looks like a USB-C but it is not. There are many complaints of this adapter failing. I cracked mine open and found a vapourized trace. After repair it puts out the required 19v.
    When plugged in Q16 is heating quickly and shutting off and that cycle repeats. I can't tell if this ic is functioning as intended due to a short further down the line because I can't find information on it. It is labelled as 1054P I think.
    Can anyone identify this chip ?
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8146
    Re: Nvidia Shield TV 2017 Dead
    take q16 out and fire that thing up.
    • mmartell
      • Oct 2013
      • 3189
      Will do!
      • mmartell
        • Oct 2013
        • 3189
        With Q16 removed I have 19v on pad 4 and zero on the rest. A continuity test shows pads 1, 2, 5, and 6 shorted to ground.
          I would check and see if any of the pin that shows shorted to GND to see if it is connected to any MLCC hoping for just shorted MLCC.
          • mmartell
            • Oct 2013
            • 3189
            You can't see on the pics but those four pads that are shorted are all tied together. I didn't notice it myself until now. Q15 is a dual channel mosfet which I removed and does not test shorted.
            There are three mlcc's that test short so I guess that's my next step. Thanks bud.
            • mmartell
              • Oct 2013
              • 3189
              There are more shorted caps along the back of the board near the ports, too many to start removing them. There are no shorted caps in the other areas including the cpu/gpu.
              Would it be ok to inject some voltage at the drain of the removed mosfet or at the large filter coil in pic 3 ?
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8146
                I figured that there is something else short. With a CV CC bench psu set it to 3.3 or 5V and 1A, hook it up and wait 30 seconds, then feel around for heat or douse area of interest with 91% IPA and watch for bubbles. Dont crank the psu, just wait. A shorted MLCC will get hot. It only gets tricky when there are MLCC's in parallel.
                Iam guessing it didn't boot with it disconnected? Are you sure you got a short there somewhere?
                • mmartell
                  • Oct 2013
                  • 3189
                  Some caps are shorted to ground, yes, there is a short somewhere.
                  No it didn't boot with the 1054P removed. That ic is some current sensing chip or was acting like one, resetting every half second or so.
                  • CapLeaker
                    Leaking Member
                    • Dec 2014
                    • 8146
                    there are 2 ways finding that short. Either inject power and wait for that offending part to heat up, or with very good ohm meter that can measure milli and micro ohms similar to a leakseeker 89 etc.
                    • mmartell
                      • Oct 2013
                      • 3189
                      When using ohm meter method do you use a common ground or do you measure across a device, like both ends of a cap ?
                      • CapLeaker
                        Leaking Member
                        • Dec 2014
                        • 8146
                        that ohm meter trick doesn't work with any ohm meter. It would need to read 4 digits past the decimal point. Just measure from a point that you know is shorted and start measuring all caps on that rail and look for the least resistance.
                        A while back I fixed a PSU that didn't want to turn on. It ended up being a shorted MLCC in a parallel group of 3 or 4. I used the power feed and IPA method.
                        HERE: https://www.badcaps.net/forum/showthread.php?t=82995
                        another one I used that trick on:https://www.badcaps.net/forum/showthread.php?t=73826
                        • mmartell
                          • Oct 2013
                          • 3189
                          My esr meter reads low ohms. I'm going to read up on the method.
                          • CapLeaker
                            Leaking Member
                            • Dec 2014
                            • 8146
                            low ohms on an esr isn't a bad thing, that doesn't mean there is a short. You have to look at the DCR for a short if you look with an ESR meter. IF your ESR meter has that function.
                            • mmartell
                              • Oct 2013
                              • 3189
                              No, the esr meter also reads ohms when it doesn't detect capacitance. Since I'm checking a circuit with a short the caps don't charge up and it measures the resistance of the path to ground.
                              • mmartell
                                • Oct 2013
                                • 3189
                                So I thought more about this and for anyone having the same brain block as I was I've determined you can use ground anywhere on the board since the shortest path will always be through the shorted component and the return to your ground location will always be the same path.
                                • CapLeaker
                                  Leaking Member
                                  • Dec 2014
                                  • 8146
                                  That only works IF it is shorted to GND. If it isn't shorted to GND, then you have to fine the shorted line first.
                                  • mmartell
                                    • Oct 2013
                                    • 3189
                                    Yes that's a very good point !
                                    • mmartell
                                      • Oct 2013
                                      • 3189
                                      I found and removed a shorted mlcc under one of the shields. I still have a bank of shorted caps so still have a short somewhere else. Problem is I can't trace the vcc line because I can't see the traces and I can't identify the chips I've removed so I'm kind of at a loss where to inject voltage.
                                      Help!
                                      • mmartell
                                        • Oct 2013
                                        • 3189
                                        Last edited by mmartell; 10-16-2020, 10:01 AM. Reason: deleted due to being gibberish...
                                        • badboyzzz
                                          Nvidia Shield P2897 dead
                                          by badboyzzz
                                          There is a problem with nvidia shield 2019 p2897. The lights of the device are on but there is no voltage in the red marked areas. The green areas are normal and the chip in the yellow area is heating up in long-term voltage. Does anyone have a diagram or an idea? Thanks in advance
                                          04-05-2025, 03:56 PM
                                        • piernov
                                          NVidia bumpgate
                                          by piernov
                                          Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
                                          Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
                                          May complete this post at a later date with more details.
                                          Basically issue is a combination of thermal dissipation of the chip with hotspot,...
                                          03-27-2021, 10:34 AM
                                        • badboyzzz
                                          Nvidia Shield 2019 - P2897 power on but no display
                                          by badboyzzz
                                          04-11-2025, 08:17 AM
                                          NVIDIA GeForce RTX 3080 / RTX 3090 Schematic & Board View
                                          The GeForce RTX 3080 is an enthusiast-class graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA102 graphics processor, in its GA102-200-KD-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA102 graphics processor is a large chip with a die area of 628...
                                          10-02-2024, 08:52 AM
                                          NVIDIA GeForce RTX 2060 / RTX 2070 Schematic & Board View
                                          The GeForce RTX 2060 is a performance-segment graphics card by NVIDIA, launched on January 7th, 2019. Built on the 12 nm process, and based on the TU106 graphics processor, in its TU106-200A-KA-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 2060. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The TU106 graphics processor is a large chip with a die area of 445...
                                          10-02-2024, 07:51 AM
