Help Diagnosing Backlight Voltages (JVC LT-50C550)
  • sickboy
    • Jun 2015
    • 86
    Wondering if anyone can help me understand the diagnostic process when deciding if the backlight supply is faulty or the backlights themselves.
    This is a JVC LT-50C550 which uses a TV5001-ZC02-01 power supply. The symptoms are just a brief flash of backlights at switch on.
    Voltages at switch on both white wires (to chassis ground) spike at 138v then settle down to 95v. Voltage on both red wires (to ground) are 45v.
    Strangely there is zero volts when measuring between white & red wires on either or both pairs. Can anyone give me an idea what's going on?
    Specific help on this particular tv is welcome, but I'm more trying to understand the thought process behind deciding whether the fault lies in the LEDs or the supply.
  • neilc6
    • Nov 2015
    • 1550
    Re: Help Diagnosing Backlight Voltages (JVC LT-50C550)
    Most TV power supply LED driver circuits (Samsung is an exception) will detect over or undervoltage caused by shorted or open LEDs in a string, and shut down the backlight if a problem is detected. With your power supply, the leds have two wire pairs so likely wired as two separate strings. Googling LED strips for your model shows your TV has 12 strips of 6 leds each so total of 72 leds. Each string should have 36 leds. With 2.7V drop across each led (some use 6V leds), each string should have approx 97V of voltage drop which can be confirmed with an led tester.
    I just got a UN58H5202 in and measured 79V on both strings with my led tester. The expected voltage is 113V based on number of leds so there are approx 12 leds shorted on each string just based on measurement.
    https://tvledbars.com/product/replac...c14-01a-12pcs/
    • sickboy
      • Jun 2015
      • 86
      Brilliant, thanks Neil, so does that mean with each of my strings boosting to 138v, then settling back to 95v that my power supply is working correctly and I have an open or short circuit LED?
      I usually just see no backlight and go straight for opening the screen and testing the led strips, but I'm trying to be a bit more methodical about it.
      • sickboy
        • Jun 2015
        • 86
        Anyone?
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          If the set is not powering off, you could check to see if there's an image on the screen by carefully angling a flashlight on it.
            What do you get if you only have one LED connected one at a time?
            • sickboy
              • Jun 2015
              • 86
              Thanks guys, I won't have access to the TV again till tomorrow but will let you know. Appreciate the advice!
              • sickboy
                • Jun 2015
                • 86
                Hi sorry for the delay. There's no change with either one of the plugs disconnected, still spikes at 138v then settles down to 95v
                Does this indicate that the supply is running correctly?
                • sickboy
                  • Jun 2015
                  • 86
                  Update....
                  Decided to dismantle to screen to check the LEDS and managed to tear one of the tab bonds by accident... TV is now junk.
                  Just for the record though I went ahead and tested the strips, and every single one of them had at least 1 led not lighting up, some had as much as 4 or 5 failed leds
                  • neilc6
                    • Nov 2015
                    • 1550
                    Normally in tvs with protection circuits, I usually find 1-5 bad leds. In tvs without protection circuits (Samsungs), 50 to 90% will be bad. Measuring with a led tester from the back, it is not uncommon to only measure 3V on a whole string.
                    Here is the UN58H5202 I mentioned before. There would be more LEDs out if they didn't cause the FET to fail in the power supply. Picture mode was set to Dynamic (100% backlight).
                    • elpiko
                      • May 2020
                      • 25
                      • Seychelles
                      but what if you tested the strips and all lighting up correctly but you still get the volatge drop. even when the leds are not connected i get the voltage spike and then drops
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        See your other post.
                        • Ukdigger
                          • May 2020
                          • 121
                          • England
                          My TV shows the JVC logo for a couple of seconds and then no picture. There is no sound and I can't see anything on the screen using a torch in a dark room. When I test the LED strips with a tester they read 99.5 and 99.8. If I plug them back in and start the TV it works perfect all day untill it is switched off for a period of time and then it won't work untill I repeat the LED testing again. The markings on the main board say the LED curcuit should be 94v and I am only getting 92.2v. I would apretiate any help you could give me.
                          JVC LT50C550
                          Main board TV5001-ZC02-01
                          Voltage readings of LED strips 99.5 and 99.8
                          Voltage readings When working with disconected LED's
                          Con201
                          12
                          12
                          g
                          g
                          g
                          5
                          5
                          5
                          2
                          5
                          3
                          0.1
                          g
                          con5
                          92.2
                          4.8
                          con2
                          92.2
                          4.8
                          Voltage readings When working after testing LED's with LED tester
                          Con201
                          12.3
                          12.3
                          g
                          g
                          g
                          5
                          5
                          5
                          1.9
                          5
                          2.9
                          1.9
                          g
                          con5
                          117.5
                          13.4
                          con2
                          117.5
                          15
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              If there are 10 strips of 6 leds per strip then the driving voltage would be approx 60 x 3V = 180V or 90V if wired as 2 sets of 5 strips.
                              117V would seem quite high if that above was correct.
                              Edit
                              Looks like it's depandant on the screen model if it uses 10 or 12 strips of 6 leds?
                              • Ukdigger
                                • May 2020
                                • 121
                                • England
                                Is there anyway to tell from the screen model number? V500HJI-PE8
                                MC5186082400761
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  It look as though with that panel number its 12 strips of 6 leds
                                  I think that you have an LED problem. The led tester power the leds with reduced current possibly warming up a bad joint so that when reconnected to the power supply all appears well.
                                  • Ukdigger
                                    • May 2020
                                    • 121
                                    • England
                                    Thanks, I didn't want to take the panel apart unless if the problem was elsewhere. It will be my first time doing this on an LED TV, I've only done 26 inch an LCD before. I have watched videos on Youtube and it look like a fun job. I only paid £30 for the TV so I'm not too worried about it if anything goes wrong, just got to be careful with the screen and its connectors.
                                    • Shotgun25
                                      • Feb 2014
                                      • 90
                                      You are correct, I've got this TV in right now with failed and faulty backlight LEDs and the Panel is V500HJI-PE8 with 12 x6 LED per strip backlights.
                                      The wiring for the LED strips appears to be 1 connector wiring supplies one side of the screen top to bottom, so 6 strips of 6 LEDs.
                                      I've extracted the firmware with an external programmer from the TSOP48 NAND. Do you happen to know if the firmware for these SMART TVs contain anything that would need removing before sharing the firmware?
                                      If it's safe to share as-is, where do you recommend I post it/which thread to add it to?
                                      • dick_barton
                                        • Aug 2015
                                        • 6643
                                        • Wales
                                        You can share on the "EEPROM Dump Thread" which is the first thread on the forum.
                                        If the file is too big to upload then you can Winrar it into smaller chunks.
                                        • Capacitorial
                                          Powersupply has all the voltages - Monitor still no power
                                          by Capacitorial
                                          Hello guys,
                                          I have a Philips 240B7QPJEB. The monitor seems completely dead.
                                          I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                                          On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                                          The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                                          The weird thing is, that the Power LED is powered over the TCON board.
                                          On The TCON...
                                          12-28-2024, 02:12 PM
                                        • Pipolups
                                          Corsair K70 LUX RGB dying LEDs
                                          by Pipolups
                                          Hi there !
                                          I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                                          Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                                          10-08-2024, 11:58 AM
                                        • Evgenii999
                                          Laptop Lenovo IdeaPad 3 15ITL05 doesn’t turn on.
                                          by Evgenii999
                                          I need your advice in diagnosing a motherboard issue on a Lenovo IdeaPad 3 15ITL05, motherboard HS45A/HS55A Rev 1.0 NM-D461 (2020-11-02).
                                          Symptoms:
                                          The laptop does not power on and does not respond to the power button.
                                          Background:
                                          According to the owner, her child was playing on the laptop when it suddenly shut down.
                                          What has been done so far:
                                          Original charger is missing; the non-original one was tested and found faulty (0 V output).
                                          Using a lab power supply (20 V, 0.5 A) — no activity on the board, no LEDs, no standby voltages....
                                          10-25-2025, 06:07 AM
                                        • THE GTC
                                          Insignia NS-37D20SNA14 intermittent LEDs
                                          by THE GTC
                                          So I use this TV daily as a second monitor for my PC or my Playstation - at one point a few months back I tried to fix the problem - but in the process, I figured out something that works so I haven't posted this for awhile. It is an annoying trick to have to do though, so I decided to post about it to see if anyone could spot what's wrong. It baffles me because it works on it's own half the time.
                                          When I first got this TV, I was told it wouldn't turn on, and of course I did the flashlight test, and the image was there. Also, the red LED on the front indicated that it had power (it...
                                          11-03-2020, 02:40 AM
                                        • Rank73
                                          Samsung PS51E450A1W
                                          by Rank73
                                          Hi all.
                                          It's a great place you've got here. I've learnt a lot in the last couple of days researching my problem and diagnosing this tv. It's a Samsung PS51E450A1W with no picture. Here are the symptoms and what I've tried. Any help is hugely appreciated.
                                          symptoms:
                                          No picture
                                          No chime on start. (maybe turned off?)
                                          Powers on, small flash of screen, 5 slow red leds on the front, at the same time: 1 slow and 14 long on the green led on the logic board. Then reboots and does the same.
                                          The sticker with the voltages are:
                                          VA 58
                                          07-13-2023, 03:42 PM
