lcd monitor mgc vt17w7x cam some one tell what two transistor are
  • aubrey52
    • Nov 2009
    • 29
    i found two transistor shorted by inverter comeing off high voltage transformer.this monitor have two high volt transformer.
    here is parts number on transistor one KDQR
    sec one is KDQT. both or smd i need cross to a replacement parts
    let know
    thanks
    Aubrey
    went it came in had bottom back light blinking on an off just two right side
    bottom back light
    very litte blinking
    i foun two transistor shorted
    what i need to know is what transistor do need
  • aubrey52
    • Nov 2009
    • 29
    Re: lcd monitor mgc vt17w7x cam some one tell what two transistor are
    lcd monitor mgc vt17w7x[/SIZE]
    went it came in had bottom back light blinking on an off just two right side.
    bottom back light very litte blinking. no power light.
    i found two transistor shorted in inverter board. under bottom by high voltage
    transformer.this uint have two high voltage transformer
    what i need to know is what transistor,s can i use to replace
    her some pics
    let know
    thanks
    Aubrey
    • PlainBill
      • Feb 2009
      • 7034
      Re: lcd monitor mgc vt17w7x cam in some one tell what two transistor are
      let know
      thanks
      Aubrey
      bottom back light
      very litte blinking
      Somewhere around is a thread where I chronicled the search for the identity of those parts. KD is Rohm's designation for 2SC4672, the Q designates the high gain version, while the last character is a production or date code of some sort.
      I have found the parts on eBay for about $7.00 + shipping, but if you are in the US you may prefer ordering them from Digikey, their stock number 2SC4672T100QCT-ND at $.72 each.
      PlainBill
      • aubrey52
        • Nov 2009
        • 29
        PlainBill
        thanks you very much i will place order with digikey
        i have 4 kdqp transistors at such work right.
        aubrey52
        you have a very good day
        • aubrey52
          • Nov 2009
          • 29
          Re: lcd monitor mgc vt17w7x are mgc A710 cam in
          remove c101 100uf at 25 volt it over by t101 high voltage transformer.
          and by cn101 cn 107 plug i mark it red in pics change with 100uf at 50 volt must be 105c rate cap do not use a 85c cap it will not last.
          clean all gule off of board best you can. i found at cap was bent over and gule
          cross too of jumpers went replace put cap c101 back in up right don't
          bent it cross the jumpers you have to bent jumper litte bit fit cap up right.
          res i telling all of you i thanks at what shorted out Q112 and Q113.both are under board, mark in blue
          by inverter. went place transistors replace 4 of him. you have two more by t102 high voltage transformer
          Q115 and Q116 under board.
          are mark KDQR and KDQT all 4 same transistors npn replace with 2sc4672 or 2SC4672Q.order from digikey.
          after bill told me what number i need i had 4 KDQP.i hop this help all you guy out they.
          aubrey52
          i would thank
          PlainBill for help finding cross to my transistors
          same kind i had 4 KDQP work 100 %.
          here some pics of transistors
          • keepread
            Dell monitor PSU vs Dell laptop PSU
            by keepread
            Hi there!
            Someone gave me their old monitor, it's Dell S2715ht.
            The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
            Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
            10-30-2025, 04:45 PM
          • wattage
            AOC AG493UCX 49-inch monitor - Firmware request
            by wattage
            Hello Badcaps Community,
            I purchased a preowned AOC monitor that is not working and out of warranty. It was sold as not working. I am looking for guidance on self-repair. In particular, I am after the firmware for the monitor. At the end, I have included monitor model information and links to pics and vids of the issue.
            The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
            07-13-2025, 04:41 PM
          • ant3202
            HP 27es - LED monitor - Monitor Flashing On - Off
            by ant3202
            Hi Everyone
            Lately I am experiencing the deja-vu incident on one of the led monitor like this.
            https://www.badcaps.net/forum/troubl...lashing-on-off
            The monitor is HP 27es LED Monitor
            https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
            The monitor will randomly blackout and display no signal and will recover again.
            Sometimes need to power and off again to restore the display but...
            03-20-2025, 07:30 PM
          • Rick_1234
            LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
            by Rick_1234
            Good evening, gentlemen.
            I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
            To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
            https://drive.google.com/file/d/1L6S...ew?usp=sharing
            Things I tried
            - Bought a new AC adapter thinking that was the problem but the problem...
            06-22-2024, 04:44 PM
            Wise Wing F199 19'' LCD monitor - recapped
            by momaka
            Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
            I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
            When I saw the Craigslist post, I wasn't...
            08-24-2020, 10:58 AM
