Surface 4 pro 1724 corrupted bios
  • jasko_jacker
    • Oct 2014
    • 1140
    • italy
    Hi, it's very difficult to find a worked bios dump for this model due to bootguard enabled and other things (I read this info from winraid forum) so I decided to made a clear ME but with no success. I don't understand the error message that ME analyzer return. Someone can to try to repair this file ? Thanks
  • Claudiomfa
    • Nov 2015
    • 455
    • Portugal
    Re: Surface 4 pro 1724 corrupted bios
    This is your dump bios or the new bios file that you have download?
    • jasko_jacker
      • Oct 2014
      • 1140
      • italy
      my dump
      BOARD X911788-008 MODEL 1724
      • Claudiomfa
        • Nov 2015
        • 455
        • Portugal
        Try and report..
        • piernov
          • Jan 2016
          • 4439
          • France
          Make sure you always use the latest version of MEAnalyzer.
          • jasko_jacker
            • Oct 2014
            • 1140
            • italy
            Originally posted by Claudiomfa
            Try and report..
            Your Clear Bios as the same behavior as other Bios I have downloaded but at least it's the original. (Thanks) . Probably it's works but the system stuck on red bar with open lock and surface logo. I don't know if there are other hardware problems, but the operating system won't load. I don't know how to update the EC because on this card I can't find it's memory that they say is a 25w20. Probably with vertyanov and keyboard connector ?
              • 22283
              Try this repaired bios .
              EDIT: if it still boots to the red red stripe shut down completely, then holding volume up rocker press the power button, do not let go of the volume rocker until the Surface Logo appears, that should get you into the bios, then enable secure boot.
              • jasko_jacker
                • Oct 2014
                • 1140
                • italy
                Seem as the volume + button don't take any effect, you know how reprogramm ITE ?
                  • 22283
                  No, don`t know how to program ITE on this motherboard. Here`s one more bios to try;
                  • ddhlawi
                    • Feb 2017
                    • 169
                    • algerian
                    Can one help me i have surface 1724 corrupted bios
                  • farouk_1994
                    • Mar 2021
                    • 400
                    • algeria
                    Try this file than replay
                    • shadow666
                      • May 2017
                      • 116
                      • UAE
                      Hello
                      i have Surface Pro 4 256GB i5
                      Model 1724
                      Motherboard Model : X911788-008
                      Problem is power on surface and blank screen
                      i have test any backup on this topic , suface is powered on but on top screen yellow line is displayed
                      According to the posts in this thread, I understood because change bios It happens​
                      Code:
                      https://www.badcaps.net/forum/troubleshooting-hardware-devices-and-electronics-theory/troubleshooting-laptops-tablets-and-mobile-devices/bios-requests-only/72031-surface-4-pro-1724-corrupted-bios
                      please fix this backup
                      thank you
                    • dutchgaucho
                      • 65
                      • The Netherlands
                      Hi guys,
                      I have a Surface Pro 4 with corrupted BIOS.
                      s/n: 029173654553
                      SMD Flea's bios with clean me is working, however the touch firmware is not compatbile with my device. Could somebody please assist?
                      Thanks!
                      • dutchgaucho
                        • 65
                        • The Netherlands
                        Somebody please? The legendary SMDFlea maybe?
                        • dutchgaucho
                          • 65
                          • The Netherlands
                          Hi guys,
                          Surface Pro 4 with corrupted BIOS here. Tried SMDFlea's BIOS with clean ME and works flawlessly but touch aint working so apparently that one has another touch firmware. Not sure in which section I can find and copy paste this in HxD so I need your help. I've my BIOS attached together with the one of SMDFlea.
                          Thanks in advance!
                          Model: 1724
                          s/n: 042133171153
                            SMDFlea commented
                            Editing a comment
                            Thread merged.
                        • Issiak87
                          • Sep 2021
                          • 15
                          • Bénin
                          i need help please to remove uefi passwordfrom this bios .the serial number is:058697772053
                          THE UEFI system is 231.1662.769 and the TOUCH FIRMWARE is 2.165.0.1.85.0. thanks
                          • jozlar
                            • Mar 2022
                            • 59
                            • tbilisi
                            1724 surface 4 pro please unlock password
                          • FalconPunch
                            Surface Pro X 1876 Bios corrupted
                            by FalconPunch
                            Hello everyone, I happen to have a Microsoft Surface Pro X 1876 in my hands. It was brought to me by a friends which happen to have taken off the bios chip to test another motherboard. Upon putting back the bios chip on the original motherboard, The PC is stucked on Windows logo and won t boot to bios or anything. I suspect that the changes of bios chip somehow corrupted the firmware inside. Is the hypothesis correct?
                            Also i extracted the bios inside the chip which was on Winbond 25R128JWPQ you can find the file attached if you can fix it (if possible, I would like some insight on...
                            08-09-2025, 03:56 AM
                          • zlr8r
                            Hp Zbook Firefly 14 G10 - corrupted Bios's ? - please check
                            by zlr8r
                            Greetings
                            I am hoping someone could have a check of my Hp Zbook Firefly 14 G10 , 2 x 32MB Bios files... (powers on / black screen).
                            Serial Number: 5CG3202C16
                            Product #/SKU: 739P0AV
                            CT Number: PRTUE00WBI30YX
                            Description: HP ZBook Firefly 14 inch G10
                            BuildID: 23WWWGAZ602#SABU#DABU
                            Feature Byte: 476J6S6b7B7M7Q7U7W7m7saBaEapaqauawbUbhcAfPgSguhKj4jhk8mEn7nVngpDpVpWpnpqprqMqkqz.G3
                            MAC address not found.
                            • I extracted both 32mb bios files (Main + EC). But when i run the main 32mb bios through MFIT.exe , it produces this error; ie:,
                            10-28-2025, 01:56 PM
                          • macabook
                            by macabook
                            🧩 Initial Issue
                            07-24-2025, 02:17 PM
                          • TylerHyde21
                            Lenovo TD350 ThinkServer BIOS v505 Corrupted BIOS,
                            by TylerHyde21
                            Hello, the bios on my Lenovo TD350 ThinkServer got corrupted during a bios update, the bios restore function killed the Server.
                            I need to flash the bios inside the MX25L12835F SOP8, i have already desolder the chip and solder it into my SOP8 adapter and read it with a ROM programmer.
                            I use the innoextract 1.9 software to extract the bios file from the .exe file that i download from lenovo website, can you help me edit the Hex file (removing the Index part and resize the file)?
                            This guy claim to have done it https://forums.lenovo.com/t5/ThinkSe...doesnt-Start-u...
                            06-29-2024, 10:38 AM
                          • Loli Popu
                            DELL LATITUDE 5590 BIOS CORRUPTED BY CH341
                            by Loli Popu
                            Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
                            12-13-2024, 08:29 AM
