Da0zrwmb6g0 rev g 14 volts reading
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    I have a 14v reading from the charger to the PR213 , Ive tested the charger it has 19v reading What may be the problem?
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Da0zrwmb6g0 rev g 14 volts reading
    PQ22 gate voltage?? Remove PR213 and see you get 19V on pq22 side. Measure resistance on both pads of PR213 after removing the resistor.
    • kalilinux25
      • Mar 2018
      • 2089
      • ZAMBOANGA SIBUGAY
      Im having 10 mega ohms
      • kalilinux25
        • Mar 2018
        • 2089
        • ZAMBOANGA SIBUGAY
        Yes im having 19v
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Resistance on both pads of pr213 after removing it?? You just mentioned 10 mega ohms. Which side??
          • kalilinux25
            • Mar 2018
            • 2089
            • ZAMBOANGA SIBUGAY
            From Vin Side
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              From Vin Side
              What about the other end??
              • kalilinux25
                • Mar 2018
                • 2089
                • ZAMBOANGA SIBUGAY
                6 megaohms
                • nurhan
                  • Jan 2015
                  • 26
                  • Turkey
                  Thanks for shared boardview file. I solved my problem...
                  • Sergio Kub
                    • Jul 2018
                    • 176
                    • Brasil
                    Thanks a lot !!!
                    • u666sa
                      HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
                      by u666sa
                      Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
                      Platform: ipa32 la-m024p rev 1b
                      Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
                      I found a short on the other side:
                      10-04-2025, 05:03 PM
                    • supermattch
                      HP 15dy-2021nr wont power on mystery volts
                      by supermattch
                      Hi everyone.
                      I am diagnosing my personal laptop, because it wont power on and no leds light up.
                      At the dc-in there are 8 pins, 1 and 2 shows healthy 19.66 volts. The next three are ground, but the 6th one shows .283 volts. This is strange to me, it should be 3.3 or 5 or aome volts not 0.283v. As I am new to this, I would like some guidance. Please someone advise me on what to check next.
                      Oh the boardview and schematics I am using is for a similar model as I cannot find the proper one anywhere. Quanta DA0P5HMB8F1 rev F. Nowhere on the internet.
                      09-23-2025, 12:13 PM
                    • MisterAIL
                      PS5 digital / No Power / No Beep / Good power supply
                      by MisterAIL
                      Hi everyone,
                      Brought a non functionnal PS5. Apparently only a bad PSU...
                      No beep, nothing.
                      After some tests i found this :
                      - PSU is fine (12 volts stable)
                      - 12 volts line is shorted
                      - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                      - By the way, nothing change. No signal, no power, no beep.
                      Mesuring all rails with my workbench psu (12 volts input)
                      - 0.00 amp drawing
                      - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                      03-12-2024, 03:24 PM
                    • Mcfeetroy
                      Fishing bite alarm drains battery
                      by Mcfeetroy
                      Good day to all. The bite alarm drains 9-volt Krona batteries. Current consumption when switched on is about 50 mA. I wiped the board from oxides, I will attach a photo (on the board there is a j3y transistor and a 7533 stabilizer, the microcircuit is erased = (the 3.3-volt stabilizer heats up weakly. I replaced it, nothing changed. I unsoldered the microcircuit, the consumption disappeared. The resistance on the pins of the unsoldered microcircuit from the point clockwise is more than 2 megaohms, the 11th leg is presumably ground. I warmed up the microcircuit, the consumption does not change....
                      08-01-2025, 03:52 AM
                    • BTubbs200
                      Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
                      by BTubbs200
                      Dell Latitude 5420 P137G
                      Board: LA-K491P REV A01
                      I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
                      Board seems to have no shorts, all power rails are fine and show high resistance.
                      When charger is plugged in, voltage is present in 3.3V rail but absent in others....
                      01-24-2025, 08:15 PM
