Hi guys, i need the datasheet of this mainboard or if anybody can help me to identify a burned chip. Really apreciated! I only can read MS6V
Need datasheet HP G3 mainboard DAX63CMB6D1
Tags: None
Re: Need datasheet HP G3 mainboard DAX63CMB6D1
Sy8208bOpenBoardView — https://github.com/OpenBoardView/OpenBoardView -
by MireniaHi everyone,
I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled... -
by orcicHello,
I have an old MASTER TL-240 LED TV. Since it stopped working and it had a DVB-T receiver that is being dismissed in Italy, I've decided to replace the mainboard with a DVB-T2 one.
The original problem was that when switching on the TV, the power LED was transitioning from red to steady blue, without showing video or audio.
After checking some voltages on the power supply board (HKL-240101-B Rev. 1.4, HKL from now on) someone suggested me to replace the mainboard.
Now I have some doubts about how to connect the new mainboard to the old power supply.
First of... -
by mikey5791Hi to all forum members,
Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor... -
by DevonavarI have a Vizio M43-C1 stuck in a reboot loop with no backlight.
I've tested all the voltage rails coming out of the power supply and they are "normal" for this model (PS_ON & DIM go high when turned on, BL_ON & 3D_ON are close to zero due to backlight power flowing through the mainboard, 5VSB is 5V, and 12V is 19V, which is apparently normal for this board).
Basically, I get similar results to Garry in this post: https://www.badcaps.net/forum/showthread.php?t=80346
So, I've ruled out the PSU for now.
The reboot loop... -
by MalvaHi everyone,
I'm trying to repair my LG 49UB850V TV (WebOS 1.0, UHD model from 2014).
Mainboard model: EAX65684604
PCB marking: EBT62954607
SPI chip: Winbond W25X20CLNIG Problem description:
Originally, the TV would turn on (backlight and LED OK if I force them on), but it shut down as soon as any input was received from the IR sensor or remote. The backlight and power board were working fine.
After testing and verifying the voltages (DRY ON, PWR ON, 12V/24V rails), I suspected a corrupted SPI firmware. What I tried so far:- I bought another
- Loading...
- No more items.
