Harman Kardon AVR 370
  • Technik92
    • Dec 2016
    • 16
    • Polska
    Hello, I have a problem with the harman kardon AVR 370 does not start after turning on, it immediately turns off, I borrowed the power supply from a colleague and its power supply works, so the reason will be in my power supply.
    Has anyone had a problem with this power supply or has it repaired and knows which part could get stuck in it?
    Re: Harman Kardon AVR 370
    Did you look for service manual?
    https://elektrotanya.com/showresult?...oria=&kat2=all
      BTW, you also need to attach some pictures for us to look at so we can see what we are dealing with.
      • bluebear
        • 90
        Depends what you mean by "immediately turns off".
        Check capacitor C983 and C939, they seem to fail fairly regular. Without any more specific details its hard to say.
        • Technik92
          • Dec 2016
          • 16
          • Polska
          after disconnecting the -50 V and + 50 V bus connector, the receiver starts without problems. Below are links to movies where I show the problem and 2 movie on which the receiver works after disconnecting the 50v plug.
          https://www.youtube.com/watch?v=KyDg...ature=youtu.be
          https://youtu.be/6l0qi-I6M2k
          • R_J
            • Jun 2012
            • 9535
            With CN20 disconnected from the amp board, what voltage do you measure on CN20 on the power supply? There are two seperate smps's for the +/- 50v, they are basically identical except for where the -50 takes its output. so it should be easy to check components between them.
            • Technik92
              • Dec 2016
              • 16
              • Polska
              Black and red = 54V
              Black and white = 54V
              White red = 107V
              The power supply is functional because I have a spare one.
              When I pull this tape, it runs without promblem
              • R_J
                • Jun 2012
                • 9535
                Originally posted by Technik92
                Black and red = 54V
                White red = 107V
                You said the problem is in your power supply and NOW you say it is Functional? which is it?
                When you tried your friends power supply in YOUR amp, did you have audio from ALL speaker outputs?
                Last edited by R_J; 04-11-2020, 12:01 PM. Reason: Something is causing double posts sometimes
                • Technik92
                  • Dec 2016
                  • 16
                  • Polska
                  Sorry, I checked the power supply recently because I forgot to connect 50v.
                  Tomorrow I will check if the sound is.
                  I will look for the problem of this short circuit because when I connect the tape, it is short circuit immediately
                  • Technik92
                    • Dec 2016
                    • 16
                    • Polska
                    I checked and no sound.
                    I think I have already found the reason for the short circuit at the SURR LEFT speaker output after turning on the power was 54v and dropped to 27v as in the photo after desoldering 2 ends B1647 and D2560 the amplifier works and I think I will order these 2 parts burned tomorrow
                    • R_J
                      • Jun 2012
                      • 9535
                      Make sure to check the dual emitter resistors and also the 3.3Ω base resistors. If the base resistors are open, you would need to check the driver transistors also. You should also check R821 & R822 (18Ω) If you are lucky only the outputs are bad
                        Originally posted by r_j
                        make sure to check the dual emitter resistors and also the 3.3Ω base resistors. If the base resistors are open, you would need to check the driver transistors also. You should also check r821 & r822 (18Ω) if you are lucky only the outputs are bad
                        +1
                        • Technik92
                          • Dec 2016
                          • 16
                          • Polska
                          Ok, I'll check it tomorrow
                          Through these 54v I have damaged the central speaker CEN-TS60 and the loudspeaker already has someone else suggest what could have fallen in the inverter?
                          Such parts are there:
                          3.6uf 100v
                          2x 4.7uf 100v
                          26uf 100v
                          200uf 100v
                          10w40ohm
                          10w2ohm
                          • Technik92
                            • Dec 2016
                            • 16
                            • Polska
                            Hello, I replaced these damaged parts now starts and after 10s turns off by itself
                            • R_J
                              • Jun 2012
                              • 9535
                              What damaged parts did you replace? Did you just replace the 2 transistors?
                              Check the voltage on pin 1 &2 of CN66? This is connected to the emittter resistors, check this voltage before the amp shuts down.
                              • Technik92
                                • Dec 2016
                                • 16
                                • Polska
                                So I replaced 2 transistors B1647 and D2560 + R817 3.3Ω.
                                Voltage on pin 1 & 2 CN66 = 17,2V
                                • R_J
                                  • Jun 2012
                                  • 9535
                                  That voltage on CN66 should be close to 0 volts.
                                  If R817 was damaged (open) then you need to check all the driver transistors and resistors. Check Q856,Q876,Q886,R786,R776 and all the the other transistors and resistors in that part of the circuit. You can compare values with a working channel.
                                  • Technik92
                                    • Dec 2016
                                    • 16
                                    • Polska
                                    ok Q856 is broken tomorrow I will buy these hi the rest seem ok
                                    • Technik92
                                      • Dec 2016
                                      • 16
                                      • Polska
                                      You can recommend a replacement because I can't buy the same model anywhere HVTKTD600KGR
                                      • Technik92
                                        • Dec 2016
                                        • 16
                                        • Polska
                                        ok i found and ordered 2SD600K Y TO126 NPN 100V 1A 130MHz
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • PowellSkier
                                          Harman/Kardon AVR 645 returning to stand-by after a few seconds.
                                          by PowellSkier
                                          A Harman/Kardon AVR 645 repair has been a hobby of mine for the past several years. My latest attempt involved the purchase of a DOA unit for part swapping and testing. The original AVR would power up then shut down after a few seconds. I completely tore down both units, found a couple of bad components and reassembled one of them. Same issue, no speakers connected. After extensive research I found a repair document from Harman/Kardon that explains the protection circuit in fantastic detail and provides specific test points for each fault (power, DC detection, overload & power) and the voltage...
                                          06-17-2024, 11:43 AM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                        • funky2x
                                          Harman kardon onyx studio 7 Smd code
                                          by funky2x
                                          Cant find what smd code Y0DVA.
                                          sitting in Harman kardon onyx studio 7. Appreciate any help.
                                          05-29-2025, 03:44 PM
                                          by sam_sam_sam
                                          07-01-2024, 06:34 AM
